Old 12-13-2013, 11:31 AM   #71
Apex-Wolf
Apex-Wolf's Avatar
Drives: Ultramarine Scion FR-S
That's a nice RACK you got there :P
Apex-Wolf is offline   Reply With Quote
Old 12-13-2013, 10:11 PM   #72
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Awesome work! I think the Thule big mouth bike tray I have would mount directly to the your pegs. I'll definitely be rigging this up when I get my FR-S.
Quentin is offline   Reply With Quote
Old 01-02-2014, 12:11 PM   #73
Juggles
Drives: 2013 FRS
Im interested! Tons o dirt to hit out here in Az!
Juggles is offline   Reply With Quote
Old 06-19-2014, 07:33 PM   #74
gutbuster
Drives: 13 FR-S
Here is my version of it
I used sections of the standard Yakima round tube with a Viper rack. I designed some steel adapters with 16mm threads and my friend turned them. The tubes slip over the adapters and a have long 3/8" bolts drawing them up to a shoulder on the adapters. The funny looking red thing is an adapter for 15mm thru axles on mtn bikes.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
gutbuster is offline   Reply With Quote
Old 06-19-2014, 07:45 PM   #75
littledvl
littledvl's Avatar
Drives: 13' brz limited
I would definitely buy that setup! Looks super clean man.
littledvl is offline   Reply With Quote
Old 07-07-2014, 06:39 AM   #76
kamilgt
What's type of thread is in tow hooke hole?
kamilgt is offline   Reply With Quote
Old 07-07-2014, 07:36 AM   #77
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
M16 x 1.5
stock is offline   Reply With Quote
Old 07-12-2014, 07:16 PM   #78
littledvl
littledvl's Avatar
Was curious to see how this would with a thule sidearm roof rack, I used two stock factory tow hooks and welded a 1 1/8" bar to each since I don't have access to a lathe to get my mounting points. Got it all mounted up today, need to make a bracket/brace to hold it more stable, since I didn't mount it like its supposed to be on a roof (where the front wheel mount is actually mounted to the cross bar), if I did the bike would sit outside the passenger side of the car and a few feet in on the driver side. Its not a big deal, I trust it wont break or fall off or hit the car itself, just need to hold it more stable for my liking.
Old 08-12-2014, 11:12 AM   #79
SOAZ
Drives: pinto
Great looking setup. I need to figure something like this out ASAP. No access to a machine shop so I need to figure that out.
Do you think you would try 2 bikes? I wonder if that would be over taxing the mounts or hurt the car. It would be really nice to mount 2- 20lb mountain bikes back there for a road trip.
Nice Niner by the way. (SIR9 SS Rigid here)
SOAZ is offline   Reply With Quote
Old 08-12-2014, 11:19 AM   #80
Pat
Pat's Avatar
Drives: 2023 BRZ
FWIW, I had a similar setup on my Boxster S. Except the rack was not bolted to the tow hook location. Instead, it was bolted to the bumperettes, which were aluminum and likely not nearly as strong as the tow hook location. I carried two bikes on there without issue.
That's certainly not a guarantee, but if I had to guess, I would say the OEM tow hooks could handle it just fine. As long as whatever you fab up is worthy, I say go for it.
Old 08-12-2014, 08:23 PM   #81
gutbuster
Drives: 13 FR-S
2 mtn bikes in fork mount rails need to be spaced apart a bit because of the handlebars. With one bike there is not much moment arm but the 2nd bike hanging out there is going to add bit more load overhung. I took care to size the inserts close to the hole dia in the bumper to avoid a bending moment at the M16 threads. I would not do it unless I at least did a static load analysis on the solid turned inserts.
Old 09-19-2014, 07:44 AM   #82
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
I recently picked up a 1upUSA Quik Rack hitch carrier (to carry one or two bikes on my kask2_6.0 hitch):
Pros:
  • Slick design, build quality, and craftsmanship
  • No rubber or fabric to deteriorate (except for safety strap)
  • Lightweight with one tray and bike is close to car (less moment/stress on hitch)
  • Stable
  • Centered (even my 29er doesn't stick out much on either side)
  • Convenient and quick operation (wheel trays > clamps/straps)
  • Modular (can carry up to three bike)
  • Small company
  • Made in USA
  • Great return policy and anti-theft guarantee
  • Folds up close to bumper and out of way (and doesn't block license plate when used with one or two trays)
  • Folds in half for storage
  • No assembly
  • Better ground clearance than most hitch racks
  • Trunk accessible with bike loaded (even without angling it down)
  • Easily transferrable to other vehicles (with 1.25" or 2" hitch)
Cons:
  • Expensive (cost of hitch + hitch rack > tow hooks + roof rack tray)
  • Safety strip a bit wimpy
  • Less ground clearance than tow hook solution
  • A bit heavy with three bikes (I'm not going to try more than two on this hitch)
Weight (not counting bikes):
  • 23 lbs: Rack with one tray
  • 18 lbs: Each additional tray
Deslock is offline   Reply With Quote
Old 09-19-2014, 12:06 PM   #83
SOAZ
Drives: pinto
Looks fantastic. I have my bike carrier done, but I'm going to cut it down so it's shorter. Still considering two bikes, but fork mounted. We'll see.
Big question is, is the Kask hitch still for sale, anywhere?
Originally Posted by Deslock View Post
I recently picked up a (to carry one or two bikes on my kask2_6.0 hitch):
Pros:
  • Stable
  • Small company
  • Made in USA
  • No assembly
Cons:
Old 09-19-2014, 04:14 PM   #84
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Originally Posted by the Red Devil View Post
I do a lot of riding, both road and MTB bikes. You can tell that I really enjoy bikes as my avatar is no other than "Eddy Merckx".
thanks.
Had an Eddy Merckx Century. Loved that bike.
Hot Lava is offline   Reply With Quote
the red devil
anyone fit a bike rack yet? earthsscum BRZ First-Gen (2012+) — General Topics 108 05-26-2019 11:39 AM
Mods Please delete, thanks! the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 2 06-22-2013 03:31 PM
Mods please delete! thanks! the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2013 03:19 PM
Bike rack for BRZ brzbiker BRZ First-Gen (2012+) — General Topics 1 05-27-2013 05:35 PM
FR-S/BRZ + Bike night in Lancaster,MA raphymartinez New England 10 06-21-2012 12:58 PM
