Old 04-30-2012, 02:30 AM   #29
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Scooby South View Post
-There is a dead spot from 3750 to 4250 RPM... it is the AVCS Crossover supposedly it CAN be tuned out...ALA Dual AVCS 08 STI...we'll see..Hopefully there will be a tuning company that can 'fix' this
Can someone explain this? Not sure what all this means.
Phaedrus29 is offline   Reply With Quote
Old 04-30-2012, 02:44 AM   #30
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by Ryephile View Post
Just my advice: you might want to wait until a proper LiFePo4 battery is fitted and marketed for the car before spending money on a short-term solution like an AGM battery.
Aren't those super expensive? Like over $1K? Is there a company/website you know of that makes good ones for cars?
Sure, you can change the cams to give it more power in that range but at what cost? If it were purely a win-win, don't you think Toyota/Subaru would have done that to begin with? And the DAVCS is continuously variable valve timing so I didn't think there is a crossover area. It's not like a two-stage lift VTEC or something.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-30-2012, 02:46 AM   #31
serialk11r
Drives: '06 AM V8V Coupe
Lithium batteries need different charging method or else they die faster...
Old 04-30-2012, 03:17 AM   #32
Lordharding
Drives: Subaru WRXd & classic turbo 2000
I'm still worried about seating position
I'm 6ft and like to sit upright
I assume some of you guys are my height or taller and fit in ok ?
Looks tight with the helmet on
Lordharding is offline   Reply With Quote
Old 04-30-2012, 10:34 AM   #33
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
At 5'11" with 31" inseam I found I had a good 3-4" above my head when the seat was about an inch above its bottom-most position, sitting reasonably upright. (I did not bottom the seat out because the wheel then blocked the gauges when it was set to my preferred position.)
Sport-Tech is offline   Reply With Quote
Old 04-30-2012, 10:42 AM   #34
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm 6'4" with a tall torso. I also like an upright seating position. With the seat moved all the way down I had maybe a couple inches between my head and the ceiling. Enough to get a helmet on. And I could compromise and lean the seat back a click or two to get more headroom.
Overall, I don't think you're going to have any problems.
Old 04-30-2012, 10:46 AM   #35
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by Bristecom View Post
Aren't those super expensive? Like over $1K?....
They can be expensive if they're vehicle-specific, however there are options out there for prices not too far away from premium lead-acid brands. Just wait and see what the vendors come up with.
You're thinking of Lithium Polymer, which isn't appropriate for automotive use. Lithium Iron Phosphate is what I'm talking about, and when designed correctly they're drop-in replacements with zero maintenance on a daily-driven car.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-30-2012, 11:33 AM   #36
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Yup. As hobbyists will tell you, even storing LiPo's in your car is a bad idea. Unless they're in one of my models currently in use they're sitting in an insulated fiberglass bag.
MmmHamSandwich is offline   Reply With Quote
The Following User Says Thank You to MmmHamSandwich For This Useful Post:
Ryephile (04-30-2012)
Old 04-30-2012, 01:53 PM   #37
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
You should be fine... I am almost 6'3"...and I can "make it" fit to my sit upright style...someone 6ft...should not have ANY problems at all.. and without the helmet I had NO Issues..
Bill
Scooby South is offline   Reply With Quote
Old 05-02-2012, 07:33 AM   #38
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Well I'm short (5'9") so this answers my question of how easy will it be in there with a helmet. Thanks!
I'm thinking this car will be classed in C Stock/STX year one. I've been bugging the NYR chair about this and he said no classing until cars are at dealers lol.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-03-2012, 12:49 AM   #39
chitownwrx
Drives: WRX
That headrest design will likely be a deal breaker to me. They are canted forward to prevent whiplash in an average height male (5'9", actually). It's a NHTSA regulation. Unfortunately the design also causes neck pain to shorter people. I'm 5'5", and I can't find a comfortable adjustment in most rental cars. Leaning the seat back just makes you lean back more while your neck is still cranked, and you cannot remove them and flip them around backwards.
chitownwrx is offline   Reply With Quote
Old 05-03-2012, 12:59 AM   #40
Dizz1e
Dizz1e's Avatar
Drives: 2013 Subaru BRZ (WRB)
In one of the video reviews the guy mentioned the headrest and even said he would just flip them around. So I was under the impression you could.
Dizz1e is offline   Reply With Quote
Old 05-03-2012, 01:29 AM   #41
chitownwrx
Drives: WRX
I hope so. It's all conjecture at this point about the BRZ. Next time you rent a car see if you can do it. The notches on the posts don't line up with the catch / clicky button adjuster on the side. So instead I end up ratcheting the headrest as high as it goes. Even if you could flip it around, why bother even having one at all? Less protection than the pre- 2006 headrests. It's a feature that is keeping me from buying a new car, well that plus the fact I still like my beat up old car.
For comparison, see the Impreza, which actually appears to have a fore/ aft tilt adjustment range.
And for tall drivers, I bet someone will make lower seat brackets for this car. These cars seem made to be modified.
Old 05-03-2012, 01:48 AM   #42
bestwheelbase
Drives: 1985 P-Type
Safety first! I have never had a problem but I always inspect my packs and consider where they're being stored/transported/etc.
Dealer wants to do a launch event around delivering car to me HotLavaMann Scion FR-S / Toyota 86 GT86 General Forum 24 05-09-2012 02:16 AM
Sat in FR-S yesterday Arthur Scion FR-S / Toyota 86 GT86 General Forum 35 04-11-2012 12:50 AM
Interesting take on 2012 GT-R bofa Other Vehicles & General Automotive Discussions 84 08-29-2011 06:38 AM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 04:05 PM
