Old 09-16-2014, 06:15 PM   #1
keeeefers
keeeefers's Avatar
Drives: Whiteout frs
Powered by MAX Comp Coilover Lower control arm review/Install
Powered by Max Comp Coilover lower control arm install/review
Before (stock suspension)
I started on the rears and since we were installing lca's and coils we took everything off except for the two nuts that hold the coil to the body inside the trunk.
Lower control arm and rear coil installed. There is two holes to mount the coilover in, top hole is 20mm lower bottom is 45mm lower. I didn't have the balls to try the bottom hole ..... yet
Front stock suspension removed
After install. i plan on going lower but the stock end links up front wouldn't let me.
Everyone told me how stiff and uncomfortable pbm coils were, but I knew they made quality products so I went out on a limb and did it. To my surprise they are nowhere near as stiff as people made them out to be. They are pretty damn comfortable and take dips and uneven roads better than any other coil I've ran before. Ive been on pbm's for about 3 weeks now and i have the the dampening set to 7/12 clicks all around. With this set up you have an insane range of ride height adjustiblity, you can go super super low on these. I have no complaints other than every once in a while you will hear a pop or in the rear at low speeds or on steep inclines. Overall this is best coil over I've owned and I reccomend this set up to anyone looking for a quality set of suspension with out killing your wallet.
thanks for looking!!
keeeefers is offline   Reply With Quote
The Following 6 Users Say Thank You to keeeefers For This Useful Post:
chaoskaze (10-26-2014), DAEMANO (09-16-2014), FRS Johnny (03-29-2015), gkubed (04-23-2016), RedEdTed (02-01-2016), Slow_86 (10-24-2014)
Old 09-16-2014, 06:54 PM   #2
Captain Caveman
Drives:
These are on my radar. Glad to see more people starting to run them.
Sent from my KFTHWI using Tapatalk
Captain Caveman is offline   Reply With Quote
Old 09-16-2014, 07:23 PM   #3
Jdogg88
Drives: Sapphire Blue ‘23
Been waiting for a review on these coils, makes me even more stoked to pick up a set!
Jdogg88 is offline   Reply With Quote
Old 09-16-2014, 08:31 PM   #4
griffunitt
Drives: Whiteout FR-S
How is the camber adjustment in the rear? Is it pretty easy to get to without taking the LCA down?
griffunitt is offline   Reply With Quote
Old 09-19-2014, 04:37 PM   #5
keeeefers
keeeefers's Avatar
its pretty simple one bolt and you gotta unjam a few nuts locking in camber specs .
Old 09-30-2014, 03:12 AM   #6
Squishy86
Squishy86's Avatar
Drives: Your Car
Did you need rear toe arms to get back to spec?
Sent from my HTC One_M8 using Tapatalk
Squishy86 is offline   Reply With Quote
Old 09-30-2014, 11:50 PM   #7
Jdogg88
Are you gonna buy new endlinks so you can lower more?
Old 10-01-2014, 02:01 PM   #8
srizzors25
Daedalus Moto
srizzors25's Avatar
Hmm I've always loved PBM but was hesitant based on the spring rates. You'll have to keep updating I'd be curious how these hold up with time
Old 10-05-2014, 06:33 PM   #9
keeeefers
keeeefers's Avatar
Yes toe arms are a must! I was toeing out so bad before we go them on. My boys over @fteightysix hooked it up on a let minute set of spc toe arms so i wouldn't fuck up my tires.
Old 10-05-2014, 06:37 PM   #10
keeeefers
keeeefers's Avatar
Ill be totally honest with you i love how they ride. its not as stiff as people make them out to be. the only thing they are quite a bit noisier than stock espessialy on super bumpy roads and steep inclines but then again people don't buy aftermarket part for how stealth they are ahah. Ive been on them for about a month and a half now and i don't have a single complaint
Old 10-05-2014, 08:13 PM   #11
PradiG
Drives: Fr-s
I'm surprised you need toe arms...
you shouldn't need toe arms for anything under -5 camber in the rear.
PradiG is offline   Reply With Quote
Old 10-06-2014, 11:02 AM   #12
illmattic
illmattic's Avatar
Incorrect. Anytime you change camber by using rear lower controls arms it messes with the toe.
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 10-06-2014, 11:14 AM   #13
PradiG
Drives: Fr-s
I know, I'm just saying I have the same LCA's and I'm running almost -4.5 camber in the rear with the oem toe arms...
Old 10-06-2014, 02:06 PM   #14
srizzors25
Daedalus Moto
srizzors25's Avatar
Well thats awesome to hear. So would you suggest them as a DD setup with maybe very occasional autox/track/drift? I'm talking like 95% DD ha, have the track bike for the real stuff, definitely building the car for a nice looking DD.
coilovers, lower control arms, pbm, powered by max, review
Voodoo13 Rear Lower Control Arms - Initial Inspection - Install/Review to follow Travisty75 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 10-23-2016 03:33 PM
PA:FS Stance Coilover and Lower control arm (price reduced) tapsumbongfrs Brakes, Suspension, Chassis 11 10-13-2014 03:50 PM
Powered By max coilovers/lower control arms keeeefers Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-28-2014 12:47 AM
Powered by max coilovers/lower control arms keeeefers Brakes, Suspension, Chassis 3 08-30-2014 06:52 PM
Help with Lower Control Arm install. DaiTT500 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-08-2014 11:56 AM
