Old 09-20-2014, 11:15 PM   #43
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by imom View Post
I say it is anal...because you do have TPMS on these cars. Unless you get a slow leak from a screw...it's not going to change much unless you're the type of person that wants a specific PSI per tire weekly or so to ensure better gas mileage
Suppose... if you like buying new tires more frequently.
The ID10T light is for people without a clue who would ruin them completely without it.
I use my selection of high pressure bicycle pumps to keep all my tires inflated to my preferences.
Not hard to do once in a while, and it's free season specific air.
For those without access to the correct phlogiston mixtures:
http://kalecoauto.com
The Following 2 Users Say Thank You to bcj For This Useful Post:
extrashaky (09-21-2014), Manic (10-10-2014)
Old 09-21-2014, 07:38 AM   #44
imom
Drives: BRZ sold
I stand corrected of 86 TPMS...I was more used to my old Z4... BMW allows you to set the TPMS trip point. I haven't bothered with the BRZ. I don't know what the TPMS trip point...I believe the factory/dealer sets it. This is another of the few things I miss from my old car. BMW will tell you how much gas is left not an idiot light to have you guessing.
Why do you use high pressure bicycle pumps? It's really not that efficient..the volume of a bicycle tire is fractions of a car tire. You'll have popeye arms by the time you are done. Get a little compressor and adjust it to your desired pressure.
In any case, I still just do a walk around weekly and check about a month or two my tire pressures and I lose about 2 to 3 psi if that on my tires all around. More power to you for checking more often...as I said before.. it's not bad to be more cautious and check... but if you get gas every week to check the tires every time...it's a bit much for me. Also I noticed that every time you check...a little bit of air goes out so then you have to fill up the tires more often. So if you check every gas fill up...say once a week, I think in about a month or so...you'll lose about that 0.5 to 1 psi per tire. I say that much because I also double check readings on my tire pressure reading...so first time you insert the gauge and remove some air will go out of the valve. Do it twice and then do it 4 times a month...it adds up. Then it's more work to break out the compressor or/and fill up all 4 tires.
P.s. I use a nice analog truck guage that has 0 to 60 PSI...so it's very accurate.
imom is offline   Reply With Quote
Old 09-21-2014, 02:15 PM   #45
stonenewt
Drives: BMW 120d
You'll get popeye arms by trying to put 160psi in a tyre with a 140psi rated pump. You'll need very few reps but a lot of force, that's how you build bulk muscle.
Putting 35psi in a high volume tyre will just give your arms some tone as well as getting a great cardio work out due to the number of repetitions
I much prefer a my stirrup pump because each stroke is about 0.1psi. This makes it nice & easy to get the right pressure in my tyre first time .
stonenewt is offline   Reply With Quote
Old 10-07-2014, 06:22 PM   #46
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Just wondering why nobody has mentioned filling the tires with nitrogen. The dealership offered it to me at the beginning of winter, last year, and I never had any tpms lights come on even when it snowed.
lastexile1987 is offline   Reply With Quote
Old 10-08-2014, 08:57 AM   #47
My tpms has come on once each year when the temp first drops below 60F in the morning. Other than that, I check my tires about once a month and have never had to add air.
As far as nitrogen, there is some benefit to it, but I stick with the standard 78% Nitrogen mix I've been using since the dawn of time. I don't see any real reason to pay the premium for the remaining 22%.
Old 10-08-2014, 09:09 AM   #48
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
No idiot lights on my 2014 Canadian BRZ, I can play with the pressures as much as I want
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-08-2014, 11:48 PM   #49
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I keep an Airgas size 200 nitrogen bottle in the garage to use with all of my tires. I've got two race cars and a lot of vehicles, trailers, and other wheeled items with pneumatic tires, and it's handy to have a high-pressure system to fill tires quickly.
The bottle costs around $50 per year to rent, and the more or less annual nitrogen refills are also around $50. One of the best things about the system is the high pressure in the bottle - truck tires are my largest capacity fills, and they fill really fast with the pressure set at 150 psi.
The fact that it's nitrogen is useful mostly for the race tire fills. Nothing that I have has TPMS anymore so that doesn't come into play.
dradernh is offline   Reply With Quote
Old 10-09-2014, 01:06 AM   #50
alan.chalkley
Drives: 4wd zooks
Every time i fill up fossil fuel , i check tyre pressures and look for nails/screws in the tyres.
I do this with four cars in an effort to avoid punctures.
alan.chalkley is offline   Reply With Quote
Old 10-09-2014, 03:28 PM   #51
octavio.molina.1985
octavio.molina.1985's Avatar
Drives:
Every two weeks when I wash the car boiii!!
Sent from my itablet
octavio.molina.1985 is offline   Reply With Quote
Old 10-10-2014, 01:42 PM   #52
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
This is my new favorite website.
Manic is offline   Reply With Quote
When you guys swapping to summer tires? dem00n NY / NJ / CT / PA 28 03-25-2014 01:33 PM
Fill and paint? or PDR... rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-12-2014 09:36 PM
Where did you guys sell your old oem tires/wheels??? eddieEndo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 07:34 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 05:46 PM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge [WARNING: NO POLITICS] 64 04-13-2011 01:36 AM
