Old 09-21-2014, 11:00 PM   #15
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Just buy a clean c6 Vette. Trust me on this one
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
BlackMonarch (09-26-2014)
Old 09-21-2014, 11:03 PM   #16
08stiguy
08stiguy's Avatar
Drives:
Will do! Thanks ✌️
08stiguy is offline   Reply With Quote
Old 09-22-2014, 07:10 AM   #17
AtlasMick
Drives: FR-S 2013 Asphalt
Do the swap. This guy ended up getting better weight front to rear ratio and less overall weight on the car with a LS and tran. swap.
http://www.vorshlag.com/forums/showthread.php?p=57906
AtlasMick is offline   Reply With Quote
Old 09-22-2014, 09:05 AM   #18
extrashaky
Drives: 2014 BRZ Limited
What about center of gravity? You can put 100 lbs on a 20 foot pole welded to the roof and have it perfectly centered front to rear and left to right, but it would still handle like shit.
Old 09-22-2014, 10:28 AM   #19
AtlasMick
Won't know until someone tries it. However, I believe people are getting over excited about it. The whole engine assembly might weigh a quarter of the car's whole weight. If the engine CoG is higher by 2 inches the whole cars might raise minimally. Combined with an inch drop on the car and you've solved your problem.
When you counter this with adding weight in front and up high in the engine bay a turbo, and then the rest of the supporting mods (intercooler, oil cooler, oil catch can, etc) of a turbo system to acheive the same HP or torque you are still are doing the same damage (read "if any") that a LS swap would.
So OP, please do it. and then maybe we can all chip in for you to take it CoG tested with the rest of the car completely stock?
Old 09-22-2014, 10:31 AM   #20
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Corvettes are heavier too, COG will change but that doesn't mean it will handle like shit. Example: miatas with ls swaps, there are a ton of track oriented ls miatas that do way quicker laps than a standard one. There are a ton of factors at play, it won't be as balanced but it won't turn the car in to a piece of shit necessarily. Damn this forum is full of hating ass people.
Readytoxplod is offline   Reply With Quote
Old 09-22-2014, 10:49 AM   #21
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
not sure how this hasnt been posted.....
http://shop.weaponsgradeperformance....rz-ls-swap-kit
Vides990 is offline   Reply With Quote
Old 09-22-2014, 11:01 AM   #22
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
"complete kit" = $8k. (add $5k for them to do install). I don't think the OP is looking to spend $8k just for the kit to put a 200k mile engine in his car.
What's the going rate for a slightly used FA20 and trans? I get the feeling that's his budget.
ashtray is offline   Reply With Quote
Old 09-22-2014, 11:05 AM   #23
Vides990
ummm, its still a complete list of the correct parts to make sure his swap works reliably, whether or not he buys the stuff from there.......budget build swaps are bad ideas anyways but thats a completely different topic.
Old 09-22-2014, 11:13 AM   #24
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
bama_brz (10-02-2014), inertia (10-07-2014)
Old 09-22-2014, 02:28 PM   #25
ashtray
I'd say better brakes, upgraded rear diff, possibly suspension changes along with wider tires should all be considered part of the list. This is like saying to build a house you need 2x4's, nails, and plywood. Oh, but the complete kit would contain roofing materials, carpet, and paint.
I'd have to imagine the actual complete list of parts alone on this engine swap would be over 100 items.
Don't get me wrong, these builds are completely doable and the end result (when starting with a good engine) would be show quality, with very impressive performance numbers. Problem is, as posted earlier, to do this right is about a $70k investment for something so unique that no shop would be able to troubleshoot a problem down the road sometime. It's a great idea for people in the car industry to build to show either the quality of the parts they make, competency of their shop, or as a specialty competition drift vehicle, etc. It's not the sort of build one does when their DD gets into an accident, and they have two spare vehicles to drive (BRZ and TA) that they then take out of commission for a few months in order to do an engine swap on a budget - equal to roughly the value of a used FA20. And not that people won't want an FA20, but with a plethora of EJ blocks out there in both 2.0 and 2.5l sized, with turbos, for cheap - who is looking to spend much more on an FA20 engine? (Not helping that it will likely come without the much needed ECU)
As a reference, I once had a V6 model vehicle and wished mine had the V8 option that was available. I spoke to a shop and they flat out said it would be easier and cheaper to just sell my car and find one with the factory V8 than to attempt a swap. The cost of the engine itself was minimal compared to the other costs to get it all to work and the amount of labor involved. I was 17 at the time and the used V8 engines were about $2k. Very naive I was.
Old 09-22-2014, 08:59 PM   #26
Vides990
Originally Posted by OmarGC View Post
I don't mean you have to go to a high end shop to have it done just that the right parts and equipment need to get used. It costs money to play and if you don't do it right the first time it just costs more down the road....cheap, fast, reliable, you only get two and if you want fast and reliable it costs $$$$$ something OP doesn't seem to have........there's nothing budget about your builds...lol
The Following User Says Thank You to Vides990 For This Useful Post:
OmarGC (09-22-2014)
Old 09-22-2014, 09:02 PM   #27
Vides990
I just meant the major assembly pieces.....though from reading your post I think you're saying the same thing and we agree.....
Old 09-22-2014, 09:16 PM   #28
extrashaky
Learn to read. I asked a question regarding the effect of the swap on the center of gravity. I didn't say it would make it handle like shit, only that a car could have "better" weight distribution than the twins and still handle like shit, because weight distribution is not the only factor at play. None of that means I'm "hating ass people."
Fuck me for asking a legitimate question.
Painted front mustache BRZ AR35 Cosmetic Modification (Interior/Exterior/Lighting) 57 08-26-2016 03:00 PM
BRZ carbon fiber mustache? Norcalmav23 Cosmetic Modification (Interior/Exterior/Lighting) 36 07-21-2015 02:02 PM
Replacing the BRZ mustache FrSnake Cosmetic Modification (Interior/Exterior/Lighting) 5 05-06-2014 01:15 AM
Mustache beagoodruslan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-16-2014 04:05 PM
I mustache you a question. Jive Turkey BRZ Photos, Videos, Wallpapers, Gallery Forum 5 10-14-2013 09:18 PM
