Old 07-01-2014, 12:20 PM   #113
celek
Resident Gear Head
celek's Avatar
Originally Posted by AlphaMotorsports.ca View Post
Excited to see this build come to life. Sub'ing.
Will you be running a dry sump oiling system or do you plan on making modifications to the factory Oil pump to accommodate 10K+ rpm.
Yes I will be sending the oil pump to Accelerated Performance for a little work
celek is offline   Reply With Quote
Old 07-01-2014, 12:22 PM   #114
celek
Resident Gear Head
celek's Avatar
Something came back from California yesterday
Old 07-01-2014, 03:02 PM   #115
BadBRZ
Drives: Subaru
89.5 bore, and the ej25 crank right. What compression?!? 13.5:1?!?
BadBRZ is offline   Reply With Quote
Old 07-01-2014, 03:02 PM   #116
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I love NA builds (used to have an NA EG back in the day). I didn't read word for word this entire thread ..but I think you're destroking it or decreasing displacement or something, and making it a highly tuned, high rev monster?
Anyways...why not just do a crate LS3 swap? It'll be NA, 400+whp that is oem factory built and reliable and bulletproof. And also similar in weight of a stock FA. I bet it would be a lot cheaper too than getting a custom fully built NA FA engine..not to mention there's going to be countless hours of tuning and troubleshooting afterwards to get that NA FA working at its' best.
fooddude is offline   Reply With Quote
Old 07-01-2014, 03:04 PM   #117
celek
Resident Gear Head
celek's Avatar
FB25, the EJ does not support timing chains and has a smaller stroke larger bore
Old 07-01-2014, 03:05 PM   #118
celek
Resident Gear Head
celek's Avatar
Increasing stroke and bore.
Why LS3? its been done, too many times. and it raises the center of gravity of the car and handeling
Old 07-01-2014, 03:11 PM   #119
fooddude
True and true.. never liked the idea of ruining the car's true form and balance/cog either...and also kinda don't like the idea of sticking a domestic engine in it.
So what's the final displacement of your engine after your bore and stroke? 2.5?
Whats your final comp ratio goals? ...I am actually still pretty amazed at the stock FA's CR... I remember in the 90s, a 12.5:1 CR was already considered crazy insane high.
What are your plans with the upper block? ...port&polish heads, cams, valvetrain parts, mill the head and/or block? ..and tune.
Any modified intake manifold tb, or itb's setup?
I wonder if Toda is doing an NA FA engine. Aren't they Japanese NA specialists?
Old 07-01-2014, 03:23 PM   #120
celek
Resident Gear Head
celek's Avatar
There are a few companies out there working on Valvetrain parts. This particular build is unexplored territory so all kind of unknown at the moment.
As for high compression the DI helps with that.
Old 07-25-2014, 08:54 PM   #121
A3r0pusH
A3r0pusH's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Any updates?
A3r0pusH is offline   Reply With Quote
Old 07-25-2014, 09:35 PM   #122
Fr-s.h
Drives: Golden White
Keep it up! Sleeved block FTW! Look forward to some nasty high reving action from your build. Best of luck overcoming hurdles and props for blazing the trail.
`13 Whiteout Fr-s.h
Fr-s.h is offline   Reply With Quote
Old 09-10-2014, 04:01 AM   #123
BadBRZ
Drives: Subaru
Herro?
Old 09-23-2014, 10:44 AM   #124
celek
Resident Gear Head
celek's Avatar
Currently sources of money are being spent on family trips and a trip to SEMA in November. Sorry for the slow build, like Rome it was not done in a day. Also paid off all existing credit cards
Old 09-23-2014, 12:42 PM   #125
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Computer guy here so crazy incoming question. Is it possible to put a K24 in this car?
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 09-23-2014, 12:55 PM   #126
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Anything is possible with the right amount of money..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
