Old 09-23-2014, 08:41 PM   #2003
randomthoughts
Drives: 2014 White BRZ
Originally Posted by Walla Walla View Post
i always use shell 91 (im in quebec)
last week, i was at toronto, and i tried petro 94..... wow... that gave an insane amount of cricket.... once back in quebec, i've took shell 91 again, and the sound is gone... i would suggest you to try both and see the results for yourself!
I have experimented with Petro 91 and Shell 91. I have no crickets on Shell 91 but they return when switching back to Petro 91.
Once I get my OFT I will experiment with Stage 1 tune and different fuels.
What are the Stage 1 tune options, 91 and 93? Is there a 94 tune or just use 94 with the 93 tune?
randomthoughts is offline   Reply With Quote
Old 09-23-2014, 09:07 PM   #2004
steve99
Drives: FT86
Crickets generally caused by 10% ethanol fuels, its annoying but does not appear to be harmful.
E85 fuels have some additives that generally supress crickets
Always run a fuel of equal or higher octane rating than the tune is designed for.
91 tune for 91 and higher octane (slightly reduced power compared to 93 tune maybe 3-4 hp due 1 degree less ignition advance top end)
93 tune for 93 octane and higher fuels
E85 tunes for E85 fuels only.
Old 09-23-2014, 11:37 PM   #2005
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
and i would suggest 93 tune only with 94 octane in canada... as i had knock on 91 tune with 91 gas. (on high rpm, 6000+ with Stage 2 bpb) seems like our gas is not the best...
Walla Walla is offline   Reply With Quote
Old 09-24-2014, 01:51 PM   #2006
RFB
RFB's Avatar
Drives: FRS
I will be purchasing an OFT shortly and not sure if I should be using Shell 91 or Petro 94. Just wondering what others from Toronto area are using with OTF on a stock car. I know Perto 94 has 10 ethanol.
Most of our OFT 2 cars are using Petro and corn juice 93 - seems smoother and more powerful . I tried OFT 2 and Shell 91 with Torco bringing it up to 94 and it seemed powerful but not as smooth as the Pierre Elliot Trudeau Ripped Off Canada corn liquor gas.
For stage 1, Shell 91.
I plan to test stage 2 with Shell no corn juice 91 with 1 gal. of race gas per tank to bring it up to 94 and see wha hoppen.
CERBERUS
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Triumphrider (09-24-2014)
Old 09-25-2014, 06:35 AM   #2007
Stumpygt86
Drives: Toyota GT86. N/A for life
Quick question,
I have downloaded the bin files for my car with the correct calid (from the OFT web site, OTS v2.061 [Stg1 A00G]). Where do I look to see if they are 91 or 93 oct tunes.
I am from Australia and I believe we should be using the 91 oct tune for our fabulous 98 we have here.
I cannot seem to find.
What am I missing
And are people still using TunerPro or have you all gone to RomRaider
Cheers,
Jeff
Stumpygt86 is offline   Reply With Quote
Old 09-25-2014, 06:43 AM   #2008
Stumpygt86
Sorry, think I have just answered my own question.
Old 09-25-2014, 07:04 AM   #2009
steve99
Drives: FT86
Originally Posted by Stumpygt86 View Post
Quick question,
What am I missing
Cheers,
Jeff
correct due to our fuel we only get the 91 version.
Stumpygt86 (09-25-2014)
Old 09-27-2014, 09:20 PM   #2010
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
i have some quick questions. I have ecutek on my car already, been thinking about getting an open flash tablet so that i can do my own tunes and learn and i don't have to wait for a tune update when i do mods. Quick questions, does open flash support flex fuel yet? Do i have to have ecutek erased from my ecu to use open flash? or does the ecu just need to be reverted back to stock rom?
brichard0625 is offline   Reply With Quote
Old 09-28-2014, 03:36 AM   #2011
steve99
Drives: FT86
OFT does not have flex fuel option yet. to run E85 (tune copes with 60% to 90% E blends.) you have to flash E85 tune, to revert to petrol flash petrol tune. unfortunately no tune switching yet either.
You will have to flash back your "stock "ecutek" rom to the ecu so its not locked or encrypted and no longer contains a "multiswitchable race rom tune".
Unfortunatly Ecutek "stock" tunes are not 100% stock they contain some licience info embedded in the rom. this is not a problem for the OFT, but its possible you may loose your ecutek licience. if you write over this information in the rom.
however the OFT does store a copy of the "stock rom" when you marry up oft to your car so theroeticly when you unmarry the OFT your stock ecutek rom will be reritten to car and you can use ecuteck again.
Just flash your "stock" ecutek rom back to car and you should be all good.
read the OFT Tips link below.
also confirm what I have said with the OFT guys they are very helpful.
Old 09-28-2014, 03:40 AM   #2012
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why not just use ECUtek if you have it already?
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-28-2014, 11:52 AM   #2013
brichard0625
thanx guys for the info. Any i have ecutek but i hate waiting for a tuner to have to update my car when i put new mods on it. And it can be costly going with a different tuner. i just rather learn and tune myself. Thanx for the info guys
The Following User Says Thank You to brichard0625 For This Useful Post:
Triumphrider (09-28-2014)
Old 09-28-2014, 06:17 PM   #2014
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why not DIY on ECUtek? If you have a cable you have all you need....
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-28-2014, 10:35 PM   #2015
s2d4
s2d4's Avatar
Visconti ftw!
Old 09-29-2014, 05:05 AM   #2016
steve99
Drives: FT86
yes it would work always an option.
the oft guys give you $100 discount if you have ecutek already prety good deal for a backup portable device.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
