Old 10-08-2014, 04:29 PM   #1
2pointSLOW86
Drives: 2015 Whiteout FRS. Much Slow, No Go
Wheel bolt stripped
So, i got a nail in my tire the other day and i went in to go get it patched. The guys at the tire shop told me when they tried to get the lug off, the bolt was spinning with the lug and they couldnt get it off. Anybody have this issue before?
2pointSLOW86 is offline   Reply With Quote
Old 10-08-2014, 04:31 PM   #2
2pointSLOW86
Fail....wrong section..IGNORE
Old 10-08-2014, 07:33 PM   #3
Seen far, FAR more off topic posts!
continuecrushing (10-08-2014), Ultramaroon (10-12-2014)
Old 10-08-2014, 07:41 PM   #4
sirsol66
Drives: 2013 FRS- Hot Lava
Do you have the stock studs, or aftermarket? Stock wheels? Who was the last person to remove/install your wheels?
My guess is that the last person who installed your wheels hit the lug nuts HARD with a impact and spun your studs. I don't have experience with this, so I will just say good luck as I hate issues like this. I would google to try to find an ingenious solution. my guess is you will have to drill the lug nut off (hopefully without damaging the wheel) and then replace the stud.
sirsol66 is offline   Reply With Quote
Old 10-08-2014, 07:53 PM   #5
2pointSLOW86
I had toyota replace the stock rims with aftermarkets. All i know is they were the only ones to touch em since the swap so your guess makes sense. I have an appt tomorrow with the dealership to have them replace whatever they messed up. Damn rookies :mad:
Old 10-08-2014, 07:57 PM   #6
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
i had this happen to my old speed 3, discount tire had made the mistake but sadly i was swapping over to my winter set up at home. discovered the issue, had to ride to discount tire on 4 of 5 studs nearly shitting myself the entire way (about a 30 minute drive). The manager who knew me apologized and went to work re-threading the stud. if that didn't work he was going to send me to a shop to get a new one put on thankfully i didn't have to go that far and he had me out in about 10 minutes. Toyota will fix this for you.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 10-08-2014, 08:05 PM   #7
2pointSLOW86
So wait, how did he manage to get the bolt off in the first place? Im just curious cuz my bolt is literally so stuck on there that they said they couldnt get it off unless they broke it off. I wouldnt have been opposed to that if they actually had replacement bolts tho
Old 10-08-2014, 08:18 PM   #8
RobertPaulson
Drives: 2017 Golf R
Well as i was removing the bolt, it felt like it was tight then entire time (needed to use a breaker bar) and then it spun freely not coming off. I managed to wiggle it off after much swearing and effort. in your situation i wouldn't mess with it, just bring to the dealer and let them deal with it.
Old 10-08-2014, 08:20 PM   #9
2pointSLOW86
Will do... I had no plans on messing with it. Just wanted to know if anyone else had this problem and how it was resolved. Thanks guys 👍
Old 10-09-2014, 03:12 PM   #10
2pointSLOW86
So i took it to the dealer and it turns out they stripped more than one bolt on the other wheels. Amazing isnt it?
Old 10-10-2014, 01:08 AM   #11
Poodles
Drives: 2015 Series.Blue
Monkeys with impact guns...
The Following User Says Thank You to Poodles For This Useful Post:
2pointSLOW86 (10-10-2014)
Old 10-10-2014, 11:19 AM   #12
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
This is somewhat a common issue with this car. I have had two drivers side studs snap. I carry two spares just in case now. I know others who have had the same issue with the stock studs.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-10-2014, 11:21 AM   #13
2pointSLOW86
Looks like just another issue to add to the list
Old 10-10-2014, 11:49 AM   #14
projekkt
Drives: 15 wrb brz
Every toyota dealer (that my parents have taken their toyotas to) overtorques the lug nuts to at least 100-120.
Toyota cars = 12mx1.5.
I think this may make a difference. I don't think we have an issue at 80ftlbs of torque. Its super easy to reach without much force too so I can't imagine them doing a good job with their impacts.
projekkt is offline   Reply With Quote
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 02:11 PM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
