Old 09-18-2014, 01:32 PM   #43
37
degrees
37's Avatar
Drives: 6MT BRZ
Originally Posted by wheelhaus View Post
PLEASE NOTE: The gray tape is temporary. I'm working with our 3M rep to test out some black tapes that are also UV resistant. I want this shroud to be hardly visible at all.
3M 4947F should fit the bill. It's black, UV-resistant, and 49 mils (1.1mm) to dampen both vibration and be thick enough to wedge something between the glass and carbon housing in the event it needs to be removed. It's designed specifically for adhering items to glass and resists both paint and plasticizer. Carbon fiber and fiberglass resin—especially when molded smooth—has enough surface energy that adhesion and any possible off-gassing should be a non-issue.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
wheelhaus (09-18-2014)
Old 09-18-2014, 02:01 PM   #44
wheelhaus
wheelhaus's Avatar
Originally Posted by Rosticles View Post
I definitely want one of these, preferably in a less expensive fiberglass. I think it would also be nice to make a matching triangular piece to cover the wound left on the back dash after removing the factory light. I was going to make one myself from plastic, but I think it would be smart to pair these items for sale.
I am already planning on including three felt patches, the edges can be seen from the rearview, but even on untinted glass they're nearly invisible. I'll look into making a cover of sorts to see how best to handle it. I want to avoid any hard surfaces near the glass though, rattles be the devil, ya see...
Originally Posted by DarkestBuddha View Post
can you make it so it has an extension that does into the headliner and bolts into the middle push cap and so it keeps pressure against the back window
so we dont have to use double sided tape on tint.
also how bright is that light under direct sunlight
I was thinking about this, but I had a HELL of a time trying to get that center button off, I just gave up. And I was using interior panel tools etc. I do have the ability to bend and even bond an aluminum foot as you suggest, but it's not going to happen with the first design. It's on the radar though and I'll keep you guys posted.
The light is really bright, enough to bloom on a camera. It very very close to the same color and intensity as the OEM tail lights. I'll take a photo if you'd like.
Originally Posted by 37 View Post
3M 4947F should fit the bill. It's black, UV-resistant, and 49 mils (1.1mm) thick to dampen both vibration and be thick enough to wedge something between the glass and carbon housing in the event it needs to be removed. It's designed specifically for adhering items to glass and resists both paint and plasticizer. Carbon fiber and fiberglass resin—especially when molded smooth—has enough surface energy that adhesion and any possible off-gassing should be a non-issue.
4929, 4949, and 5952 are all considerations in the line of ~45 mil black VHB tapes. Do you think 1/4" would be sufficient or should I stick with 1/2"? 1/4 would be easier to remove if necessary.
Old 09-18-2014, 04:33 PM   #45
37
degrees
37's Avatar
Drives: 6MT BRZ
4929 / 4949 / 5952 are all for bonding metal and plastic. 4947F is specifically for bonding various substrates to glass. While all of these should work, my money is on 4947F above all else. I have experience with that exact tape.
1/4" wide is more than enough. Overall weight is likely under a pound and most VHB has pull strengths in the 30+ PSI range. Even a 1/4" strip should take 10 PSI or more just to pull off. I'd rather fight 1/4" worth of VHB than 1/2".
Keep in mind this could get dust, bugs, haze, or other unknown variables behind the glass and require periodic cleaning. I could almost see a version with a long tail that tucks into the headliner and puts enough pressure on the housing against the glass to stay in place with only a felt lining. Cleaning would be vastly easier. It could even bolt to the antenna area. Just a thought.
The Following 2 Users Say Thank You to 37 For This Useful Post:
DAEMANO (09-18-2014), wheelhaus (09-18-2014)
Old 09-18-2014, 04:42 PM   #46
DarkestBuddha
Drives: BRZ limited GBS
okay cool.
i actually did this too but i added the aluminum foot and the headliner button goes through a hole in the aluminum to keep it stable and up there without the need for 3mtape. however due to the aluminum, the part that was supposed to be flush to the headliner is slightly lower then it now.
Also what light are you using, can i get a link.
my light is near invisible in direct sunlight through my tint.
at night it is very bright tho.
DarkestBuddha is offline   Reply With Quote
Old 09-18-2014, 05:07 PM   #47
wheelhaus
wheelhaus's Avatar
okay cool.
I am using the same light from the first thread I referenced, seen here. It is this light from www.superbrightleds.com
Old 09-18-2014, 05:14 PM   #48
GremlinGSP
interested.
GremlinGSP is offline   Reply With Quote
The Following User Says Thank You to GremlinGSP For This Useful Post:
wheelhaus (10-04-2014)
Old 09-18-2014, 05:24 PM   #49
wheelhaus
wheelhaus's Avatar
Ah perfect, that's exactly what I need. Unfortunately they don't make 4947F in 1/4 wide rolls. My supervisor was under the impression some vendors can cut custom widths... I'll make some calls and see if that's possible.
I'll work on a way to mount it with a bracket, seems people definitely want that option, but its going to be more expensive. Using tape is the quickest, cheapest way to mount a razor thin light like this. I guess it is possible for debris/etc to enter the housing, but with felt covering the areas where tape isn't (moreso than seen in my photo), accumulation should be minimal if any. Nearly every headliner I've pulled from several different cars revealed a pretty clean area behind it.
To boot, the top edge of the carbon flange actually butts against a piece of foam or something bonded to the roof structure/skin, so in combination with the felt it sort of acts as a poor-mans labrynth seal.
The Following User Says Thank You to wheelhaus For This Useful Post:
37 (09-18-2014)
Old 09-18-2014, 06:22 PM   #50
37
degrees
37's Avatar
Drives: 6MT BRZ
Depending on the volume you produce, fabricating a cutting jig for the tape wouldn't be difficult. It's added time and time is money. If you only crank out 20 units then a custom tape order probably wouldn't pan out. You'd have to do the math on length versus cost. Each housing is ~2' worth of tape. One roll of tape would last a while.
Tape is indeed the quickest and easiest. If the housing is sealed well enough to keep out dust/bugs/haze then I'm all for it. My BRZ windows seem to get hazy quite quickly despite not smoking and the car being over a year old. The plasticizer used in the interior panels must still be off-gassing.
Old 09-18-2014, 06:51 PM   #51
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Nice!
I'm absolutely 100% in if you start producing these.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
SkAsphalt (09-21-2014), wheelhaus (10-04-2014)
Old 09-18-2014, 10:04 PM   #52
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
mm. Me likey. Me dont likey the carbon fiber because $$$. If it was FRP or fiberglass thatd be a different story
..maybe more affordable then.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 09-19-2014, 06:33 PM   #53
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
in for GB.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
Old 09-20-2014, 02:49 AM   #54
Tjbugs1
Tjbugs1's Avatar
Drives: Subaru BRZ
Just posting so I can follow about a GB.
Originally Posted by My Wife
Wait, where does the key go? WAIT, WHERE IS THE KEY?
Tjbugs1 is offline   Reply With Quote
The Following User Says Thank You to Tjbugs1 For This Useful Post:
Old 09-20-2014, 01:34 PM   #55
White64Goat
I'll throw this question out there as no one has asked so far. Does the housing cover over any of the wire grids for the rear window de-fogger? Asking because if the LED should fail, an easy removal without damage to wire grids would be necessary.
If the housing doesn't contact any of the grids, would black RTV silicone sealer be an option?
The Following User Says Thank You to White64Goat For This Useful Post:
Old 09-20-2014, 02:37 PM   #56
GTSRolla34
Drives: 2014 BRZ Limited - 1986 AE86
I'm interested in a group buy. I'll keep an eye on the thread.
2014 Subaru BRZ LTD - Dark Gray Metalic
1986 Toyota Corolla GTS - CA18DE Powered
http://club4ag.com/forums/viewtopic.php?f=7&t=1247
http://www.86garage.com/forums/viewt...hp?f=40&t=1459
GTSRolla34 is offline   Reply With Quote
The Following User Says Thank You to GTSRolla34 For This Useful Post:
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 04:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 10:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 11:10 AM
Low profile Seibon Carbon Fiber Spoiler pics mike_ekim1024 Cosmetic Modification (Interior/Exterior/Lighting) 0 04-17-2013 06:56 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
