Old 10-07-2014, 11:51 AM   #239
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
CBR600RR (10-07-2014)
Old 10-08-2014, 08:48 PM   #240
quality_sound
Drives: '15 BRZ Series.Blue
Duuuuuuuude, that's BADASS!
quality_sound is offline   Reply With Quote
Old 10-09-2014, 08:47 AM   #241
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by quality_sound View Post
Thanks for the info. I want to move mine to the OEM key location. If I move the seat heater switches it'll be to install the controller for my processor.
You can't move it to the OEM location, the button assembly is too deep and there is a bunch of steel in your way.
toast is offline   Reply With Quote
Old 10-09-2014, 09:25 AM   #242
quality_sound
Then how does the Premium fit a key cylinder in there? I'm not saying you're wrong because I obviously haven't looked, it just seems weird that a key cylinder will fit but a momentary switch wont.
Old 10-09-2014, 10:02 AM   #243
toast
Both Premiums and Limited have the main ignition wiring running to the steering column. In the Premium the switch is bolted to the column and connected to the wiring. In the Limited a steel box is bolted to the column that handles all the higher current switching and gets its input from the momentary switch.
Anything is possible of course, just a matter of how badly you want it. From what I saw when I (admittedly quickly) looked, it would be a decent amount of work to unmount that box and relocate it. I'll look again tonight, because I would like to put it there as well and put a single cup holder in the middle of the console instead of the push button.
Old 10-09-2014, 11:19 AM   #244
qoncept
qoncept's Avatar
I can't answer your question but the guy that installed my amp did put a gain knob in the stock key location without any problems.
qoncept is offline   Reply With Quote
Old 10-09-2014, 12:00 PM   #245
toast
I can see that, there is some room. The issue is the push start switch is about 3" deep.
Old 10-09-2014, 12:33 PM   #246
Jive Turkey
the tuna, no crust.
yeah, i hate to rain on your parade, but the push button, atleast the OEM one is HUGE. look at my photos comparing the before after when i painted. i'm sure you can make it work, but i think its more hassle than its worth. especially because you will have to run all kinds of wiring there.
you may have to extend the piece out a bit more to gain clearance but that will just look funky. unless you can relocated stuff inside the column it will be hard to fit. i can look into this if you want, since i have to pull my interior apart this weekend to put in something i made and thing you guys will like.
you have a limited right?
Old 10-09-2014, 01:36 PM   #247
qoncept
qoncept's Avatar
If you want to move the button to the steering column switching to a different switch shouldn't be an issue.. you can barely see it there anyway. Is there anything special about it or is it just a normal momentary switch?
Old 10-09-2014, 01:57 PM   #248
toast
It has 7 wires connected to it, I would imagine there is more to it than momentary contact. I haven't looked at the wiring diagram to see what logic is in there.
Old 10-09-2014, 02:07 PM   #249
quality_sound
Well dammit. I'll have a look as well, maybe I'll get lucky.
I have a Series.Blue, so basically a Limited. lol
Old 10-09-2014, 02:08 PM   #250
quality_sound
That would be really handy to see. It almost sounds like the switch controls the logic for accessory, start, and off, instead of the ignition module controlling it. That would explain the size of the button.
Old 10-09-2014, 02:22 PM   #251
toast
The entire FSM is online, it is in a sticky on the this site.
Old 10-14-2014, 06:37 PM   #252
Jive Turkey
the tuna, no crust.
instagram will do for now.
The Following 4 Users Say Thank You to Jive Turkey For This Useful Post:
calmtigers (10-20-2014), Creole (10-16-2014), Michael (10-19-2014), SkAsphalt (10-16-2014)
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 10:17 PM
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 58 04-11-2011 09:03 PM
