Old 10-10-2014, 10:03 PM   #29
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by aagun View Post
i have same sound . i had drift event and weekend drifts . can you inform us what was worn in you diff ??
I actually never found out the real answer. The dealership insists the differential has spider gears but most of my research shows that open differentials are the ones that have spider gears.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
aagun (10-11-2014)
Old 10-11-2014, 11:17 AM   #30
aagun
Drives: 86
is the sound came while course control ???
do you use down shafting to reduce the speed ??
aagun is offline   Reply With Quote
Old 10-11-2014, 11:40 AM   #31
aagun
Drives: 86
[ame="http://www.youtube.com/watch?v=r0NsMzdFcZg"]Differential Side Gear Backlash Measurement - YouTube[/ame]
Old 10-11-2014, 11:50 AM   #32
aagun
Drives: 86
[ame="http://www.youtube.com/watch?v=co1LpI8fy4Y"]TorSen t-2.avi - YouTube[/ame]
Old 10-11-2014, 12:08 PM   #33
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I'm sorry, course control?
I hadn't really experienced any changes to noise with respect to gear selection but I really only encountered the noise at low speed 1st and 2nd gear tight turns (in parking lots).
For all I know, the noise was present at higher speeds and gears but I simply did not hear it over the engine.
Old 10-11-2014, 08:16 PM   #34
aagun
Drives: 86
Cruise Control
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
Car sensing clutch fully engaged when its not// 504 Issues | Warranty | Recalls / TSB 1 09-16-2014 10:02 AM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
Clutch / Diff / Gearbox issue? doggy Issues | Warranty | Recalls / TSB 5 10-03-2012 10:47 AM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
