Old 09-21-2014, 11:04 PM   #1
uEih
Drives: CBS Subaru BRZ Limited
Side Marker lights won't turn on
So today as I was getting ready to wash my car I noticed one of the side marker was flickering so I tried to open it and tighten it hoping it'll be fixed however it caused both of them to be off now. Did I blow something? I only messed with one side and the other side is out also.
uEih is offline   Reply With Quote
Old 09-21-2014, 11:51 PM   #2
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Is it stock, or did you swap it for an aftermarket bulb/piece?
Most likely it's the weather stripping on the side of the markers. If you tear off the black strip s, water and moisture might get in. Especially if you're pointing the hose straight at the markers. I never do that.
Go to Autozone and get an LED amber bulb that's waterproof, it should solve your problems.
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 09-22-2014, 12:03 AM   #3
uEih
It's aftermarket but what would explain the reason the other side went out also? Other side was working fine until I tried to fix the flickering side.
Ok after checking it out my license plate lights are off also. I don't know much about fuses but could it possibly be that I blew a fuse and need to change it?
Old 09-22-2014, 12:30 AM   #4
veck
veck's Avatar
Drives: 2014 Subaru BRZ
Check owners manual, fuse locations should be there. I think there are some reserve fuse in the box too.
veck is offline   Reply With Quote
Old 09-22-2014, 12:54 AM   #5
uEih
Found it and looked at it. Seems like my DRL, side markers, night running taillights, and license plate lights are out. Hopefully not all of those are blown and just a few or one that causes the others to go off.
Old 09-22-2014, 02:54 AM   #6
uEih
Replaced the blown fuse and the new one blew immediately. Not sure what the issue is.
Old 09-22-2014, 03:02 AM   #7
bumppinKota
Drives: FRS!!!
any pinched wires you can see that might be grounding out?
bumppinKota is offline   Reply With Quote
Old 09-22-2014, 03:19 AM   #8
uEih
I didn't do anything out of the ordinary, only messed with the side marker lights and for all I know it wasn't a tight space or anything so I don't see how it could have pinched. There could be something wrong with the LED bulb and I could take it off before trying a new fuse but not sure if that'll do anything.
Old 09-22-2014, 03:24 AM   #9
bumppinKota
Drives: FRS!!!
what i would do is i would remove the bulb you put back in place. replace the fuse. see if it burns. if it does then the bulb probably isnt the cause.
Old 09-22-2014, 04:03 AM   #10
uEih
I was thinking this is the only solution, gonna hate going through a bunch of fuses to find the issue though. I'll try this tomorrow.
Old 09-22-2014, 09:29 AM   #11
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Your flickering side marker LED is crap and has a short in it, causing the circuit to short. Sides and tails are all on one fuse under the dash. I had this same issue a while ago. The fuse is a 10a one that's located in the 4th slot I think... look at the fuse cover or owner manual to locate the correct one. There's a fuse puller in the fuse box under your hood.
Replace that LED w/ another one before you replace the fuse unless you want to keep blowing fuses.
Buy 50-60 spare fuses on amazon for about $14 instead of paying $1 each at autozone
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
The Following User Says Thank You to aznatama For This Useful Post:
uEih (09-22-2014)
Old 09-22-2014, 08:16 PM   #12
uEih
Thanks I figured if I took the LED off it should work, I'm gonna do it in about an hour. I'll let you know the results. I would buy it from amazon but unfortunately I need it asap and went to oreilys, 5 for $3.
Old 09-22-2014, 10:18 PM   #13
uEih
Took the LED light out and it works, the connection was probably weak and caused the short.
Old 09-24-2014, 05:33 PM   #14
Diode Dynamics
Diode Dynamics's Avatar
If the LED in your sidemarker was flickering, that means it has begun to fail.
The flickering is a sign of heat related damage
Nick C.
John C.
Diode Dynamics
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 03:41 PM
Side marker lights gap subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 1 03-06-2014 01:42 AM
FS: JDM clear side marker lights ILL_86 Audio/Visual, Electronics, Infotainment, NAV 3 01-02-2014 05:19 PM
FS: smoked side marker lights. NorCal_Guy Exterior Parts (Aero, Lighting, Etc.) 46 07-14-2013 04:42 PM
Is it possible to link the turn signal blink to the side marker on the BRZ? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 1 03-09-2013 02:03 PM
