Old 09-23-2014, 04:46 PM   #337
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
accept my request on instagraaaaaaammmmmmm
I'm RoadconePhoto
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline
Old 09-25-2014, 11:37 AM   #338
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Finally installed my Race upgrade. Cutting the grille is required on the FRS, but our grill is cheap and easy to replace, so if you're looking for this splitter/upgrade, don't fret. It can be done with less material removed than I did, but I wanted more clearance, just bc. I messed up on the right side (passenger), so the hole is super huge. Very nice, and extremely sturdy now.
Review, I've only had the opportunity to play around a little since installing it. I've had it to 115mph, and it was hardly an issue, but it wasn't before either. I took it into some low speed turns, and it's more noticeable now as well. Honestly, the car can get a little loose coming out of turns because it seems that the front bites that much harder now. Still very very happy with the @Wonderbar Driveway Labs V1 diffuser and the @FT-86 SpeedFactory @eric6 @plucas race upgraded splitter.
Kwaziekeller is offline
Old 09-25-2014, 06:03 PM   #339
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Need to get you some real tires on there to help with those corners.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline
Old 09-25-2014, 09:22 PM   #340
noob and expert
Drives: None :(
can it be mounted a little further in and still work? it sticks out just a little too much for my taste. also, is the rexspeed carbon lip kit functional?
??? is offline
Old 09-25-2014, 10:16 PM   #341
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Less area (mounted further rearward) will result in a decrease amount of downforce, but yes it will still work. We are finishing up a custom splitter for a member here, and while it has been a learning experience, after tomorrow I should be able to accurately quote lead times and cost for custom, one off splitters. To clarify, the custom splitter will be more expensive then the standard splitter.
Thanks,
Eric
eric6 is offline
Old 09-26-2014, 08:37 AM   #342
Roadcone
StreetKart
its hard to tell how much you trimmed the grill. i got my race upgrade in the mail yesterday but its going to have to wait a little while before it gets installed.
also, throw some sticky tires on the car and you'll wonder why that wasnt your first mod lol
Roadcone is offline
Old 09-26-2014, 10:22 AM   #343
Kwaziekeller
Oh I'm well aware that the Primacys are not exactly high grip/sticky tires. It will probably be spring before I go with something else, just gonna wear these out first. I'm debating wider wheels and tires, but I'll probably go with Michelin Pilot Super Sports once these are worn out.
Old 09-26-2014, 10:30 AM   #344
Kwaziekeller
Here are some better pics of the modifications I made to the grille. It can be done removing less material, but I wasn't worried about it. My blunder on the passenger side is quite evident. I had the bracket held up to the middle 2 holes when I was eyeballing what section to cut out.
Old 09-26-2014, 10:52 AM   #345
noob and expert
Drives: None :(
Thanks,
Eric
Thanks, and does anyone know if the rexspeed kit is functional? Also, I saw a front bumper and a front lip available from apr. How does the modified bumper compare to the apr lip spoiler? Can both be used?
Thanks
For me, there is no glide in pulse and glide :p
??? is offline
Old 09-26-2014, 11:03 AM   #346
gramicci101
Off Topic
@Kwaziekeller, would it be possible to get a straight-on side shot that shows both the splitter and the diffuser? Thanks.
gramicci101 is offline
Old 09-26-2014, 11:15 AM   #347
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Size:  63.9 KBName:  uploadfromtaptalk1411744492920.jpg
Size:  52.6 KBName:  uploadfromtaptalk1411744517073.jpg
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 09-26-2014, 11:15 AM   #348
zdr93523
zdr93523's Avatar
I have no idea why my phone double posts pics. Any ideas?
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 09-26-2014, 11:24 AM   #349
Roadcone
StreetKart
lol at the blunder... i'm considering cutting the entire grill out and just leaving the upper bar. i might get lucky and be able to to install the race kit after lunch tomorrow.
Roadcone is offline
Old 09-26-2014, 11:27 AM   #350
Model Citizen
Lacking brains
Drives: frz
so many uncropped pics of rear end in a front splitter thread.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 06:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 03:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
