Old 10-21-2014, 03:33 AM   #5531
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Originally Posted by Kodename47 View Post
Out of interest, what belt are you guys running on the smaller pulleys? I'm looking at a 70mm from a 75mm. The belt is very tight at the moment so was wondering if a shorter one is needed.
Same belt, The tensioner has plenty of range, belt will still be tight on a smaller pulley.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
The Following 2 Users Say Thank You to poorsche For This Useful Post:
CarzCarzCarz (10-21-2014), Kodename47 (10-21-2014)
Old 10-21-2014, 04:53 AM   #5532
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Originally Posted by poorsche View Post
On the market for a header, what flows good with this setup? Any research or numbers for headers with the innovate kit? Curious if FI has a preference between EL and UEL. Any data appreciated!
If you're not in any sort of hurry and are patient enough then you could probably wait until Delicious finishes his tunes for what he says are the top performing headers.
From the Delicious Tuning thread:
- JDL Equal and Unequal Length
- Tomei Equal and Unequal Length
- Nameless Header
- PPE Equal Length Header
http://www.ft86club.com/forums/showp...&postcount=841
http://www.ft86club.com/forums/showp...&postcount=847
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
The Following 2 Users Say Thank You to MINOCIN For This Useful Post:
J.C. (10-21-2014), poorsche (10-21-2014)
Old 10-21-2014, 05:49 AM   #5533
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Apologies if this has already been answered (too many pages to read), but anyone here using the non-IC kit, under high temp conditions? Such as ambient temps of around 100-110F? With 91 octane fuel? Would appreciate some feedback....
I see so many guys in here running the non-IC kits, but this isn't an option for us in Australia as they only sell the intercooled versions. I've been advised that non-IC isn't suitable for our market, but I wanted to explore this further.
Fizz is offline   Reply With Quote
Old 10-21-2014, 06:04 AM   #5534
8686
8686's Avatar
Drives: 86
I only have the non-intercooled kit for couple of months now and I live in Saudi Arabia which I assume is very hot.
I noticed a drop in power once the intake temp climp above 100F as the tune start to pull timing once the intake temp increase.
So usually I dont go full throttle in these temps. I try to keep my full throttle injoyment for early morning drives when temp is around 80 F and saving to get the intercooler ASAP.
I only got the non intercooled because I was offered a very good price from a local dealer to take it from his shelf.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Fizz (10-21-2014)
Old 10-21-2014, 06:28 AM   #5535
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Last i talked to Mark they said they would sell it on request but stongly advise against it.
It would be alright in the Perth winter like coldest of winter, summer no chance at all the heat soak with the IC kit is just manageable on the track. On the street it would be alright but if you wanted to have fun it would pull timing etc pretty quick.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
Fizz (10-21-2014)
Old 10-21-2014, 09:48 AM   #5536
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
I was just about to ask the same question. Is it the same for the 69mm pulley? Thanks for the info
CarzCarzCarz is offline   Reply With Quote
Old 10-21-2014, 10:53 AM   #5537
sam69
Drives: GT 86
Yes same belt for 75mm and 69mm pulley's .
sam69 is offline   Reply With Quote
Old 10-21-2014, 11:48 AM   #5538
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Can you explain how it feels like when it drops power, are you getting lots of knock or tip-in knock? Does the power drop below stock levels?
Old 10-21-2014, 12:35 PM   #5539
8686
8686's Avatar
Drives: 86
I felt that while testing the accelleration againest my freind car. The more we do it, the more he get close to me. like I am loosing a bit of power every time.
Old 10-21-2014, 01:48 PM   #5540
xxscaxx
Drives: 2013 SWP BRZ
I have to go back and edit my post, but I just wanted to make a quick note of whoever decides to use the brass fittings I had posted a while back for the elbows on the back of hte supercharger to use a 5/16 barb NOT a 1/4 barb for the evap line.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
J.C. (10-21-2014)
Old 10-21-2014, 02:01 PM   #5541
J.C.
Drives: '13 Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
@Fizz I'm currently running the non-IC kit on 91oct here in California. I definitely noticed the heatsoak during daily driving this past summer with 100-110F weather. Stop and go traffic also really sucked. Under normal temps (70-90F) it runs fine but I feel that the intercooler is necessary for consistent power and less heatsoak. Still not as bad as a turbo setup though... esp. w/o the proper cooling/supporting mods on the track. Hope this helps. Why do you say the non-IC is not suitable for your market?
@poorsche Running the JDL UEL right now and definitely noticed more power down low and in the midrange. I was also considering the Revworks UEL and Nameless header but got a good deal on the JDL with matching OP & FP. I'm looking to get a dyno tune once I get the IC & 69mm pulley on and will report back with data.
J.C. is offline   Reply With Quote
The Following User Says Thank You to J.C. For This Useful Post:
Old 10-21-2014, 06:16 PM   #5542
brianhj
Drives: 2017 Camaro 1SS
I had the same disappointed feeling about this kit right after install. The game changer for me was e85 and 70mm pulley. I have stock header and non intercooler and it makes 253whp with no heat soak issues so far. The best I could muster on 93 was around 220whp. The available power with e-85 is immediate though, it's a whole new animal.
Just to clarify you're using 70mm with no intercooler? Why does everyone say not to use smaller puller without intercooler? Generates too much heat?
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
CK_Bladesmith (10-21-2014)
Old 10-21-2014, 06:16 PM   #5543
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
That's exactly why
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
brianhj (10-21-2014)
Old 10-21-2014, 06:18 PM   #5544
brianhj
Yeah mine gets hot as hell with 75mm pulley, damn near burned my hand on it
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
