Old 09-13-2014, 06:49 PM   #1
Wilson15
Drives: Subaru BRZ Limited
18x9.5 +45 fitment
Need some help, was just wondering is 18x9.5 +45 will have any fitment issues stock and/or dropped on springs 1 inch.
What else would i need to adjust to make these work if there are fitment issues.
Thanks
Wilson15 is offline   Reply With Quote
Old 09-18-2014, 06:56 PM   #2
vividracing
vividracing's Avatar
You should not have any fitment issues at all. However what size tires do you plan on running?
vividracing is offline   Reply With Quote
Old 09-18-2014, 07:05 PM   #3
Wilson15
thinking 255/35, but iv read after that for the 57extremes 18x9.5 +40 all around will create issues in the front with the struts, wouldnt +45 (ssr gtv02) make it worse?
Old 09-18-2014, 07:27 PM   #4
CSG David
CSG David's Avatar
Thanks
You will not be able to fit them without spacers or coilovers (smaller diameter spring). If you want a 9.5" you will need a +38 minimum.
Old 09-18-2014, 07:28 PM   #5
CSG David
CSG David's Avatar
It won't fit on stock suspension or lowering springs. We've test fitted both setups +40 and +45.
Old 09-18-2014, 07:43 PM   #6
vividracing
I just got 4 sets of 57xtreme in-stock yesterday and Im trying to move my last set of HKS Hypermax IV GT coilovers. Pm me and let see if we can make it work for you and eliminate all fitment issues you think you may have.
The Following User Says Thank You to vividracing For This Useful Post:
TheGuyWithTheFireStorm (09-18-2014)
Old 10-04-2014, 04:48 PM   #7
BcRuZn
Drives: 2017 Brz Series Yellow
Don't mean to thread jack but would it fit with 18x9.5 35offset .. 235/35 or 245/35 tire... Looking at a pair of varrstoen es1s with eibach pro kit springs
BcRuZn is offline   Reply With Quote
Old 10-04-2014, 08:46 PM   #8
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Those will clear the struts. Only issue is a good amount of poke in the front.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
CSG David (10-05-2014)
Old 10-05-2014, 07:49 PM   #9
CSG David
CSG David's Avatar
Need to camber it to fit better.
Enkei Raijin Mesh Wheels - 18x8.5 / 18x9.5 in custom 5x100 FR-S / BRZ fitment GuerillaRacing Wheels and Tires 193 05-26-2015 05:55 PM
TE37 reps. 18x9.5 +34 perfect fitment! 265/35/18 beefy tires! CHEAP!! dOMEmE Wheels and Tires 18 05-12-2014 02:16 PM
Traklite Angle 18x9 FR-S BRZ Fitment $899 Shipped!!! Dustin@Dynosty Wheels and Tires 77 12-09-2013 09:40 AM
Rota torque 18x9.5 +35 fitment PB-GT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-22-2013 08:08 AM
18x9 wheel fitment and options? epson1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2012 05:36 PM
