Old 09-14-2014, 09:58 PM   #15
wparsons
wparsons's Avatar
Mine was closer to -1.5* on each wheel (within ~0.03), guess I got lucky
-1.2* will definitely be a good difference from stock! You might want to dial out some camber in the rear, around -1* would be more ideal to balance out what you have up front.
It won't be bad as is, but you could optimize it if you wanted.
flickr
Old 09-19-2014, 11:34 AM   #16
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
My car is currently sitting at -2.5 front -1.6 rear. I've been debating that my -2.5 front may be a little too much. I've been considering dropping the front to -2.0 flat...
Thoughts? I'm kinda a suspension and camber newb here. Looking for comments/suggestions on what would be a good place to keep this.
- For reference, I do casual autocross, and love to take windy roads whenever possible.
SpectreRT is offline   Reply With Quote
Old 09-19-2014, 12:11 PM   #17
wparsons
wparsons's Avatar
Are you wanting to set for tire wear, or for max grip?
If you want to set for wear, look at how they're currently wearing (and consider if you're willing to flip the wheels on the rims to wear them the other way).
If you want to set for grip, you need to measure temps across the tread after an autocross run. If the outside is colder than the inside, you have too much camber.
I would bet that at -2.5 you're in the right range for autocross (possibly even wanting more), but possibly getting some uneven wear depending on how much the car is driven.
flickr
Racecomp Engineering (09-19-2014)
Old 09-19-2014, 01:15 PM   #18
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Thanks for the quick reply. I'm looking for a happy balance of longevity and cornering/grip. When I had my front camber at -1.5, I still noticed a lot of sidewall wear. At -2.5, that seems to be gone; however i'm concerned it may be a little much.
Yes, I know too much camber can/will wear the inside of the tire; i'm comfortable with that. Just trying to find that sweet-spot, ya know?
Old 09-19-2014, 03:04 PM   #19
wparsons
wparsons's Avatar
If you're not concerned about the wear on the inside edge, then I would just leave it as is.
flickr
Old 09-19-2014, 03:50 PM   #20
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
So long as I'm not buying tires every year; i'm fine. lol...
Old 09-19-2014, 03:57 PM   #21
gramicci101
Off Topic
Zero your toe front and rear.
- Andy
I thought zero toe front and rear would make the car twitchy? I read somewhere on here that a little bit of toe in the rear would make it more settled and less likely to track lines in the road. A little bit being around 1/32 each, for 1/16 total.
Is that not right? I'm ordering springs this weekend and want to know what to tell the alignment guy once they're in.
Old 09-19-2014, 03:59 PM   #22
Grim-Reaper
Grim-Reaper's Avatar
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
Just a short question. Does front camber count per side or combined? Like 2x 1.75 degrees or 1.75/2?
Grim-Reaper is offline   Reply With Quote
Old 09-19-2014, 04:03 PM   #23
wparsons
wparsons's Avatar
Zero rear toe is good for autox, but unless you're really experienced on a track you'll probably want that ~1/16" of toe in.
Camber is measured per wheel.
flickr
gramicci101 (09-19-2014)
Old 09-19-2014, 04:22 PM   #24
gramicci101
Off Topic
Thanks. Then I'll go 2* on the front, zero toe. And whatever I get from lowering on the rear, with 1/32 toe in on each side. Sound good for a DD? I have camber bolts for the front.
Old 09-19-2014, 04:43 PM   #25
wparsons
wparsons's Avatar
You won't get -2* up front from just camber bolts, ~1.5 max.
flickr
Old 09-19-2014, 04:49 PM   #26
I wouldn't say 0 toe makes things "twitchy" but a little bit of rear toe-in is usually a good thing and helps keep things stable.
If he's not adding rear LCAs and isn't able to dial out the extra rear camber from the drop, I wouldn't worry about not having that slight amount of toe-in especially if he autocrosses. Also if he's going to be limited with how much front camber he can get.
If you are able to back down the rear negative camber or add a bunch of front camber, then I would dial in a little bit of toe-in (1/16 total is good).
- Andy
Old 09-19-2014, 05:06 PM   #27
gramicci101
Off Topic
Well, I'll do what I can with what I have, I guess. Any is better than stock.
The Following User Says Thank You to gramicci101 For This Useful Post:
wparsons (09-19-2014)
Old 09-19-2014, 05:52 PM   #28
wparsons
wparsons's Avatar
You're not wrong there!
flickr
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-26-2013 12:39 AM
Alignment questions Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2013 02:50 PM
Alignment/coilover questions yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-04-2012 05:48 PM
