#575 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Update:
Warlock-29 Titan-28 Hunter-26 (missing purple booties, but that will change as soon as i hit rank 2 w/ vanguard) 27 coins / week at least and 3 opportunities for raid loots! :P
-Jack Burton |
#576 |
T64-416Ax3=13,140shp
Drives: 2002 AP1 and 2015 F-150 EB (DD)
#577 |
Okay, after reading up on Ice Breaker, do want.
| The Following User Says Thank You to 53Driver For This Useful Post: | MokSpeed (10-10-2014) |
#578 |
Granny Shifter
Drives: 2014 FR-S
Anybody want to run the weekly nightfall tonight I will be doing it to get some strange coins.
#579 |
Praise Helix!
I'm about to drop this damn Thorn mission. Any time I start ramping up void kills I get slaughtered a whole bunch and drop down to zero again. And I need five hundred points.. And it's not even the best hand cannon in the game either... Seriously the difficulty far outweighs the reward, I'm thinking.
| The Following User Says Thank You to n2oinferno For This Useful Post: | 53Driver (10-10-2014) |
#580 |
Anyone up for a VoG raid this weekend?
Ice Breaker... I have 33 coins, might need to make a purchase this week. Solo'ed the weekly nightfall, first try. WAY easier than I expected with the everything-burn modifier. Typically difficult majors/ultras were roasted in short order. I really, REALLY wish we didn't have these harsh ammo penalties when switching weapons. I can understand having a penalty to switch weapon types, but it's compounded by different elemental damage. Its not a huge problem I guess, just really annoying because it's so artificial. At least ammo boxes give me a reason to spend glimmer. |
#581 |
#582 | |
Granny Shifter
Drives: 2014 FR-S
I'm Central as well. Anytime after 7:30 works for me. I don't sleep on Friday nights. |
#583 |
So another question. Lets say you have a level 15 autorifle that is saved in the armory. If you start a new character, does that new character have to be level 15 before he can use it? I ask because I saved a lot of low level weapons initially with the plan of having better weapons to use for a new character. If that restriction doesn't exist, then I'll clean house tonight and start saving higher level weapons.
#584 | |
Okay, later usually works better for me. I usually can get on for about an hour or so right after work, but then with dinner and spending time with the girlfriend etc it's usually around 9 or so if I get back on there. I'd be down though. I'll add you as a friend when I get home tonight. Then maybe we can launch around 9 or so. |
#585 |
What character and level are you again? I'm lvl 25 Titan. My Striker Sub-class is maxed out, just started working on the Defender subclass. I do have the protective bubble available now, so let me know which sub-class would help out more on the strike and I'll make sure I equip it before we role.
#586 |
Granny Shifter
Drives: 2014 FR-S
I'm a 27 Gunslinger Hunter. My friend is a defender and his bubble is maxed so if you'd like to run your striker we could use a good super that can clear hordes when we're in a tight spot. The weekly nightfall is Winter's Run so prepare for the Archon Priest.
I use the Galahad-E and Final Boss sniper so I'll keep people off your back from picking you off at distances. |
#587 | |
#588 | |
Granny Shifter
Drives: 2014 FR-S
Okay. We might have to go find you some raw materials and level your gear a little bit first. If I remember correctly, Bungie stated a 3 level gap may make opponents immune to your attacks. If not immune then extremely resistant. So even getting you to 26 will go a long way. I know all the farming routes for each planet though so we should be good. |
| NorCal86 Facebook Groups | finch1750 | Northern California | 41 | 01-08-2024 01:58 PM |
| [TX] DFW General Discussion | feedbag | Southwest | 1488 | 06-18-2022 07:25 PM |
| El Monte Car meet raid by polices- 115 citiations given | Speed2th | Southern California | 5 | 07-18-2014 02:22 AM |
| Gundam Universe - General All Discussion Thread | poormans_LFA | Off-Topic Lounge [WARNING: NO POLITICS] | 273 | 03-23-2014 11:45 PM |
| Any groups in the Stockton Area? | MidLife&luvIt | Northern California | 73 | 06-09-2013 06:14 PM |
