Old 10-15-2014, 08:20 PM   #5461
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by sw20kosh View Post
Into the motor.
The oil that lubes the supercharger gears is getting into the engine? It's not sealed?
brianhj is offline   Reply With Quote
Old 10-15-2014, 08:30 PM   #5462
Calum
That Guy
Drives: 2013 asphalt FRS MT
It's supposed to be.
Old 10-16-2014, 10:34 AM   #5463
8686
8686's Avatar
Drives: 86
Innovate (Sprintex) Supercharger Owners Topic
I went to change the spark plugs to HKS range 10. My mechanic found some oil on the old spark plugs. Now I dont know if it from the SC oil or Engine oil.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 10-16-2014, 11:03 AM   #5464
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Sounds unlikely that oil consumption from your sc is contaminmating your spark plugs. I've lost maybe half an oz. After about 8000 miles.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 10-16-2014, 11:07 AM   #5465
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Any pics of what your plugs looked like? Here's mine after 16k non boosted miles and 5k boosted miles. Name:  ImageUploadedByTapatalk1413472017.679434.jpg
Size:  201.7 KBName:  ImageUploadedByTapatalk1413472035.474724.jpg
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 10-16-2014, 11:09 AM   #5466
poorsche
poorsche's Avatar
Any oil in the intake tube? Could be blow by.
Old 10-16-2014, 07:44 PM   #5467
8686
8686's Avatar
Drives: 86
The intake tube is clean.
Here is a picture of spark plugs after 11k NA and 200 SC miles
I am using lucas octane booster for the last 5k miles as our pump gas is worse than 91
I installed dual catch can setup and will inspect the plugs after couple of hundred miles.
Size:  144.6 KBName:  ImageUploadedByTapatalk1413502949.760750.jpg
Size:  148.4 KBName:  ImageUploadedByTapatalk1413502967.015432.jpg
Size:  144.6 KBName:  ImageUploadedByTapatalk1413502984.327942.jpg
Old 10-17-2014, 02:33 AM   #5468
poorsche
poorsche's Avatar
If you've been using octane booster for 5,000 miles then I think we've solved the mystery of the fouled plugs. I would ditch the octane booster! Where do you live? As long as you aren't having knock with the fuel that is available to you I wouldn't worry too much.
Old 10-17-2014, 02:56 AM   #5469
8686
8686's Avatar
Drives: 86
I used the octane booster because my car was knocking. I live in Saudi Arabia. So I have to limit the use of the octane booster?
Old 10-17-2014, 02:58 AM   #5470
poorsche
poorsche's Avatar
That's a pickle. I really don't think octane boosters are meant for continued use, but fouled plugs are better than knock.
Old 10-17-2014, 06:14 PM   #5471
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Why is your fuel so bad? Just doesn't make sense especially being the US receives a lot of oil from Saudi Arabia. Correct? You would think you would have the best fuel. Learn something new every day.
Cheers,
William Knose
Old 10-17-2014, 08:17 PM   #5472
8686
8686's Avatar
Drives: 86
Cheers,
William Knose
refining technology is old. We need to import some new technologies from the US and some corn juice.
Old 10-17-2014, 11:56 PM   #5473
blown
Drives: ft86
Cheers,
William Knose
most of our oil is imported from Canada. not the middle east where most people believe. actually we get more oil from latin america than middle east.
blown is offline   Reply With Quote
Old 10-18-2014, 12:27 AM   #5474
DeliciousTuning
Interesting...
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
