Old 09-29-2014, 09:54 AM   #1
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
RE-11's falling off after being heated up?
Has anyone running Bridgestone RE-11's had any experience with the grip falling off when they get really hot?
Ran my first AutoX event after installing them yesterday and I did two heats of 5 runs. In each heat, my 5th run was without a doubt my sloppiest run. Wondering if it's the tires getting hot or if it's me psyching myself out because it's the last run and I wanna be fast.
Anyone?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 09-29-2014, 10:39 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Anyone?
what are your pressures?
what are the ambient temperatures?
how do you drive? do you have video of your runs from inside the car?
in my experience, over-inflated RE11's, driven hard, do in fact overheat quite quickly.
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
FRSToyota86 (10-06-2014), wparsons (09-29-2014)
Old 09-29-2014, 10:59 AM   #3
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Anyone?
I'm running 245/40/17 RE-11A's at 38psi hot and haven't experienced any loss of grip in 30 minute track sessions in 80-90 degree ambient temperatures.
The RE-11A is supposed to be a softer, more auto-x/track friendly compound than the RE-11 though.
From TireRack: http://blog.tirerack.com/blog/motors...-11-and-re-11a
The main change in the design is a compound difference that allows for slightly higher grip limits
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
CSG Mike (09-29-2014), wparsons (09-29-2014)
Old 09-29-2014, 11:38 AM   #4
wparsons
wparsons's Avatar
If you're doing 5 runs back to back, you're probably ending up with much higher pressures than you want by the 4th and 5th run.
flickr
Old 09-29-2014, 11:41 AM   #5
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Probably need to bleed the pressures and spray the tires and then see how they feel.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-29-2014, 12:32 PM   #6
Silver Ignition
APEXHNTR
I was checking and adjusting pressures after each run. I started out with regular street pressures; 35-36psi and ended up dropping all the way down to 25 in the driver's front and 28 passenger rear. Even with pressures this low I wasn't folding the sidewalls, and could even probably go another few pounds lower.
Ambient temps were between 78 and 83*F but as stated, I was checking tire pressures between each run.
My next event I will add tire temp to the data I collect. When taking temps on tires, is tread surface the best spot?
#1867 of 2500
Old 09-29-2014, 12:35 PM   #7
vroom4
Try something more like 32 front 30 rear. Spray as soon as they are anything more than 'warm' to the touch on a hot day. On a cold day I will wait till they are hot to the touch.
vroom4 is offline   Reply With Quote
Old 09-29-2014, 03:42 PM   #8
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Buy a 1 gallon garden pressure sprayer, fill it with water, and start spraying after your first or second runs to keep the tires cool.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 09-29-2014, 05:09 PM   #9
wparsons
wparsons's Avatar
It's funny that people have a hard time keeping tires cool enough in autox, up here most local autox's have enough wait between runs you have to make sure the engine is warmed up!
flickr
Old 09-29-2014, 06:07 PM   #10
Miniata
I've had autocrosses with co-drivers where we couldn't cool down the tires enough (Dunlop Star Specs), even with a 2 gallon sprayer full of cold water.
Old 09-29-2014, 09:01 PM   #11
wparsons
wparsons's Avatar
I'd probably be more into autox if it were like that here, I get bored (ADD much?) waiting 45-60 minutes between runs.
flickr
rs999 (10-10-2014)
Old 09-29-2014, 09:21 PM   #12
Dezoris
Dezoris's Avatar
I had these tires on my last car, within a week it was clear they were horrible for track and street. They cannot handle heat. One of the few tires I regretted blowing money on.
Old 09-29-2014, 10:36 PM   #13
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
No. See: http://www.longacreracing.com/techni...sus%20Infrared
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Silver Ignition (09-30-2014)
Old 09-30-2014, 09:17 AM   #14
Silver Ignition
APEXHNTR
I would never go if it was 45-60 minutes between runs...up here I'm lucky if I have enough time to adjust tire pressures between runs and even then I'm being rushed
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
wparsons (09-30-2014)
DIY – OEM Heated Seats @Art_Mighty DIY (Do-It-Yourself) Guides 22 12-30-2020 05:38 AM
Another Homelink mirror is loose\falling off\rattling thread B-R-Z Issues | Warranty | Recalls / TSB 9 09-21-2016 01:46 PM
8 Car Brands Falling Behind.....Scion on the list suaveflooder Scion FR-S / Toyota 86 GT86 General Forum 176 02-05-2016 08:21 AM
Wobble, falling apart, loose joints? imravenit Issues | Warranty | Recalls / TSB 25 03-29-2015 10:02 PM
The ride of the falling leaves trueno86power Other Vehicles & General Automotive Discussions 0 10-20-2011 06:45 PM
