Old 10-09-2014, 08:14 PM   #43
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Pete156 View Post
Couldn't agree more! Most of the ~300whp 86s on this forum will completely run away from the 500whp ones while they sit and spin. Totally unusable power in 99% of real world situations.
Wanna race?! We can put your theory to the test.
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
CxG (10-27-2015), OmarGC (10-10-2014)
Old 10-09-2014, 09:06 PM   #44
Pete156
I like to eat!
Sure! Autocross?
Pete156 is offline   Reply With Quote
Old 10-09-2014, 09:15 PM   #45
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
has anybody here even driven a frs or brz with over 240 whp? most of you will say no. till you do this you don't need to even think about 2jz or v8 swaps
sweetfrs is offline   Reply With Quote
Old 10-09-2014, 09:15 PM   #46
Dipstik-sportech
Sure, I'll be sure to install my r comps. You do know the throttle isn't a light switch right? I don't have to use all 500whp from the moment I touch the throttle.
Old 10-09-2014, 09:22 PM   #47
Pete156
I like to eat!
Yes, I do. Have you run autocross with this setup (In the rain)?
Old 10-09-2014, 09:28 PM   #48
Dipstik-sportech
Not in the rain but I have auto crossed it on my 560 tread wear nittos and guess what..... I beat all the stock FRS/brz's and placed 2nd in the street tire class. It's all in how you use the power and how good of a driver you are to be able to control it. Any other questions?
The Following 4 Users Say Thank You to Dipstik-sportech For This Useful Post:
CxG (10-27-2015), D_Thissen (10-15-2015), glorydays (01-12-2018), vividracing (12-30-2014)
Old 10-09-2014, 09:29 PM   #49
Pete156
I like to eat!
I haven't lost to a stock 86 either, with street tires. That's not saying much. If you live in the PNW you pretty much have to run in the rain.
Old 10-09-2014, 09:33 PM   #50
Dipstik-sportech
We lucked out and none of our events were rained out. Off boost my car makes no more than stock power so it stands to reason, on part throttle it will be as easy to drive as stock.
Old 10-09-2014, 09:47 PM   #51
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
This is why the lsx wins over the 2jz. More usable power. A lsx frs would probably be easier to drive than my 450+whp fa20.
Old 10-09-2014, 09:47 PM   #52
Pete156
I like to eat!
I imagine when you do come into boost on an autocross course it must take some extreme right foot control. Good on ya for getting out there and performing with that setup.
Old 10-09-2014, 09:49 PM   #53
Dipstik-sportech
It's a crowd pleaser that's for sure on the street tires.
Old 10-09-2014, 09:52 PM   #54
Reaper
Reaper's Avatar
Drives: violent
It's all in the tune. Boost by gear, rampable boost and per gear traction control are all a click away in ecutek. But a large displacement na v8 will always be easier to drive then a fi 4 cylinder of the same hp. Trust me, my first tune made power too quick with my gtx28.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
CxG (10-27-2015), hmong337 (10-10-2014)
Old 10-09-2014, 11:03 PM   #55
solus
Drives: 2014 Scion FRS (Ultramarine)
Originally Posted by AZFA20 View Post
Sounds like neither of you know how to drive. Nor do you understand the use of traction control aids I guess
To say there is nothing left of the 86 is also not even remotely true. The only thing different is the engine and trans.
Oh well.......... steps out to shop to actually build cars.
Ha! The axles, differential, suspension, drive shaft, brakes, and all associated components will need work to support that much torque reliably to the ground. Essentially only the body of the twin will remain...
If you think these stock parts will hold up under that kind of stretch then you have a rude awakening coming
solus is offline   Reply With Quote
Old 10-10-2014, 01:01 AM   #56
Poodles
Drives: 2015 Series.Blue
Originally Posted by solus View Post
The first question you should ask... Why do you need 500 hp? Because without upgradig damn near the whole car then then the power is worthless other then to brag to the Internet that you have 500 hp. Also, after all that upgrading why not just buy a corvette?
If it's just for the challenge of hitting 500 hp yourself then have fun.
Why do you need a sports car when a Prius will do? Why do you need a car at all when a bike or your own 2 feet will do?
See how stupid that sounds?
Originally Posted by PhoKingCool View Post
Exactly! Keep in mind guys, 95% of the people that say they're going with a LSX, 2JZ, or whatever swap, end up dropping their projects because it goes over their heads. Kind of like those two guys working on their 1-2 year long "2JZ Project". @slicktop @Drift&Drag Is it really worth it to dump that much money and time into this chassis?? Not only that, but what about utilizing the power behind the build. Both engines are over built for what this car can handle. SMFH What a waste!! lol
Considering the size of the tires you can stuff under this chassis and how beefy the suspension really is, you're simply 100% wrong.
Originally Posted by Jawnathin View Post
LSx > 2JZ
Naturally aspirated high displacement engines FTW
Sure, if you like single digit gas mileage
Originally Posted by Decay107 View Post
Buy Literbike ===> go faster than ANY swapped/modded FR-S
and for pennies on the dollar too...
Depends on gearing and power levels. I've heard this line before and watched Supras absolutely destroy them...
I stand corrected.
Still, if you want to go fast it's hard to make a compelling argument against bikes. Unless, of course money is of absolutely no concern.
Depends, with how many trucks and SUVs with idiots behind the wheel around here, a bike is a death wish...
Still not convinced that 500 hp is useable on this chassis... Most "500 hp" builds are over built and achieve nothing other that sounding cool when you read off the mods sheet. Props for having the technical fortitude to actually do the work though. Just seems as a useful as tits on a bull.
Also, basically you're swapping a Twins body onto a GM car, almost nothing except the look of the car will remain in order to put that kind of power down on a consistent basis.
You make it sound like you can't get decent sized rubber under this car, and that it's magically going to snap the chassis in two. It's been consistently proven the chassis is very overbuilt on this car.
Maybe on a car without any tuning that gives full boost in first gear. We've been able to get real traction control with different boost levels per gear for decades now...
Originally Posted by FRSBRZGT86FAN View Post
Not to be off topic here, but I feel this car to be even more fun only needs 20-40 more hp. I'm surprised nobody has done an FA20F swap from the new wrx or jdm legacy gt or something...
Won't fit, would make less power than adding FI to our FA20 because of the dual fuel system we have, etc...
- Axles I dunno of failures from power (lots of failures from being too low, just like the WRX/STI crowd). So what, get beefier ones.
- Differential is the same size as the old MKIII Supra IIRC, so it will take it just fine. Oil cooler will help on high speed runs though.
- Suspension is fine (unless of course you're putting in a much heavier engine, so then you need springs to match)
- Drive shaft is fine and if it needs to be stronger it's no big deal as everyone is swapping them anyway.
- Brakes, there are bolt on options for this and people with stock power are even going to BBK's so I fail to see your point.
THIS CAR WAS DESIGNED TO BE TUNED. They knew all of this stuff would happen and it's why the aftermarket support for this car is huge. Want to stay stock? Good for you, but you're in the minority...
The Following 3 Users Say Thank You to Poodles For This Useful Post:
Cross (10-16-2014), CxG (10-27-2015), hmong337 (10-10-2014)
stupid yet curious question(fa20 turbo) friss21 Forced Induction 2 03-24-2014 07:55 AM
nj brand new fa20 turbo kit minus turbo 2500 kingkai23 NY / NJ / CT / PA 3 03-06-2014 06:41 PM
FA20 turbo exhaust setup. Baramzisyan Engine, Exhaust, Transmission 26 02-20-2014 07:58 AM
FA20 Turbo? slidethis Forced Induction 23 09-27-2013 11:55 AM
new jdm legacy B4 uses FA20 turbo cyde01 Forced Induction 3 07-26-2012 02:00 AM
