Old 09-28-2014, 02:40 PM   #57
noob and expert
Drives: None :(
Originally Posted by Dezoris View Post
The AP kit is probably the most tested on the Forums from track users. Its pretty consistent in terms of performance and it definately responds best with the same pad compound at all four corners like oem.
I dont think anyone has had issues with bias. But one thing that the drivers of my car dont like is that the brakes are very very firm like on and off switch hard to modulate with agressive pad compounds.
Does that on/off effect have anything to do with the temperature? From what I understand it gets really cold sometimes up where you live but I live in Florida. And since these discs are bigger, we can't just go get pads that fit an frs right? They have to be a different size?
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 09-28-2014, 03:21 PM   #58
Dezoris
Dezoris's Avatar
No you have to get pads for the CP8350 AP Calipers which is very common. And then same pads for rear oem size.
The Following User Says Thank You to Dezoris For This Useful Post:
??? (09-29-2014)
Old 09-28-2014, 03:23 PM   #59
noob and expert
Drives: None :(
Thanks
Old 09-29-2014, 12:09 AM   #60
CSG Mike
CSG Mike's Avatar
@??? the kit will not mess with bias unless you inappropriately select pads and alter it yourself.
??? (09-29-2014), Stumpygt86 (09-29-2014)
SARD Racing Japan seat cover install & review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 136 09-22-2017 04:58 PM
Cool install Kido RAcing Coilovers/Brake kit on FT86,10%off.. Tubano-shop Brakes, Suspension, Chassis 0 06-04-2013 11:53 PM
Essex Sprint brake kit--Strano Performance will be carrying them... Sam Strano Brakes, Suspension, Chassis 13 10-08-2012 01:47 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
