Old 10-11-2014, 05:30 PM   #1107
otterpop
Drives: 2015 scion frs
Originally Posted by protpibe View Post
If you're running the 8psi actuator, I would suggest a clutch right away. You'll get clutch slip in higher gears in the 9ish psi range.
Ok thank you for your that. I'll definitely keep it in mind. Any recommended clutch?
otterpop is offline   Reply With Quote
Old 10-11-2014, 06:06 PM   #1108
Pete156
I like to eat!
The stock clutch can handle roughly 220wtq. I'd base clutch replacement on this figure instead of boost number. I have been running my stock clutch with the 8psi actuator for 15,000 miles with no noticeable slippage. (I don't abuse it either)
Pete156 is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete156 For This Useful Post:
Astroboy (10-11-2014), protpibe (10-11-2014)
Old 10-11-2014, 06:34 PM   #1109
Astroboy
Astroboy's Avatar
Drives: None
Does anybody feel a thump when starting their vehicle? Every time I start my vehicle, I notice a thump from the passenger side. I'm hoping it's just a wheel bushing from when oil got in there due to a bad oil leak coming out of the AVO cam plate pump.
Astroboy is offline   Reply With Quote
Old 10-11-2014, 06:37 PM   #1110
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I thought mine was fine until I put it in 5th gear and floored it at around 3-4k rpm and it started slipping.
As for clutch recommendations, I'm running an exedy stage 1 and have no complaints.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
otterpop (11-02-2014), Pete156 (10-11-2014)
Old 10-11-2014, 06:37 PM   #1111
protpibe
protpibe's Avatar
The first thing I would check is the overpipe. Do you have an aftermarket one?
Old 10-11-2014, 08:31 PM   #1112
otterpop
Yeah I would check your pipes it could be the initial "cold start" making them radle and cause it to make a noise. Is it a continuous noise until you start driving or as soon as you turn it on and it does a single thump sound?
Old 10-11-2014, 10:08 PM   #1113
BRZranger
Originally Posted by Musickmixxer90 View Post
Hey guys,
New guy here, so sorry if this question was answered before. I am looking at this kit to turbo my car and was wondering if the TRD CAI would work with this? also, what would I need for a 8psi boost level? I've got an AT so I will follow @BRZrangers build closely, any other advice for a turbo noob? :P
Thanks for the mention, I have been busy and haven't had time to be active on the forum. My BRZ is at about 25k miles right now, so I've had the turbo on for almost 20k miles. I have had no problems with the turbo and it has run very well. I believe this is in part due to @AVOturboworld's excellent build quality and @Drift-Office's excellent install, tuning and regular maintenance.
BRZranger is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZranger For This Useful Post:
Drift-Office (10-14-2014), Musickmixxer90 (10-17-2014)
Old 10-11-2014, 10:24 PM   #1114
Astroboy
Astroboy's Avatar
Drives: None
Yes, sadly, I have no friends. So who's going to start up my car while I check it
Old 10-12-2014, 12:42 AM   #1115
protpibe
protpibe's Avatar
Check the pipe to see if it's obvious that it's hitting something. If not, wedge a rag in there and start it to see if it still makes the noise on startup.
Old 10-12-2014, 11:22 AM   #1116
protpibe
protpibe's Avatar
Here's another public service announcement that I hope will save someone else hours/days of frustration
Shortly after installing the 3" downpipe/overpipe/frontpipe, I developed an exhaust leak. As it turns out, it was at the downpipe/overpipe flange and then overpipe/frontpipe flange. After tightening everything down again, it seemed like the overpipe was at a VERY slight angle causing the 2 flanges to not sit flush. The front pipe nor the down pipe have any forward and backward play, only up and down, so the overpipe being a couple mm too short is a bit of a problem. I used all kinds of torque pattern combinations to try and have it pull everything together evenly, but eventually it would leak again due to pulling apart. I also put it up on a hoist at work and loosened every exhaust bolt in the system (down pipe to catback) and re-tightened everything in order. Still no go!
The solution!
I ended up using 2x vibrant gaskets per flange to "lengthen" the overpipe enough to create a consistent contact patch between the two joint areas. The exhaust is now dead silent.
Just to make sure I never have to go down there again for that reason, I sandwiched permatex copper between the two gaskets and then again on the flange/gasket areas as well. I figure it would give it another layer of flexibility in thickness if needed once it warms up.
I'm not saying you have to do this, I'm just saying that this was my experience. The clearances are VERY tight and as a result, you need to get it just right when installing.
I hope this saves someone a bit of frustration
The Following 4 Users Say Thank You to protpibe For This Useful Post:
Astroboy (10-12-2014), Draco_PR23 (10-14-2014), kbogarto (10-12-2014), Sportsguy83 (10-12-2014)
Old 10-12-2014, 11:23 AM   #1117
protpibe
protpibe's Avatar
Sorry, double post
Old 10-12-2014, 05:30 PM   #1118
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Is someone using the AVO Kit in combination with an Exedy stage 1 clutch kit? Any hints on how much torque this clutch could handle? It's rated for 254 TQ@ the flywheel but since the OEM clutch handles already roughly 220 TQ this seems to be a very conservative number.
Any suggestion for a blow-off valve which would fit directly onto the AVO kit and could be set up to vent in to atmosphere? I'm missing the blow-off whistle of my STI
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 10-12-2014, 10:39 PM   #1119
protpibe
protpibe's Avatar
I'm using the exedy stage 1 and it's fine. It's known to hold significantly more than the stated 250wtq, but I'm sure the service life will be cut down. You should take a look at the new revision Stage 2 Exedy. From what i've read, it has the same drivability characteristics as the Stage 1 but is rated for more power.
The Following User Says Thank You to protpibe For This Useful Post:
Flasher (10-15-2014)
Old 10-14-2014, 07:55 AM   #1120
Flasher
Smartass
Flasher's Avatar
Ok thx for sharing your experience. I've installed the stage 1 clutch already a few weeks ago and I'm very satisfied at the moment. But I was thinking if I would need a new clutch, if i would go for more power/torque. 300whp would be nice. Currently I'm at ~300 hp
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
