Old 09-24-2014, 10:49 AM   #1
MAPerformance
Drives: Asphalt FRS
GSC FA20 Intake/Exhaust Valves
With the recent release of their valve spring kits for the FA20, they have now released both intake and SuperAlloy exhaust valves. These will only work on the 2013's since the 2014's have longer valve stems and will be released soon. These are a higher flowing valve then OEM with better materials to help prevent valve distortion at the face. Less distortion allows for better sealing under extreme conditions and more consistent performance. Chrome polished, one piece stems, and swirl polished heads that avoid any flaking off of the valve head under extreme heat.
Super Alloy exhaust valves:
Head size (mm) 29 and 30 available
Total length (mm) 95.15
Intake valves
Head size (mm) 35 and 36 available
Total length (mm) 103.25
PM me for pricing
MAPerformance is offline   Reply With Quote
Old 09-24-2014, 06:47 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Anyone know the motivation for the change in valve heights from '13 to '14?
Old 09-25-2014, 09:38 AM   #3
Calum
That Guy
Intake valves
PM me for pricing
Do you know what the difference in length is or if it's possible to update to the new valves? Was anything else changed in the head?
Old 09-25-2014, 09:46 AM   #4
MAPerformance
Drives: Asphalt FRS
Unfortunately I don't know the size difference yet. I can try to reach out to GSC to try and get some more detail.
Old 09-25-2014, 10:30 AM   #5
sato
sato's Avatar
Drives: Dodge Patitas
No pics?
sato is offline   Reply With Quote
Old 09-25-2014, 12:40 PM   #6
MAPerformance
Drives: Asphalt FRS
Sorry, they have not been released yet
Originally Posted by sato View Post
No pics?
Old 09-25-2014, 01:43 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its quite possible they decided a longer stem would support stiffer springs, hinting at those who boost the motor wont have to worry about it? Thats my best guess.
Old 09-25-2014, 03:45 PM   #8
Calum
That Guy
It could also put the rocker at a different angle making it harder or easier to dislodge at high rpm.
Old 09-25-2014, 05:29 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What year is Phil's 86?
Old 09-26-2014, 07:12 AM   #10
Calum
That Guy
Phil's failure was due to the pin coming out. But that's exactly the line of thinking I was on. I don't know the answer to your question though.
The Following User Says Thank You to Calum For This Useful Post:
cdrazic93 (09-26-2014)
Old 09-18-2019, 01:11 AM   #11
chewbacca
Drives: Frs-t
The rocker arms. The 2014 rockers "dome" or where the hydraulic lifter seats, it seats deeper into the rocker.
Thats about from 4.74mm versus 5.31mm plus/minus.
If these are fitted in a 2013 the clearances will be too great to buy them, find them at subaru. After calculating the shim, it came to a 3.45mm or so to flll in. And then the shaftcams.
The shaftcams on 2014 has to have either taller heel on the camshaft lobes to add additional material to fill the space between the roller and the camshaft lobe and set the clearances. The 2013 lobe from nose to heel is about 40.31mm plus/minus.
For now im retuning the rocker arms and shim with the rockers i have.
So if the lenght of the valve stem is not enough then the camshaft lobe might be slightly taller. If the lenght is enough then a slight variation in timig is in question, however, i place the chance that is a taller lobe and not timing. As the rest timing chain, timing gear sprockets are the same. In addition to this, the cariers, and lifters fits on and are same too.
That i'm aware if there is a valve train kit and a dual spring kit for 2014 is a harder one to get. At least from the search. Now for the 2013 there are a couple of options available, easier. At least from what it seems.
Photos couldn't be uploaded
chewbacca is offline   Reply With Quote
The Following User Says Thank You to chewbacca For This Useful Post:
Calum (09-19-2019)
Old 09-18-2019, 06:23 AM   #12
solidsnake11
Drives: brz
The difference is the valve length and the rocker. I switched one of my heads from short to long. One more thing, the extra length is past the keeper towards the rocker. Not so sure why they have two different valve spring kits.
solidsnake11 is offline   Reply With Quote
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post:
Calum (09-19-2019), Lantanafrs2 (09-18-2019)
Old 09-18-2019, 11:38 AM   #13
Lantanafrs2
Drives: 2013 frs red
So the goal was to get them riding deeper in the rocker?
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Calum (09-19-2019)
Old 09-18-2019, 03:19 PM   #14
solidsnake11
Drives: brz
I think both the pivot and the valve are deeper.
The Following User Says Thank You to solidsnake11 For This Useful Post:
Calum (09-19-2019)
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 04:24 AM
Carbon build up around intake valves? csaba Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 57 01-13-2015 09:39 AM
exhaust valves? aznatama Engine, Exhaust, Transmission 16 09-14-2014 09:39 PM
FA20 turbo exhaust setup. Baramzisyan Engine, Exhaust, Transmission 26 02-20-2014 07:58 AM
Can an NA FA20 produce exhaust burble/pop? FR-Slide Engine, Exhaust, Transmission 27 08-16-2013 12:38 PM
