Old 09-11-2014, 12:16 PM   #15
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Originally Posted by FRS-Learner View Post
Can this app pick up oil temperature from the ELM327 device?
It should. We have all the info set the PID here:
http://www.ft86club.com/forums/showp...00&postcount=2
1. OBD Header: 7E0 or 0
2. PID: 2101
3. Formula: AC-40
4. Minimum Value: -40
5. Maximum Value: 215
6. Descrpition: Oil Temp
7. Unit type: C
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
runnerAZ (12-03-2014)
Old 09-11-2014, 12:26 PM   #16
TIE Pilot
TIE Pilot's Avatar
Post How to input custom PID in App?
Old 09-12-2014, 03:14 AM   #17
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Anyone know the custom PID to read air/fuel ratio?
Darryljr11 is offline   Reply With Quote
Old 09-14-2014, 03:34 PM   #18
Creole
Creole's Avatar
Drives: Monogram FRS
Every time I try to connect I get this message. I've tried changing the IP address and it still doesn't work lol
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
Old 09-26-2014, 02:18 PM   #19
runnerAZ
Drives: suv
configuration
Originally Posted by Creole View Post
Attachment 90847
Your adapter should work. Did you select OBDWIFI or CLKDevices from your WIFI settings?
runnerAZ is offline   Reply With Quote
Old 09-26-2014, 02:34 PM   #20
runnerAZ
Drives: suv
Pid for AFR
It is included in EngineLink app. Long press on custom page to create gauge and load pid from standard pid file. I believe the pids are 0144 and 0134.
Old 09-26-2014, 04:00 PM   #21
Creole
Creole's Avatar
I selected OBDWIFI. I don't get a CLKDevices when I have the obd adapter plugged in
Build Thread:
Creoles Creation
Old 09-29-2014, 10:54 PM   #22
runnerAZ
Drives: suv
configure
OBDWIFI is fine. Make sure that the IP address within OBDWIFI setting and the ip on connect page of EngineLink are not the same.
Old 09-29-2014, 11:05 PM   #23
Creole
Creole's Avatar
PM'd
Old 10-08-2014, 02:14 PM   #24
runnerAZ
Drives: suv
Worked. Thanks a lot.
Old 12-03-2014, 06:19 PM   #25
runnerAZ
Drives: suv
There are many kinds of gauges to choose, i like the new average gauge the most. It displays both instant and average data.
Old 12-04-2014, 11:09 PM   #26
runnerAZ
Drives: suv
Screens for emission test and 0-60 timer (see how fast my car is)
Old 01-14-2015, 06:45 PM   #27
runnerAZ
Drives: suv
Fire Theme
Gauge theme with user configurable text colors and gauge skins.
OEM end link with coilovers bad? 86socal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-30-2014 10:16 PM
Rear toe link and toe changes Suberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-30-2014 06:49 AM
Suspension Weak Link? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-17-2013 01:12 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
