#85 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Here is what we removed: + removed airbox + I disconnected the charge pipe coming out of the blower, and I disconnected the last two pipes in the system (the one with the maf and the one going to the throttle body). + removed the strut tower brace + removed the driver side diagonal brace + removed the single bolt on the perrin motor mounts that connects it to the subframe Notable things we left: Full exhaust left bolted on I think I left the gearbox mounts in place We jacked up the motor on each side that we were working on. About 2" did the trick. I have the perrin resonated catback, so the flex pipe on the resonated part let me keep everything connected. Looking back I probably should have taken the bolts off the gearbox mount. I have to check my oil pressure. I assume you can't do it unless you have an external sensor? I have run 10w30 before but you can feel the difference as the car felt more sluggish to me dailying it around.
#86 |
Drives: Panda FR-S
Yeah. I used to have hard starts. It was a russian roulette. I went over to e85 flex fuel. Haven't had any starting problems when ethanol is present. I haven't tried pure petroleum since.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| The Following User Says Thank You to Cal3000 For This Useful Post: | Tye300 (09-29-2014) |
#87 |
Drives: Toyota 86 TRD Version AT
Installed the moto-east flex fuel kit last night, and filled up with e85. I got e58 since I had some 1/4 tank of pump left. Had my car custom tuned for flex fuel. After a few runs, we ended up with 300.86 whp with 218.33 torque. The tune is not done yet, as I have to fill up with pure E85 to get tuning done for higher ethanol content. Not bad for stock 9psi pulley imo.
Here's a comparison for the current tune: RED is 85 tune on stock 9psi pulley BLUE is 93 pump tune on 9psi pulley PURPLE is stock tune with headers. (could not find the baseline tune) ![]()
| The Following User Says Thank You to Tye300 For This Useful Post: | Cal3000 (10-05-2014) |
#88 | |
For oil pressure you need an external gauge, the sender gets plugged into the oil gallery bolt hole by throttle body. In the heat by you and if you track I think you will be shocked at how low the oil pressure drops on 0w20 after 215F. I had to switch to 10w30 for daily driving. And 10w40 for track and that's at 80F ambient temps.
| The Following User Says Thank You to Dezoris For This Useful Post: | misooscar (10-01-2014) |
#89 | |
#90 | |
#91 |
SLO NO MO
Curious - how many of you guys are using Vishnu's Open Flash Tablet Tuning with an aftermarket header on your Vortech cars? Any feedback, negative or positive?
#92 | |
Drives:
Sent from my SM-N900T using Tapatalk |
| The Following User Says Thank You to misooscar For This Useful Post: | Foobar (10-11-2014) |
#93 |
Y u do dis?
anyone know if the tomei EL header will fit with this kit?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#94 |
Custom User Title
Drives: Spaceship
Maybe we could add this to the front page.
MAP Scaling for OMNI 3-BAR and Diagnostic Trouble Code to disable for OFT300 Tune: ![]() If the P0068 code isn't showing in OFT300 Tune, Shiv or you can disable it in a Hex Editor. Straight from Shiv: "The P0068 switch is at 0x11DD54. I just changed the 01 (on) to 00 (off)." PRO TIP for FIRST TIME Installers: Before you mount the SC to the car, pull the tensioner 98% open. You should see a hole on the block and a hole on the Tensioner Pulley at the 7-8 o'clock position lining up - stick a small Allen Key or something similar in there to keep the tensioner open. Otherwise you'll have a hell of a time working around the dipstick mount to try and rotate the tensioner, ask me how I know. Also, when installing the belt, slip the belt over the silver smooth idler under the A/C compressor as the last step before you release the tensioner. This is by far the easiest. Thanks to @Shiv@Openflash, @zkv476, @stratodyne and THIS thread for help along the way. |
| The Following User Says Thank You to alexand3r For This Useful Post: | Foobar (11-25-2014) |
#95 | |
SLO NO MO
Is there any benefit in going back to the 3 with this scaling on the tune? P.S. I was able to get the P0068 option by incorporating TD-D's mapping definition from his files on github. I had to use the one for my CALID of course. The OFT300 is based on the 1.x not the 2.x OFT maps, so use the right file for your ECU. Sent from my Nexus 5 using Tapatalk |
| The Following User Says Thank You to Foobar For This Useful Post: | alexand3r (11-25-2014) |
#96 |
Drives: 2013 FRS, 2002 WRX Wagon
I actually found the top bracket (which goes to the alternator) bolt on the SC plate will hold a serpentine belt tool in the fully open position while installing belt...
Sent from my Samsung Galaxy S5 |
| The Following User Says Thank You to Joeprelude For This Useful Post: | alexand3r (11-25-2014) |
#97 | |
Custom User Title
Drives: Spaceship
Also, good point on the OFT300 tune. Just verify you are using the 1.x definitions. 2.x will load, but give you crazy values (could also brick your ECU if you proceed to load a tune modified with them). Ah, yes, that could work too. Just make sure to have a long enough wrench. Last edited by alexand3r; 11-25-2014 at 02:49 PM. |
#98 |
Ah, yes, that could work too. Just make sure to have a long enough wrench.[/QUOTE]
There is a $20 tool which is specifically for tensioner at autozone. This trick work with these, plus you can access from the top and it's almost 3 feet long so you get a lot more leverage on the tensioner Sent from my Samsung Galaxy S5 |
| New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems | Brian@Vortech | Forced Induction | 168 | 08-08-2018 11:45 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 02:05 PM |
| Vortech Supercharging System Update - More boost, more POWER! | Brian@Vortech | Forced Induction | 337 | 03-12-2016 03:42 PM |
| Vortech Supercharging Systems Now Legal On 2 Continents... | Brian@Vortech | Forced Induction | 27 | 01-22-2014 01:33 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 05:49 PM |
