Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-03-2014, 02:37 PM | #2073 | |
For STX class you would want to coilovers to be competitive. Are you out to be competitive in a certain class or just trying to have fun? - Andy |
10-03-2014, 03:13 PM | #2074 |
Drives: 2013 FR-S Matte Orange
Sorry, was in a hurry. I was pushing entering corners and did a temporary remedy of letting air out of the tires but I had to take them down to 28PSI hot to do anything. It helped but I'm needing to srub off more speed to keep things in check. The rear is wanting to step out as well. I've gotten it to lose grip with less speed than I was exiting with before. My current rear camber is -2.2 so I'm hoping adding a bit will make it stick a bit more. I've thought about going to full soft on the sways or even unhooking it.
10-03-2014, 03:29 PM | #2075 | |
Drives: VW MK6 GTI | 13 Mustang GT
Would a STX build be better for that? I would prefer a neutral setup instead of a tail happy car like the FR-S is stock or with a rear sway bar only. I did read this thread: http://www.ft86club.com/forums/showthread.php?t=52755 And it looks like the Tarmac 0's are a good choice but with the stock bars or only front upgraded bar. Should I instead start with the Tarmac 0's then add a front bar or start front bar then do T0's? Sticky summer tires will be on both setups.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
10-03-2014, 04:10 PM | #2076 |
Drives: 2013 Firestorm FR-S
So I am currently debating between running in CS or STX for the next season of autocross (my first full season).
For CS, I like the idea of being able to make my car fairly competitive (not factoring in the driver mod lol) for relatively cheap. I already have a 2nd set of OEM wheels for winter that would function as track wheels during the autox season. However, I also like the idea of being able to modify my car even more to my liking with STX. One of my concerns with STX comes from changing between daily wheels (17x7 OEMs) and track wheels (most likely 17x9 RPF1s). Once I get coilovers (planning on SACHS since I get a significant discount) will I run into any issues with the tuning of the suspension or ride quality going back and forth between such different sized wheels?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
10-03-2014, 04:13 PM | #2077 | |
RCE T0 are a great choice and work well for track and auto-x. If you know they're in the plans then I would start with them as that will be the most dramatic change. You may like them without changing bars at all. One note, a hardcore, dedicated, nationals level STX car may not be ideal on the track. BUT a well set-up track car will still be pretty quick for auto-x. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Brzzee (10-03-2014) |
10-03-2014, 04:17 PM | #2078 | |
Drives: 2013 FRS Whiteout
The situation is that if I go by strut measurement and get both sides even then when I measure the hub-fender distance, it'll be different or the car won't look even. I opted for adjusting coil over so it's visually when and disregard strut length.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
10-03-2014, 04:17 PM | #2079 | |
1. I would think about softening the rear sway if you raised the rear (and I do think that raising the rear was a good call). 2. The slight bit of extra rear camber you added also is probably good. 3. I was a little confused on what you did for your damper settings. I would soften the front rebound a bit if you're understeering on entry. 4. Can you not reach your rear adjusters? - Andy |
10-03-2014, 04:19 PM | #2080 | |
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | yomny (10-03-2014) |
10-03-2014, 04:27 PM | #2081 | |
Thanks for your time and believe it or not a means the world to some of us that you guys take the time just to answer. Any time I need parts your webpage is the first visit. Got my track pads from David at csg.
The Following User Says Thank You to yomny For This Useful Post: | Racecomp Engineering (10-03-2014) |
10-03-2014, 04:47 PM | #2082 |
Off Topic
@rs999, @Shark_Bait88,
Check this thread out. http://www.ft86club.com/forums/showthread.php?t=72735 This would put you in STX, but it's a good deal. Especially with the upgraded springs included. |
The Following User Says Thank You to gramicci101 For This Useful Post: | Shark_Bait88 (10-03-2014) |
10-03-2014, 04:50 PM | #2083 | |
The Following User Says Thank You to Shark_Bait88 For This Useful Post: | gramicci101 (10-03-2014) |
10-03-2014, 04:54 PM | #2084 |
Off Topic
10-03-2014, 05:01 PM | #2085 | |
Thanks. I did soften both compression and rebound. They were previously set nearly at full firm by GC so I moved them right into the midrange on each setting. I can't do the rears because I can't see the adjuster. The instructions show doing it out of the car with the shock in a vice. Ain't gonna happen today. If I'm missing something about how to adjust the rears please tell.
10-03-2014, 05:19 PM | #2086 | |
- Andy |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
