Old 09-25-2014, 07:57 AM   #925
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
So now I've been thinking either 225/40 front with 255/35 rear
Or
235/40 front and 265/35 rear on 18 x 8.5 et45 front and 18 x 9.5 et45 rear.
Stock suspension for now
Any input?
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 09-25-2014, 08:36 AM   #926
Raven604
Or
Any input?
Let er rip bud
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 09-28-2014, 06:56 AM   #927
Aidos
Aidos's Avatar
Drives: Orange GT86
So im going to be putting 265's on my 18x9.5 +40's. Just a question for guys that have done the same. Is there any noticable "performance" difference. Eg. Lower acceleration.
Thanks
Aidos is offline   Reply With Quote
Old 09-28-2014, 09:50 AM   #928
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
255/40R17 As usual rubbing the rear fender/bumper tab but only on extreme circumstances.
yomny is offline   Reply With Quote
Old 09-28-2014, 01:57 PM   #929
J.C.
Drives: '13 Raven FR-S
So I'm looking to get a meatier tire setup... the 225/40/18's V12's I have on my Volk CE28N 18x8.5 +44 are almost done as far as tire tread and they don't grip enough for me with the SC I have installed. Also not a fan of the (slightly) stretched look but they came with the wheels.
I was thinking either 235/35/18 or 245/35/18 all around. I'm dropped about 1.8" on coilovers and running 10mm spacers in the rear. -2.0 camber all around but I'll probably be getting another alignment/ height adjustment when the tires go on. Any thoughts?
J.C. is offline   Reply With Quote
Old 09-28-2014, 02:18 PM   #930
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Ditch the spacers and go with either 245/35/18 or 255/35/18.
sdemo is offline   Reply With Quote
Old 09-29-2014, 12:33 PM   #931
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Looks great man, but just a word of advice, if you're looking to be launching the car any, the rear has to come up a bit. Anything more than a 1" lower in the rear starts putting too much stress on the rear axle.
raul is offline   Reply With Quote
Old 09-29-2014, 12:40 PM   #932
yomny
yomny's Avatar
Meaty Tire Thread
Thanks man, it's actually about 1" exactly, may seem lower because of the fatties lol. But I actually raised it about 1/8" on all 4 corners after those pics. Rides nice, re aligned it and I have 1.5 up front and 2.5 rear camber all natura(well front struts are slotted, maxed). I need to get control arms and top hats to get those numbers a bit better.
Tabs removed
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Old 09-29-2014, 09:36 PM   #933
raul
Lap time enthusiast
raul's Avatar
@yomny 2.5 in the rear is where you need to be anyway, just get to -3 in the front and you have a good starting alignment for good handling.
Old 09-30-2014, 04:19 PM   #934
yomny
yomny's Avatar
Thanks I'll keep that in mind. I guess I should aim towards getting the top hats to get the front adjusted as the rear is on the right track.
Old 10-01-2014, 05:46 PM   #935
brzjun
Hey guys, I read through couple pages, but I just wanted to double check.
I have Hankook Ventus Evo K110 255/40/18 tires and bought 18x9.5+40 wheels. Will this fit on both front and rear or is this too much sidewall? Thanks in advance!
brzjun is offline   Reply With Quote
Old 10-02-2014, 01:45 AM   #936
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
that's way too tall. 245/35 i think is ideal but a more common tire size is 255/35
Use a tire calculator to help you compare your oem tire diameter to that of the tires you want to purchase.
http://www.discounttire.com/dtcs/infoTireMath.do
AutoRnD is offline   Reply With Quote
Old 10-02-2014, 08:08 AM   #937
yomny
yomny's Avatar
I think it'll be too much, i have the 17x9" with 255/40 up front and if too low the tire will hit the inner front fender liner. You'll need serious camber settings and some good fender rolling it they could work at all
Old 10-02-2014, 11:16 AM   #938
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
that is a bit too tall, it will look like a balloon.
you should either go with 255/35 or 265/35. but it also depends what tire, as all brands run different.
a 245/35 ideal on a 9.5 rim? you're kidding right?
it all also depends on offset, not a single person ever mentions offsets. i don't have crazy camber settings, or etc. granted my rear is rolled flat, but even with it not rolled there was room just have to trim the rear bumper "tab"
Jive Turkey is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
