#43 |
Drives: '13 Subaru BRZ Limited
Almost done, waiting for paint to dry at this point.
Prior to cutting: Rough cut: Closer look: |
| The Following 4 Users Say Thank You to J-W For This Useful Post: |
#44 |
Not sure why photos are showing up twice.
#45 |
Installed:
#46 |
/dev/null
Drives: Uphill
That looks very, very cool!
Oh, how I wish I had the balls to cut into my fender... I'd guess the structural integrity of the fender isn't seriously compromised by this, any one else having thoughts on that? |
| The Following User Says Thank You to Sarlacc For This Useful Post: | J-W (09-21-2014) |
#47 |
There isn't much structural integrity in the fender to begin with. I know this from replacing one after an accident. I had some fun with the old one that was only crunched up on the front corner.
Also, I'd recommend removing your fender if you have the time and space to do so. I think it would make it a lot easier to handle all of the cutting. Last edited by J-W; 09-20-2014 at 09:45 PM. |
| The Following User Says Thank You to J-W For This Useful Post: | Sarlacc (09-21-2014) |
#48 |
Drives: Scion FR-S
#49 |
#50 |
If I did something like this to my fender I would put in the extra effort in sanding down the areas that were cut (exposed metal) and applied some anti-rust black primer. I am sure the last thing you want is to have rust stains dripping down the side of your car.
#51 | |
Drives: 2013 Asphalt 6spd
Phantom ESC, OFH, OFT, K&N Drop in
#52 |
#54 |
I decided to do a bit of a test today to see if the vents actually worked at speed. I had found an old cassette and used a bit of the film(?) From it to make a crude streamer and tied it to the vent in order to display air movement from/around the vent. I wasn't able to make video yet, but when I was cruising at 75 mph (on a highway) it appeared that air was flowing over the hood and down the side of the fender. The film from the cassette tape was pointed down, but still away from the vehicle. I was also monitoring ambient air temperature in the front of the engine bay compared to the intake air temperature. Those were but a few degrees off from each other compared to before, when there was about a 10 degree variance. In conclusion, it is my opinion that this does work, though maybe only slightly. I don't have very many hard facts, but from what I've observed, I think it's worth it.
#55 |
Drives: 2014 SWP BRZ, MT
I myself never ended up getting the chance to do any remotely "scientific" testing although I will say it was definitely worth the aesthetic improvement
The answer is racecar. Always.
| The Following User Says Thank You to zkv476 For This Useful Post: | J-W (09-26-2014) |
#56 |
I was going to make some sort of comment on how fake vents are for mustangs or some other car that has followers that rag on imports, but I didn't want to ruffle too many feathers.
| The Following User Says Thank You to J-W For This Useful Post: | B-R-Z (09-26-2014) |
| Want to trade my white Frs fender vents for Brz fender vents | White0utFrs | Exterior Parts (Aero, Lighting, Etc.) | 0 | 09-23-2013 03:17 AM |
| Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
| WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents | BlueLeader | Exterior Parts (Aero, Lighting, Etc.) | 0 | 03-18-2013 02:55 PM |
| Functional front fender vents | JohnATL | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 01-25-2013 11:58 AM |
| Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents | DC-FRS | Exterior Parts (Aero, Lighting, Etc.) | 15 | 11-01-2012 11:41 PM |
