Old 10-18-2014, 11:26 PM   #1
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Lightbulb Skunk2 BRZ Intake Results!
A customer wanted to get every last HP out of a car, and we of course are more than happy to do what it takes. While some of the intakes have a large MAF housing, they require pinching of the primary tube to get past the smaller OEM bulkhead, or reuse the OEM snorkel that necks down to 2.5". None of those are valid options in our book. However, Skunk2 aka Kraftwerks/Grams/Group A, have released their intake which addresses many of those issues. Bigger snorkel, filter, and most importantly, a HUGE elbow from the filter to the TB. This is an example of good engineering, not just throwing parts at a car. The snorkel improvement is much needed IMO, and the large diameter elbow is the reason you see the gains throughout and not just at the very top end.
Xero-Limit is offline
The Following User Says Thank You to Xero-Limit For This Useful Post:
lucid215 (10-20-2014)
Old 10-19-2014, 12:27 AM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Very nice results!
What other mods does this car have?
Carlitoz3 is offline
Old 10-19-2014, 01:19 AM   #3
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Nice gains
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline
Old 10-19-2014, 01:51 AM   #4
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Curious what the baseline was.
Was it tuned before the intake?
Andrew025 is offline
Old 10-19-2014, 02:25 AM   #5
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Need some more info!!!
tigermack is offline
Old 10-19-2014, 02:43 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
AFRs?
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Muaddib (10-19-2014), Smudgeous (10-19-2014)
Old 10-19-2014, 02:49 AM   #7
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Mike, do you happen to have any AFR data from this pull? The gains certainly look nice, but without AFR data, it's hard to know how much of that power increase is "real".
What I mean by this is some intakes I've seen made extra horsepower by running leaner (sometimes dangerously so at WOT). Even if it's not dangerously lean, the intakes that show signficantly different AFRs than stock almost always show lesser gains once properly tuned, as they don't have the same amount of tuning room due to starting leaner already.
Smudgeous is offline
Old 10-19-2014, 06:53 AM   #8
s2d4
s2d4's Avatar
Think about it for it second, how does it run leaner?
s2d4 is offline
Old 10-19-2014, 07:14 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Because less air passes the MAF sensor, making the ECU inject less fuel.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
s2d4 (10-19-2014)
Old 10-19-2014, 07:39 AM   #10
Smudgeous
Smudgeous's Avatar
A larger circumference tube will result in air moving through it at a slower rate, which tricks the cpu into thinking it needs more air.
Old 10-19-2014, 08:37 AM   #11
zooki
Drives: waiting on a 2021...
So, roughly 5-6 HP? About what a drop in filter would give you? 5 HP in a 2900-3000 lb. car(with driver) is something I don't think you could ever measure...
The OEM engineers just keep looking smarter & smarter. 😊
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline
Old 10-19-2014, 09:21 AM   #12
Xero-Limit
Xero-Limit's Avatar
Originally Posted by Carlitoz3 View Post
Very nice results!
It is built for the SCCA STX class, so header, exhaust, tune etc...running ethanol for both pre/post intake.
Should've made this more clear in the first post (it was a bit late!) but the car was tuned on the dyno before and after the intake. We put it on the dyno after the intake to do the MAF scaling (much quicker than on the street) and to see the gains from the intake. AFR is the SAME on both pre/post intake runs. The intake has an optional insert to reduce the MAF size. You need this on the stock tune. The MAF body is HUGE. You need to make it that way to get the large radius/volume elbow in there.
For the $$$ 5-6 hp is quite good. No drop in filter will make 5 hp on this car in an accurate test. Maybe 1-2 when a forced induction setup is using the OEM air box, but even then I'd say it is optimistic.
Old 10-19-2014, 11:10 AM   #13
kevin.nguyen
Drives: Ultramarine FRS
Have this intake. The butt dyno loves it. The sound it makes at around 4500 rpm sounds so nice
kevin.nguyen is offline
Old 10-19-2014, 12:25 PM   #14
Foobar
SLO NO MO
Foobar's Avatar
moto-mike,
No disrespect, but do you have some data to back that statement up? It's been long accepted on these forums that performance drop-ins like the K&N, HKS, and aFe have dyno'd 5 HP over stock on a bone-stock 86.
Foobar is offline
The Following User Says Thank You to Foobar For This Useful Post:
Boofneenee (10-19-2014)
Skunk2 BRZ/FRS Powerbox Intake System KraftWerks Engine, Exhaust, Transmission 75 06-06-2015 10:37 PM
Skunk2 Pro-C Coilovers for FRS, BRZ, FT86 KraftWerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-04-2015 05:06 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 05:09 PM
Skunk2 Garage Sale: 06.28.14 KraftWerks Southern California 4 06-24-2014 09:53 PM
K&N Intake and Unichip Dyno Results PhastekSport Engine, Exhaust, Transmission 11 04-10-2013 07:27 PM
