Old 10-14-2014, 01:44 PM   #1
RaveSaint5
Drives: 2015 Subaru BRZ Series.Blue (White)
Exclamation Shifting issue?
First off, sorry if this isn't in the right area to post. This is my first post lol.
So yesterday, at 1700 miles on my BRZ, I started getting some weird feedback from my shifter when I shift to 2nd and 3rd. Going from 1st to 2nd, not all the time, but enough to make me worry, it seems that when I push the clutch pedal, the clutch doesn't completely disengage the gear I was on, and when I switch to second, I get a push like I'm switching as if I'm not pressing the clutch all the way. Same thing happens when I get from 2nd to 3rd gear, but it's a lot more feedback switching to 3rd.
This doesn't happen all the time. It started happening yesterday quite frequently, and only once today driving a total of about 50 miles.
Any tips would be greatly appreciated.
2015 BRZ Series.Blue.
RaveSaint5 is offline   Reply With Quote
Old 10-14-2014, 02:15 PM   #2
jp_r6
Change your oils asap to motul gear 300, both tranny and diff
jp_r6 is offline   Reply With Quote
Old 10-14-2014, 02:39 PM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
Or bring it back to the dealership...that's what the warranty is for.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
JohnJuan (10-15-2014)
Old 10-14-2014, 02:52 PM   #4
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Don't do anything. Bring it to the dealer. This is becoming avery common issue and if people don't report it we will never get a recall. It's worn syncros.
The Following User Says Thank You to Reaper For This Useful Post:
Old 10-14-2014, 02:55 PM   #5
calidus
Drives: 2013 SWP BRZ Premium
Let your car warm up for 5-10 minutes and see if you still have the issue.
calidus is offline   Reply With Quote
Old 10-14-2014, 02:57 PM   #6
Reaper
Reaper's Avatar
Drives: violent
You shouldn't need to do that. It's worn syncros. A known issue. Take it in and get the transmission warranted.
subieshanerz (10-17-2014)
Old 10-14-2014, 03:00 PM   #7
calidus
hmm I have had my car for 9 months with a similar issue, I guess I should have them take a look. Should I mention the syncros or just the effects?
Old 10-14-2014, 03:01 PM   #8
Reaper
Reaper's Avatar
Drives: violent
Syncros. They should put a new transmission in.
Old 10-14-2014, 03:59 PM   #9
RaveSaint5
Awesome. Thanks for the replies guys. I did drive it for another 20 miles today and it did start doing that again after about 10-15 miles in on my second trip.
I'm going to get an arrangement at the dealer ASAP and try to drive it as little as possible.
EDIT: Going to the dealership at 8 AM on Thursday. Hopefully everything goes well.
Old 10-14-2014, 08:23 PM   #10
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Keep us updated! I was wondering the same thing, how would I know if I have worn synchros?
What would I need to notice and feel to know that its in fact the synchros?
I'm just wanting a heads up just in case since I have a Series.Blue also.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 10-14-2014, 08:24 PM   #11
RaveSaint5
Sounds good. I'll keep you all posted Thursday.
Old 10-14-2014, 08:36 PM   #12
Reaper
Reaper's Avatar
Drives: violent
It will grind or crunch going into gear between shifts. Alot of people are having this happen. More people need to report it to their dealers so it turns into a warranty.
Old 10-16-2014, 12:16 PM   #13
RaveSaint5
Update: So I just got back from the dealer. Arrived at 9 AM and just got home. 5 minutes ago (11:10). They couldn't duplicate the problem so sadly nothing was done. However, on my 35 minute drive home from the dealer, I didn't have any grinds. What's to stop it from happening in the future again anyways... They told me to come back when it's a constant issue.
EDIT: Just got back from the T-Mobile store around 10 minutes ago at 1:55 PM. Felt grinding again at only 3rd gear. Seems to happen when I push her a little bit aggressively. Will do more testings.
Old 10-17-2014, 12:57 AM   #14
Poodles
Drives: 2015 Series.Blue
This does nothing for warming up the transmission or diff. It's also bad for your engine.
clutch, issue, shifting
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 08:15 PM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 01:30 AM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 10:05 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 04:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
