Old 05-12-2014, 10:12 AM   #99
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Anyone know of any fixed caliper kits that will fit under a 16X7 +46 TE37? Wasn't overly happy with my brake performance even with stock power on the track yesterday.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-16-2014, 06:00 AM   #100
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
So got the fitment template for the buddyclub BBK.
Buddyclub Template
Not sure which 4Pot 330x28 mil kit it is though, one as a 41 offset and the other has a 50.
Guess ill test both.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-21-2014, 01:13 PM   #101
BRZZZZZZZZZZ
Car Nut
Anyone?
Old 05-30-2014, 01:19 AM   #102
Gambit
Gambit's Avatar
Drives: Subaru
Anyone?
You need to contact the kit suppliers directly and ask for a caliper fitting template that you can print and physically apply to the inner of your wheel to check for clearance.
Gambit is offline   Reply With Quote
Old 05-30-2014, 05:13 AM   #103
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
So a little late but Buddyclub 330mm does not fit Enkei RPF1 17x9 +35.
So just dropped a cool 3K (aussie funny money) to get a Essex sprint kit.
Build thread
Old 06-01-2014, 10:39 PM   #104
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
STI brembo's and Rota Rt5's (18x8.5, ET 38)
The Following User Says Thank You to SkAsphalt For This Useful Post:
UltraMarine86 (06-02-2014)
Old 10-10-2014, 11:56 AM   #105
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
Does anyone have a set of CE28RT 17x9 +38s and if so, would a big brake kit fit? Thanks!
ScottDRFT is offline   Reply With Quote
Old 10-17-2014, 06:41 PM   #106
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Stoptech 328mm fits 17x8 +36 Kosei K4R and 17x8 +45 Enkei RPF1
Which means the AP Sprint fits both as well.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
brzaapi (01-20-2015)
Old 10-17-2014, 07:18 PM   #107
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
x2, looking for 16x7 options myself
Old 10-17-2014, 11:09 PM   #108
pleong
Drives: 2013 Whiteout FR-S
Just put on sti brembos
They DO NOT clear in the FRONT without a spacer
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 11-06-2014, 08:28 AM   #109
pleong
Has anyone fit the Stoptech 355F and 345R with 18x9.5 +38 Enkei RPF1s?
Old 11-06-2014, 11:14 AM   #110
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I can confirm this, I have 2012 STI Brembo brakes and run a 8mm spacer in the front.
The Slow One is offline   Reply With Quote
Old 11-10-2014, 03:37 PM   #111
pleong
Has anyone tried the 355 stoptechs with 18x9.5 +38 Enkei RPF1s?? I used the template and it seems to clear EXCEPT for the height.... but stoptech says minimum 18" wheels...
Old 11-14-2014, 03:48 AM   #112
Alphard
Tried ultra's multi-template (http://www.ft86club.com/forums/showp...9&postcount=81) and seperate templates for essex sprint and essex endurance on 18x7.5 +48 ZE40s.
Essex sprint is a very tight fit, only around 1mm clearance from the spokes. I would use a spacer if i opted for this kit.
Essex endurance has plenty of clearance, around 7mm clearance from spokes and plenty of clearance from rim.
Stoptech 328mm is another good fit, similar to essex endurance.
Alcon 365, 334 and stoptech 355 don't fit. Good clearance from rim, but calipers are too big and don't clear the spokes. All of these would fit with a spacer.
Alphard is offline   Reply With Quote
big brake kit, brembo, essex, stoptech, template
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 10:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) — General Topics 727 03-17-2013 07:29 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) — General Topics 13 03-01-2012 12:56 PM
