Old 09-03-2014, 04:44 PM   #1989
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by lucid215 View Post
i dont believe the tune will compensate for it. you will most likely start knocking a bit due to the lack of octan rating. i believe the timing tables are a bit different between the two roms. maybe @steve999 or @shiv can give a better answer
Yes, no problem running 91oct on 93oct maps if you need to, from time to time. The ECU will retard timing when/if it detects knock. You may loose a little bit of subjective smoothness in the process but that is understandable. If you find yourself having to run for 91oct for long periods of time, it may be more enjoyable just to flash in the 91oct version of the map you are running
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (09-08-2014), Gords_zenith (09-04-2014), lucid215 (09-04-2014)
Old 09-03-2014, 04:56 PM   #1990
eddieflyinv
eddieflyinv's Avatar
So has anyone noticed a difference in drivability/smoothness with their tune based on where they filled up ? I almost alllllwaaaays use shell 91, have had the 91 stage 1 tune for about a week now, and ended up filling at a Petro or something, car doesn't feel quite the same...
eddieflyinv is offline   Reply With Quote
Old 09-03-2014, 04:58 PM   #1991
Shiv@Openflash
Drives: 2013 FRS
That's entirely possible. FWIW, I only fill up with Chevron, Shell or 76
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
eddieflyinv (09-03-2014)
Old 09-03-2014, 07:43 PM   #1992
eddieflyinv
In Canada the best I can get is Shell 91 lol there's Petri ultra 94 but it's just additives... So I stick with pure and ethanol free when I can find it..
Old 09-03-2014, 09:05 PM   #1993
kavanagh
Fat on Corn Syrup
Most of us in Arizona have noticed that fresh gas is more important than the brand of gas. Especially since we can only get up to 91oct or E85 (in love).
I used to be hard core Chevron and Shell - alternating between the two to get the most out of each's additives. But I noticed sluggishness sometimes and then once had to go to a QT (convenience store with 'off-brand' gas) that is always busy. It was the best tank of gas I ever got, and it was 10 cents cheaper - which is why it's always fresh.
So look for the busiest station and fill up from there. I almost guarantee you'll feel the difference.
The Following User Says Thank You to kavanagh For This Useful Post:
DC2R (09-03-2014)
Old 09-08-2014, 03:48 PM   #1994
86socal
86socal's Avatar
Drives: White frs
I just installed the tomei uel on my frs and I just wanted to make sure if the oft will work well with it before I get one. Thanks
86socal is offline   Reply With Quote
Old 09-08-2014, 03:56 PM   #1995
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Load up stage 2 uel map and have fun!
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
The Following 2 Users Say Thank You to Triumphrider For This Useful Post:
86socal (09-08-2014), lucid215 (09-08-2014)
Old 09-20-2014, 10:14 AM   #1996
randomthoughts
Drives: 2014 White BRZ
I will be purchasing an OFT shortly and not sure if I should be using Shell 91 or Petro 94. Just wondering what others from Toronto area are using with OTF on a stock car. I know Perto 94 has 10 ethanol.
randomthoughts is offline   Reply With Quote
Old 09-20-2014, 10:44 AM   #1997
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Has anyone experienced their Calibration ID changing?
I've had an OFT since last winter and my car was set as A00D at that time. I took it to the dealer a few days ago (oil change and taillights) and decided to update to V2.061. I looked at the ECU info and it is now B01D...OFT manager still says my CAL ID is A00D and I was able to flash my car with A00D V2.061 with no issues. Should I be worried? Would I be able to revert back to stock with my original file being from A00D?
It is a 2013 model. And honesty, I'm not sure whe the change occured; it could've been a few days or it could've been months ago.
Thank you!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 09-20-2014, 01:08 PM   #1998
Hagbard
Hagbard's Avatar
In Durham as well running the 93 tune on petro 94
Hagbard is offline   Reply With Quote
Old 09-20-2014, 04:23 PM   #1999
randomthoughts
I will probably end up going with the same set-up. Did you try the 91 tune with Shell V-power 91?
Old 09-21-2014, 04:52 AM   #2000
steve99
Drives: FT86
Thank you!
Thats normal
read OFT TIPS link below
the oft keeps a copy of your original rom so you can always flash it back and it will be the original A00C rom
but the oft tunes are generally based on the latest compatable rom for your car so the latest tunes compatable with A00C are B01C based tuned roms ie you get a free upgrade as well as the tune The A00C rom you flashed is actually a B01C inside :-)
Old 09-21-2014, 10:40 AM   #2001
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The benefits continue
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-21-2014, 12:35 PM   #2002
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
i always use shell 91 (im in quebec)
last week, i was at toronto, and i tried petro 94..... wow... that gave an insane amount of cricket.... once back in quebec, i've took shell 91 again, and the sound is gone... i would suggest you to try both and see the results for yourself!
Walla Walla is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
