Old 10-12-2014, 01:04 PM   #1429
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Originally Posted by cslntuee View Post
What's different between these two STI strut for BRZ?
https://www.japanparts.com/parts/detail/45136
https://www.japanparts.com/parts/detail/45805
Thanks.
One is front set only, the other is all 4 corners. Aside from that, w/o part numbers for the front only set, it's hard to tell if there's any difference w/ the parts. Color appears to be different too. Why don't you just contact them and ask?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 10-12-2014, 03:52 PM   #1430
DSOmegaX
DSOmegaX's Avatar
Thanks.
Should be different dampers. The first link are tS spec and are made by Showa. The second are bilsteins. Because the tS suspension is a paired spring and damper set, I'm going to assume the bilsteins are designed for the available STi springs you can purchase seperately
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
cslntuee (10-12-2014)
Old 10-14-2014, 12:36 AM   #1431
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks.
The Bilsteins seem to be part of a new set released only a few days ago: http://www.sti.jp/news/2014/14012.html
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
cslntuee (10-14-2014)
Old 10-14-2014, 06:16 AM   #1432
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Looks like the thicker rear axle is out!
http://www.sti.jp/parts/catalogue/br...8421AS100.html
Check out the price of the new Bilstein kit:
http://www.sti.jp/parts/catalogue/br...0310ASXXX.html
krayzie is offline   Reply With Quote
Old 10-14-2014, 06:41 AM   #1433
krayzie
Drive From Home
krayzie's Avatar
The STI site is showing different part numbers for the springs on the Bilstein kit.
When will this madness end, everytime I feel I've almost finished the catalog they come out with more expensive stuff!!!
The Following User Says Thank You to krayzie For This Useful Post:
cslntuee (10-16-2014)
Old 10-16-2014, 12:12 AM   #1434
cslntuee
Drives: Subaru BRZ Limited
It looks like the front spring is same as Ts one, but the rear is different.
http://www.ft86club.com/forums/showp...&postcount=891
cslntuee is offline   Reply With Quote
Old 10-16-2014, 04:20 AM   #1435
mister.bond
Drives: BRZ Subaru
Hi, i have question again about the Part :
STI
DRIVESHAFT(ST28421AS100)
Has someone informations about it or will someone going to order it ???
What Type of Material is the STI Driveshaft made of ?
Is it made of cast Aluminium ???
Total weight of the Driveshaft??
can it be used for AT , too ?
and the other questions is, what type of performance / advantages will that STI Driveshaft give to my car ?
perhaps someone here has more infos
mister.bond is offline   Reply With Quote
Old 10-16-2014, 07:41 AM   #1436
aznatama
aznatama's Avatar
Picture is an axel. Probably just beefed up.
'14 BRZ LTD MT DGM
Old 10-16-2014, 08:18 AM   #1437
Kayshart
What's the difference between STi parts and tS parts?
Seems like they have different part numbers for the same item?
Kayshart is offline   Reply With Quote
Old 10-16-2014, 10:42 AM   #1438
krayzie
Drive From Home
krayzie's Avatar
They would never have different part numbers for the same item. Please research again carefully.
Old 10-16-2014, 11:08 AM   #1439
aznatama
aznatama's Avatar
My inclination is that Sti parts are more track oriented than ts parts. Even though the ts is a "task ready" edition of the brz. It could be the other way around though... Just go look up the specs for each of you are really going to spend the money for them.
'14 BRZ LTD MT DGM
Old 10-16-2014, 11:15 AM   #1440
krayzie
Drive From Home
krayzie's Avatar
BRZ tS has two different versions, Standard and GT package. The STI Performance Catalog does include some semi-track oriented parts but still not as hardcore as the selection from the TRD Performance Line catalog.
Kayshart (10-17-2014)
Old 10-16-2014, 11:36 AM   #1441
aznatama
aznatama's Avatar
I just want those Recaros...
'14 BRZ LTD MT DGM
Old 10-16-2014, 01:48 PM   #1442
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Haven't we discussed here already about the drive shaft being beefed up over the current one, and people were complaining about why you'd beef up the drive shaft, but keep power output the same? I always postulated it was to ensure it could take track abuse. Most of these parts have that as their justification, sacrificing daily driver practicality for parts that are noisier, but more robust, possibly heavier.
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
