Old 10-19-2014, 10:24 PM   #5517
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Here's a vid that I previously recorded for another thread where I was trying to troubleshoot a low oil pressure issue. You can here the charger whirl at idle (bad stereo ground like noise), but when I rev it a few times you mainly just hear the headers rattling and the exhaust note.
Vid is of a cold start. Jump to the 1 min mark for normal idle and then revs.
[ame="https://www.youtube.com/watch?v=jwYgi7c9Pmw&list=UU1e7IXoBYddp_0Ghugo40Hg"]Oil pressure drops to zero on cold start - YouTube[/ame]
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 10-19-2014, 10:28 PM   #5518
MINOCIN
MINOCIN's Avatar
Thanks for posting the pics of the perrin intake. I'm considering getting one as well since it looks like the only intake system that will clear the mocal oil cooler sandwich plate fittings. Did you get your ecu retuned after you installed it?
Old 10-19-2014, 10:33 PM   #5519
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
No not yet, cruised around a little and it felt fine though. Waiting on a header then back to full blown motorsports for a re-tune.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 10-19-2014, 10:41 PM   #5520
brianhj
Drives: 2017 Camaro 1SS
Thanks!
I can BARELY hear anything, maybe it's these crappy headphones on my work computer. I'll watch again when I get home. Does your car idle at 1500?? Mine has that low idle rpm issue - there is a TSB out for it i think. Drops to like 600-750, bounces back to 1k, drops back down, keeps cycling like that every 5 seconds or so. Makes idling REALLY annoying and makes the whine sound like a damn theremin. I thought uploading a tune would get rid of my idle issue but I guess it didn't - if I take my car to dealership to get TSB applied will it affect/overwrite my tune from Delicious?
I'll try to get a recording of mine, maybe it seems so loud because I have like ZERO boxer rumble going on hahaha.
brianhj is offline   Reply With Quote
Old 10-19-2014, 10:42 PM   #5521
brianhj
Wish I could just "head back over to FBM"! Must be nice
Old 10-19-2014, 10:53 PM   #5522
poorsche
poorsche's Avatar
I love it, They rock.
Old 10-19-2014, 11:22 PM   #5523
MINOCIN
MINOCIN's Avatar
My car idles fine, usually at around 800 rpm. The vid was of a cold start so that's why you saw the 1,500 rpm idle. After the cats warm up the car automatically drops back to normal, which you see at around the 50s to 1m mark on the vid. If the oil and cats haven't warmed up though and I blip the throttle then the engine will drop below idle, down to like 500 rpm, lug the engine a bit and then jump up to 1,000 rpm before settling back to around 800 rpm. That only started happening though with tune version 8.65. It doesn't bother me too much though because I know that I can avoid it as long as I warm the engine up and then drive normally until everything is warm.
I bought my FRS back in July of 2012 but I never encountered any of the issues that many of the first cars saw. Even still, the TSB for the idle issue came out around the time that I received my free third oil change from the dealership so they did their thing, what exactly I don't know.
If the dealership reflashes your ecu then I would imagine that you would lose your tune. Get in contact with Zach or Bill at Delicious and see what they say,
Old 10-20-2014, 01:36 AM   #5524
brianhj
This is what I hear when I idle. I'm at home now and I can still hear that in my head. That howling wind sound really gets to me, maybe it's because of my days battling bad grounds in car stereos I don't know. But to me that is not a good sound and it's way too loud.
[ame]http://youtu.be/mroGLu_GxBA[/ame]
Old 10-20-2014, 01:43 AM   #5525
poorsche
poorsche's Avatar
Supercharger under vacuum; situation normal. Learn to love it!
Old 10-20-2014, 01:50 AM   #5526
brianhj
So I guess I installed it correctly hahaha
Old 10-20-2014, 01:50 AM   #5527
poorsche
poorsche's Avatar
Sounds fine man
Old 10-20-2014, 09:38 AM   #5528
Calum
That Guy
Drives: 2013 asphalt FRS MT
Lol since you're going to play that card I will say this to future DIYers: follow every step. What I forgot was in the instructions.
I had to try.
Old 10-21-2014, 01:43 AM   #5529
poorsche
poorsche's Avatar
On the market for a header, what flows good with this setup? Any research or numbers for headers with the innovate kit? Curious if FI has a preference between EL and UEL. Any data appreciated!
Old 10-21-2014, 02:31 AM   #5530
Kodename47
Kodename47's Avatar
Drives: UK GT86
Out of interest, what belt are you guys running on the smaller pulleys? I'm looking at a 70mm from a 75mm. The belt is very tight at the moment so was wondering if a shorter one is needed.
.: Stealth 86 :.
Kodename 47 DJ:
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
