Old 09-24-2014, 05:37 PM   #1
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
The "Evasive 86" Nostril Mod
First and foremost, I take no credit to this mod. This mod is taken from @Evasive Motorsports , spotted it on their Time-Attack 86 and knew it had to be done.
Quick history going back, I've been wanting to modify the front bumper for quite some time. My options went from the Garage Vary intake duct, to the Rasty Front Bumper E-Duct (sadly discontinued), to even the Tsukinousagi infamous "5-Hole" mod. I kept looking not being completely 100% satisfied with either. Scouring through the Interwebs of things and alike, I stumbled upon @Evasive Motorsports 's Time-Attack 86. The ducts they made are something I've never seen, the cuts and shape all were symmetrical to the body of the Twins. I had to have it...and here is my journey.
The inspiration...
Template Creation
Made a template by first laying down some wax paper over the front bumper. I traced out the lines of the body, emblem, and headlight using a level. The Evasive looked a bit lower and followed the lines of the bottom of the emblem -- I eyed it to see what would look best. I picked up at 2" stick of wood from Home Depot with a 2" washer to make the rounded edge. I placed the washer onto one end, made sure it was even all-around and traced a half-circle onto the stick.
For the other end, I dont know the exact angle I used on the side closest to the emblem. Again this was eyed based on the indentation. Key note, I wanted zero edges, so everything is rounded out to flow better with the body.
Once everything was traced, I cut away using a dremel and my Bostitch box-cutter.
Test Fit
Used painter's tape to attach it to my bumper. Lined it up where I thought it was good, then traced around the template using a marking crayon.
Cutting
Nerve-wrecking. Completely nerve-wrecking. I researched online to see what people have done for cutting into bumpers. Some say use a dremel, some say dremels melt paint, some said to use an exacto knife, some said to use box-cutters....BOX-CUTTERS? Really? Figuring the bumper was pliable enough, so why not? I sat in front of my bumper staring at the template thinking whether this was a good idea or not. It was a "f*ck it" moment that got me going, and I started along the bottom first incase I messed up. One guy said he nearly took his finger off because his slipped. So words of advice, TAKE YOUR TIME, GO SLOW. It's going to take a lot of pressure to get the blade through
Cut!
Still have all of my fingers...You're going to need to twist the handle/blade going around the round parts. Make sure to keep going and don't pull out, otherwise you're going to get small bumps of paint like I did. If you cut, keep cutting.
Clean-Up
Used some small filers to clean up the cuts. The cuts weren't perfect, it's a little uneven here and there, but I think it came out okay since this was a first-time thing.
All Done
In Closing...
The cutout on the driver side has a direct feed to the intake snorkel. I can literally see the my air filter if I look through the cutout and that's because I cut-away most of the factory snorkel.
The cutout isn't big enough for me to even fit my hand through, so risk of theft isn't all there. I do worry about rain and other objects getting into the ducts. Slim chances I'll find a dead rat wedged there, though water can probably hit the filter if I'm speeding when it's pouring (also slim chances, living in California). I will though, have to tape off the duct during long drives infested with flying bugs, like highway 5.
I'm reserving any mods to deflect water and other objects away based on whether I get either the Skunk2 Powerbox or Grimmspeed intake. The Skunk2 has it's own snorkel, and the Grimmspeed is too early still to tell what it'll use. Otherwise, I'll tack a gutter guard behind it with some liquid nails...who knows.
Feedback is welcome, hate it or love it -- please let me know!
Update:
Double Nostrils
Door Trim Applied
Close-up
Updated Double-Nostril
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 09-24-2014, 05:56 PM   #2
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Not a bad idea. You should try to clean up the edges and put some sort of mesh/screen in there. Then it'll look legit.
FReSh is offline   Reply With Quote
Old 09-24-2014, 06:41 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hmm, I've been waiting for someone to come out with cf insert similar to what you have there.
Old 09-24-2014, 06:53 PM   #4
gramicci101
Off Topic
Get some fiberglass and put a round profile on the inside of the cut so it doesn't just look like a cut edge, it looks like a professional scoop. Might also help to smooth turbulent airflow.
It looks very good though. You had an even hand with that exacto knife.
Old 09-24-2014, 06:53 PM   #5
ck-GT86
ck-GT86's Avatar
Lightbulb! I can research to see what it'd take to make a mould. What are you thinking, making the duct dump directly into the intake box like the Garage Vary one, or an insert that fits into the bumper.
.ck
|| My Build Thread ||
Old 09-24-2014, 07:01 PM   #6
gramicci101
Off Topic
You could make a duct that ties into the OEM snorkel for the driver's side. The passenger side could just be additional air on the radiator.
Old 09-24-2014, 07:14 PM   #7
raven1231
.ck
https://www.google.com/search?q=350z...27%3B750%3B498
Old 09-24-2014, 07:15 PM   #8
raven1231
Same here
Old 09-24-2014, 07:18 PM   #9
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Very ballsy but very awesome you did it! I actually really love the headlights on the evasive car
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-24-2014, 07:36 PM   #10
continuecrushing
.ck
Same here
yup, like EXACTLY this. http://www.modbargains.com/Carbon-Fi...issan-350Z.htm
I've even played with buying one(for another car) and trying to make it work with ours.
Old 09-24-2014, 07:42 PM   #11
themajesticone
themajesticone's Avatar
Drives: '13 UM86
http://www.bellplastics.com/
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 09-24-2014, 07:47 PM   #12
ck-GT86
ck-GT86's Avatar
I did the same! R33 and R35 GTR's have big square ducts, and the 350/370Z platform only had 1 that I liked. All of which were $$$$
Thanks for the links everyone, I'll see what I can do on getting a cheaper mould, maybe made in CF too
.ck
|| My Build Thread ||
Old 09-24-2014, 07:55 PM   #13
raven1231
Had them on my 350z with the pop charger and loved it
Old 09-24-2014, 08:06 PM   #14
s2d4
s2d4's Avatar
.ck
evasive motorsports, intake, intake duct, nostrils
Happy 8/6 Day Video From Evasive Motorsports "Every Second Counts" Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 09-05-2013 09:14 PM
Happy 8/6 Day Video From Evasive Motorsports "Every Second Counts" Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 11 08-16-2013 01:49 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Happy 8/6 Day Video From Evasive Motorsports "Every Second Counts" Evasive Motorsports Southern California 2 08-07-2013 03:40 PM
