Old 09-30-2014, 10:49 PM   #2031
ZZT86
ZZT86's Avatar
Drives: BR86
I must admit mine is also behaving oddly even before upgrading to 1.11.1 (it launches & within seconds stops it's WiFi check, updates etc) although I reckon something else is amiss on my old IBM PC running XP with Norton 360 failing to stay running. I may have to either try a repair or reformat the old dog as I'm still in the process of getting a MacPro up to speed to run Win8Pro :/
ZZT86 is offline   Reply With Quote
Old 10-01-2014, 04:56 AM   #2032
steve99
Drives: FT86
mine updated fine to 1.11.1 last night
Old 10-01-2014, 06:37 AM   #2033
Stumpygt86
Drives: Toyota GT86. N/A for life
I found that since it is a new version my antivirus was causing issues as only a few people had used it previously. The more people that update the OFM, the less likely the antivirus will have issues with it
Stumpygt86 is offline   Reply With Quote
Old 10-01-2014, 10:53 AM   #2034
phrosty
Anyone notice that the OpenFlash posts under Commercial Classifieds are no longer active?
phrosty is offline   Reply With Quote
Old 10-01-2014, 10:58 AM   #2035
SOAZ
Drives: pinto
Noticed that. The big OFH thread is dead at the moment.
SOAZ is offline   Reply With Quote
Old 10-01-2014, 11:08 AM   #2036
phrosty
It looks like the OpenFlash guys are no longer forum sponsors, that's why.
Old 10-01-2014, 11:15 AM   #2037
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Was a couple hours late in paying vendor fees. Should be back up and vending later today
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DC2R (10-01-2014), phrosty (10-01-2014), SOAZ (10-01-2014)
Old 10-01-2014, 11:15 PM   #2038
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Hope you guys get a chance to look at this: http://www.ft86club.com/forums/showthread.php?t=75238
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 10-05-2014, 03:13 AM   #2039
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Hey,
If someone has a little time to spare, could you look at my log and tell me if everythings alright?
Just put in a new OP, hoping to stop a very annoying leak. Pedal response is much better, but maybe a little bit off? not sure.
Log said I had cylinder 2 misfire =/...happened during no throttle.
http://www.datazap.me/u/ray7792/new-...2-3-5-6-7-9-12
OFT stage 2 93
Thank you!!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 10-05-2014, 04:42 AM   #2040
steve99
Drives: FT86
Originally Posted by ray7792 View Post
Hey,
OFT stage 2 93
Thank you!!
Dont think that misfire is anything to be too concerned about unless it becomes frequent and repeatable. and it may be due to you running quite rich.
You ltft look good less than 4% but you seem to be runnig a bit on the rich side 11.25 all the way through midrange to higher rpm seems very consistent almost too consistent its just looks sus.
try logging wideband afr with oft that will look at second 02 sensor input and see if it reads similarly stable it just weird is so rich and stable with low fuel trims.
Old 10-05-2014, 10:45 AM   #2041
ray7792
ray7792's Avatar
Hey Steve, thanks so much for looking at it!
oh, apparently the reason for the rich afr is due to my FA20club CAI. Vishnu said everyone that has one runs 11.25 for some reason lol.
Thanks again!
'13 BRZ (sold)
'17 STI
Old 10-05-2014, 10:53 AM   #2042
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Did you scale the maf with your FA20cai ?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-05-2014, 02:08 PM   #2043
phrosty
The OFT and OFH threads in Commercial Classifieds are still closed. Is there a plan to open them back up?
Old 10-23-2014, 02:44 PM   #2044
Necric
Getting error 0x65, problem reading from device. And when I try to upgrade I get missing file AUTOCST.LST
Necric is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
