Old 10-02-2014, 03:20 PM   #113
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
They are 0603( in the door switches), but if I remember correctly, you can use the PLCC-2. They will just be a bit brighter. I would recommend using the correct size, but shouldn't hurt too much. You must use the correct size(0603) when it comes to the Base radio, as there are cut outs in the buttons for the LED to fit. 0805 Might work, but might as well order the right one first time.
Old 10-02-2014, 03:30 PM   #114
vividracing
vividracing's Avatar
Great write-up!
vividracing is offline   Reply With Quote
Old 10-02-2014, 04:43 PM   #115
Top-Secret
Drives: FRS monogram
If i can use PLCC-2 then all is good because thats what i used for everything else
Top-Secret is offline   Reply With Quote
Old 10-02-2014, 05:05 PM   #116
JHSurf
JHSurf's Avatar
Drives: 2015 BRZ Series.Blue
DIY - Gauge Cluster LED swap
For the 2015 BRZ Series.Blue, there is enough room behind the buttons for PLCC-2 LEDs but the solder pads are too tight to get them soldered in. The 603 will work but are smaller than the stock LEDs.
JHSurf is offline   Reply With Quote
Old 10-02-2014, 07:17 PM   #117
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
You can, that's what I did.
Pwolf is offline   Reply With Quote
Old 10-03-2014, 05:19 PM   #118
JHSurf
JHSurf's Avatar
Sorry took me longer to get the pics than I thought.
To disassemble the Nav HU just release the 10 clips around the front bezel.
Then disconnect the ribbon cable from the front panel. (Circled in red)
Then disconnect the small ribbon cable connecting the control board from the other board. (Circled in blue)
The big board in the front panel has 1 single LED on it. While the small control board has all the LED's for the volume knob and the push buttons.
To remove the large board, remove the 4 screws and disconnect the 2 ribbon cables shown here.
To remove the the control board, remove the volume knob by pulling straight out from the bezel front. Then remove the 7 screws.
Old 10-04-2014, 12:56 PM   #119
iniguez310
Cool Guy
Got this done yesterday and today as i was driving I noticed that the mps needle doesnt move, at idle the RPM guage reads 0 and my gas needle is a little off. I did follow the instructions with marking the position of the needles. Any suggestions on what i can do when reassembling it again?? Going to pop it off during the weekEnd,
iniguez310 is offline   Reply With Quote
Old 10-04-2014, 02:08 PM   #120
JHSurf
JHSurf's Avatar
One thing you might try.
Mark the positions with car turned off
Remove the needles
Start the car then turn it off
Replace the needles in the marked positions.
It sounds like the positions may have shifted when installing the needles. Not sure why the one is not moving though. What I did was hold the end of the needle with one hand in position then press it into place with the other.
Old 10-04-2014, 02:09 PM   #121
JHSurf
JHSurf's Avatar
Finished my full interior conversion this morning. I will post pics after it gets dark and I can get the tripod setup in the back seat.
Old 10-06-2014, 08:39 AM   #122
CJBRZ
Drives: 2015 Series.Blue
Just finished this up going to play around with gauge cluster a little more until I get exactly what I want, but for for anyone else who wants to do this, the correct LED sizes on the are as followed:
Dual Climate Control, Clock, Traction Control, Gauge Cluster are PLCC-2
Dim switch and headlight angle switch are 3mm LEDs.
Trunk open button is a single 0603
The doors and radio are 0805
CJBRZ is offline   Reply With Quote
Old 10-06-2014, 08:47 AM   #123
JHSurf
JHSurf's Avatar
Push Start is also PLCC-2
Old 10-06-2014, 06:19 PM   #124
CJBRZ
I decided to leave mine red so I forgot all about that one.
Old 10-06-2014, 06:21 PM   #125
JHSurf
JHSurf's Avatar
I left mine red for a few days but it felt like an elephant in the room so I changed it to blue
Old 10-06-2014, 06:29 PM   #126
Top-Secret
Im in the same boat. Got a bit of red left thats driving me crazy but i havent found the time yet
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
