Old 09-19-2014, 03:32 PM   #1
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
TRD Canards w/ No Drill?
Hey all
I was wondering if it'd be possibly to install the TRD Canards without drilling into the front bumper? I see that they're also attached with 3M backing tape and that stuff is supposed to be pretty strong.
Would there be any issues if I shaved down the protruding tabs and had just the 3M holding it down?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-19-2014, 03:50 PM   #2
STV3
Señor Member
STV3's Avatar
I don't know how much down force they actually generate but I could see them possibly ripping off at high speeds and maybe taking your paint with them.
STV3 is offline   Reply With Quote
Old 09-19-2014, 04:12 PM   #3
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
this car doesnt generate that kind of downforce lol
GT86drifter is offline   Reply With Quote
Old 09-19-2014, 04:24 PM   #4
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
You must have never stuck your hand out the car window on highways. I can generate massive downforce with just my hand. Imagine a properly designed and placed canard.
bimmer635csi is offline   Reply With Quote
Old 09-19-2014, 04:28 PM   #5
STV3
Señor Member
STV3's Avatar
Exactly. This is also at probably 65-70 mph. If he tracks his car or just decides to do a 135mph run down the freeway one night I can definitely see the 3m tape giving out.
Old 09-19-2014, 05:17 PM   #6
calmtigers
I know the spoilers dont necessary generate nearly as much as do canards but wouldn't the logic be similar? If fast enough the spoilers that are attached just via 3M would get ripped off?
I also always assumed that 3M auto rated tape was removable w/o damage
Old 09-19-2014, 06:25 PM   #7
KenTK808
Drives: White 2014 Scion FRS
Where I'm from they would get instantly stolen
KenTK808 is offline   Reply With Quote
Old 09-19-2014, 07:12 PM   #8
STV3
Señor Member
STV3's Avatar
Well I don't know if it would actually rip off paint but think about how much more 3m tape there is holding on a spoiler compared to a little strip that would be holding a canard on.
Old 09-19-2014, 07:16 PM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
might as well just drill into it and save the headache of it flying off. or buy some cheap pepboy ones and tape those on there and not worry LOL
Old 09-19-2014, 08:59 PM   #10
calmtigers
I think i'd risk it flying off but the paint thing is the reason why I dont want to drill into the bumper.
See I already had those but they gave me too much HP to the point where the front wheels were coming off the ground had to uninstall :/
Old 10-02-2014, 12:40 AM   #11
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
drill it. 3m wont hold it. the only two spoilers that use 3m tape on this car that i know of is trd and 5axis. both are low profile and stick within the slip stream of the car. cannards will be hit full force by the wind. besides, why do you want to 3m it? so you can remove it later? if it can hold on till then, it will probably take away paint when you try to remove it.
mrlewistan is offline   Reply With Quote
Old 10-02-2014, 03:00 AM   #12
calmtigers
That is the exact reason, my mod philosophy is do things only in so far that
a. can remove it if I get tired of the look
b. it will look decent after removing!
Old 10-02-2014, 12:47 PM   #13
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Just think about the force generated by the spoiler, it's more perpendicular to the mounting surface than a canard, where it's nearly parallel to the mounting surface. So in once instance, you'll have a good amount of force promoting adhesion between the surfaces bonded by the tape, and in the other instance you have a good amount of force trying to rip apart the two surfaces, at an angle nonetheless.
Also, properly bonded 3M tape is not supposed to be removable.
Why are people so scared of drilling into plastic, but okay w/ using permanent adhesives?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
The Following User Says Thank You to aznatama For This Useful Post:
8R6 (10-02-2014)
Old 10-02-2014, 12:57 PM   #14
calmtigers
ahhh this makes sense! Well I think it's because a lot of people (like myself) always thought you could remove it with some wire and goo gone!
Thanks folks, looks like I wont be getting these little cannards after all
APR front bumper canards WallsAndFoundations Cosmetic Modification (Interior/Exterior/Lighting) 0 09-13-2014 09:15 PM
FS: Password Canards (inner) $75 shipped EggsAreGood Exterior Parts (Aero, Lighting, Etc.) 4 05-03-2014 06:29 PM
APR BRZ Canards and Front Lip SilverSkyline210 Cosmetic Modification (Interior/Exterior/Lighting) 15 07-05-2013 11:55 AM
Toronto FR-S orders- Drill or no Drill on bumper Dragon86 CANADA 35 10-12-2012 01:35 PM
Canards? blackfireball5 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-13-2012 02:58 PM
