Old 09-30-2014, 02:41 AM   #575
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Dezoris View Post
I forgot are you on a 40 or 50wt oil?
If you are seeing max of 210F on that monster you wont be worrying about pressures and could get away with 10w30 or 10w40 and enjoy the extra power from it.
Motul xclean 5w30
Was thinking of doing a 10w40 but decided to test 5w30
Was running 7.8 psi on sat but decided to bump it down to WG spring pressure (6 psi) on Sunday (this is what @CSG Mike drove) in order to preserve brakes and be more confident and predictable with the throttle:
Contrary to what most people thought, my use of E40-E50 at the track was not for big power but for consistency of power output, preservation and extra cooling of the cylinders.
Old 09-30-2014, 06:16 AM   #576
Dezoris
Dezoris's Avatar
Originally Posted by sw20kosh View Post
Motul xclean 5w30
Sounds like you are going to have a very stable setup for extended lapping and consistency. Post back updates on temps vs pressures when you start pushing harder in the heat.
Old 09-30-2014, 07:09 AM   #577
buddy32
Drives: WRB Subaru BRZ Limited
As mike said temps were great. Coolant during hot laps would be somewhere between 196 - 208 and oil would be somewhere between 200-210. Quite the contrast to 230-240 coolant and 265-270 oil I saw a month ago with a 13 row setrab and 100 deg ambient.
The 25 row series 9 setrab is double the volume of the Perrin 13 row series 6. I suspect it is doing a very good job of removing heat from the oil, which in turn is preventing a lot heat from entering the coolant system.
I am on stock radiator. @mkivsoopra who has a koyo radiator and the same 25 row who was running 3(?) more psi and ~50(?) more whp than me saw the same temps.
I tested oil pressure on track. 60-75 psi at redline depending on how warm the oil was (max of 210ish). @Dezoris
Still need to test it next summer in 100 deg temps.
Whoa, awesome! Do you street your car at all? Any problems of oil being too cool?
buddy32 is offline   Reply With Quote
Old 09-30-2014, 07:17 AM   #578
CSG Mike
CSG Mike's Avatar
I'll let him answer that
Old 09-30-2014, 11:19 AM   #579
sw20kosh
Yes lol. These thermostats don't shut completely. Currently I am taping up some of the rows with gorilla tape but will be looking into a more permanent solution like manual valve in the oil cooler hose to stop flow completely when I want or as mike suggested a forester XT oil cooler on top of what I have.
Old 09-30-2014, 12:44 PM   #580
CSG Mike
CSG Mike's Avatar
Keep in mind you're reading temps post-cooler; at lower RPMs, you're not moving as much oil through the system, so you see super low temps, but inside the engine, it's not going to be super cold... but there's no way to see it.
Old 09-30-2014, 12:51 PM   #581
s2d4
s2d4's Avatar
Will it fit with a thermostatic sandwich plate? mocal? our hoods aren't exactly all that high?
Old 10-06-2014, 12:09 AM   #582
sw20kosh
Footage from last track event. Dat turbo sound!
[ame]http://youtu.be/ifkb-ZhlRkY[/ame]
@ptuning
Old 10-06-2014, 05:14 AM   #583
CSG Mike
CSG Mike's Avatar
@ptuning
I don't actally hear the turbo in the video... 480p... still processing?
Old 10-06-2014, 12:04 PM   #584
sw20kosh
Lol I can hear the turbo just fine.
@BRZkitty uploaded this for me from her gopro. I don't know the reason for 480p vs 720 etc
Old 10-06-2014, 12:22 PM   #585
xwd
Has anyone tried the kit with a smaller turbo like a GTX2867R yet? I'm assuming it would bolt right up if you using a Tial v-band turbine housing?
Old 10-07-2014, 03:50 AM   #586
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
I asked about it with PTUNING and they said something about having to redesign a new mount from the transmission because of the smaller turbo.
mikepaul21 is offline   Reply With Quote
Old 10-07-2014, 05:03 PM   #587
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
GT30 FTW!
Darryljr11 is offline   Reply With Quote
Old 10-14-2014, 09:57 PM   #588
bjun
bjun's Avatar
Drives: white premium brz M/T
Sorry guys quick question, I've been busy lately so I haven't had time to catch up on things.
So I got my oil cooler few days ago, has the headers been shipped out too?
bjun is offline   Reply With Quote
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
