Old 09-22-2014, 12:40 AM   #1051
Astroboy
Astroboy's Avatar
Drives: None
Anybody else on here running a radium catch can? And is a second catch can really needed for the outlet connecting back to the front intake for this turbo kit?
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
CxG (06-25-2016)
Old 09-22-2014, 02:37 PM   #1052
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Musickmixxer90 View Post
I guess that makes sense. Just out of curiosity, how much was that Sti conversion?
And what pads did you go with? Is that your dd also?
I did the same thing as some others, STI brembos, rotors, pads and SS lines. however I only upgraded the front brakes, the rear got SS lines and that is it.
Old 09-23-2014, 03:00 PM   #1053
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I just recieved the 3" turbo to catback exhaust bits from AVO today.
I'm very pleased with the build quality. Nice clean welds!
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 3 Users Say Thank You to protpibe For This Useful Post:
Draco_PR23 (09-24-2014), MFB (09-27-2014), OICU812 (09-25-2014)
Old 09-24-2014, 12:53 AM   #1054
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Well.. My avo stage1 kit has performed 100% well for the past 10k miles. It's up for sale now as I got sponsored for a top mount kit. I decided to build my car for show and top mount looks better.
Here's the for sale thread.
http://www.ft86club.com/forums/showthread.php?t=74750
h4nh is offline   Reply With Quote
The Following User Says Thank You to h4nh For This Useful Post:
SkAsphalt (09-26-2014)
Old 09-24-2014, 02:14 AM   #1055
Pete156
I like to eat!
Just a question, did you guys who are running at 8+ psi upgrade your brakes? and if so, what did you do? I've read for DDs pads and SS lines are okay, but I;m wondering for spirited drives that last for around 30 mins. Would this still be okay? or should I fork over mulah for BBKs?
I spent less than $1K, went with Stop Techs SS lines, slotted rotors and pads (all 4 wheels), and replaced the fluid with some good stuff. Car stops much better without the cost of a BBK.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
Old 09-24-2014, 07:13 PM   #1056
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
[ame]http://youtu.be/SvaPKsWnvcQ[/ame] vid of my progress
brz2013 is offline   Reply With Quote
The Following User Says Thank You to brz2013 For This Useful Post:
mwjcyber (09-27-2014)
Old 09-25-2014, 02:35 AM   #1057
JD86
Drives: 2013 Toyota 86 GT
I'm running the dual radium catch cans... and the AVO air/oil separator off the oil reservoir.
As to what's needed... it's debateable and comes down to personal prefernce. I chose both as I get a hell of a lot of blow by. I was filling up the massive AVO front mount catch can about every three months.
JD86 is offline   Reply With Quote
The Following User Says Thank You to JD86 For This Useful Post:
CxG (06-25-2016)
Old 09-25-2014, 02:55 AM   #1058
JD86
Third AVO turbo?!?
For those that haven't seen it yet, it appears AVO is testing a third turbo for our car on their Japanese vehicle. No word on power figures etc yet but it's larger than the stage 3 billet option and my japanese is rusty but something about forged compressor housing?
BRZターボ車両をチョイとモデファイします
タービン交換してみます
コンプレッサハウジングも鍛造品
The Following 3 Users Say Thank You to JD86 For This Useful Post:
CxG (06-25-2016), DesertFrs (12-08-2014), SkAsphalt (09-26-2014)
Old 09-25-2014, 03:04 AM   #1059
protpibe
protpibe's Avatar
I think that's overkill in my opinion. I doubt much, if anything, comes out of that oil reservoir breather. I'm pretty sure it's just to balance pressure inside the crank case with that overflow tank. The scavenging pump would be sucking all of the oil up out of there before it went through the vent hose.
I'm running a custom setup from Saikou Michi. I had the PCV side isolated on it's own tank, then had a second tank made up with two inlets (one for the crank breather and the other for the turbo reservoir vent). I also got some custom vent hard lines to run to the tanks to clean everything up. Works perfectly.
Old 09-25-2014, 08:32 AM   #1060
Raven604
http://shopping.kinugawaturbo.com/tu...1-1-1-1-1.aspx
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
The Following User Says Thank You to Raven604 For This Useful Post:
gdrider77 (09-26-2014)
Old 09-26-2014, 03:47 AM   #1061
Astroboy
Astroboy's Avatar
Drives: None
Will it be ok to just run a single radium catch can and to have the oil reservoir just vented to the atmosphere?
Old 09-26-2014, 05:17 AM   #1062
TimDing
TimDing's Avatar
Drives: Storm Black Manual 86GTS
Did anyone have to make changes to the plastic bumper bit after installing? I can't seem to get my bumper back on after installing. I am assuming that is what is blocking it. I cut a strip off from it but no joy, I think it has pushed it down too far.
Cheers.
TimDing is offline   Reply With Quote
Old 09-26-2014, 12:20 PM   #1063
GremlinGSP
I had to do some modifications to the black piece that goes under the the intercooler. I trimmed down the area with the grid. I probably wouldn't do that again. I'd be more likely to play with the intercooler and crash beam first.
GremlinGSP is offline   Reply With Quote
Old 09-27-2014, 12:40 AM   #1064
Pete156
I like to eat!
Subscribed, but hard to believe half the shit I hear. My AVO setup is working flawlessly! No complaints! No turbo failures! No overheating! No boost leaks! no issues whatsoever!
Everyone should get one of these kits. It's as if they're OEM! And the car responds accordingly!
I am happy as a pig in shit!
CxG (06-25-2016)
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
