Old 09-17-2014, 03:24 AM   #29
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I LOVE these bad boys!
I installed mine today, I took my headers off.
I have two questions.
1. Did I have to put the black metal plate from stock mounts onto the new mounts?
I tried at first but it kept sliding off, so I just took it off.
2. Whats the deal with the two bolts on each mount?
Had no idea how much to torque, so I tighten them until I passed two threads
Carlitoz3 is offline   Reply With Quote
Old 09-17-2014, 04:56 AM   #30
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Yep. Just to confirm: it requires unbolting the header and lifting the engine quite a lot. No other way of doing it
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
Sportsguy83 (09-17-2014)
Old 09-17-2014, 07:23 AM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If you bought Perrin mounts, no , no need to transfer the palte from stock mounts.
The bolts on the mounts are adapters to fit what are WRX/STI motor mounts originally to our car.
I didn't use a torque wrench either.
Old 09-17-2014, 12:41 PM   #32
Carlitoz3
Carlitoz3's Avatar
Crap, I'm also using Cusco.
What's worst case scenario not putting the plates back on?
Old 09-17-2014, 02:01 PM   #33
Sportsguy83
Drives: Limited BRZ
The plates are heat shields to the mounts.
Old 09-17-2014, 03:32 PM   #34
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
What's the NVH like on these things? I had some mounts on my altima and the vibration was bad (wonderful) enough I had to modulate the throttle so my rear view mirrors stopped shaking! To give some reference points, I've done subframe mount inserts, trans mount insert, diff mount insert, and shifter bushings; I'd call my gear whine 'noticeable but civil.'
I bought a set, I think I'll put em in when doing my header, judging by all these horror stories!
What is the stock durometer anyhow?
NissanGuy is offline   Reply With Quote
Old 09-17-2014, 07:08 PM   #35
Carlitoz3
Carlitoz3's Avatar
Yes the job was so much easier without the header, I also took off my strut bar and intake since I didn't want to smash anything when raising the engine. The NVH is most when turning on the car and taking of from first
Old 09-17-2014, 07:09 PM   #36
Carlitoz3
Carlitoz3's Avatar
How did you keep them from sliding off before the engine was lowered?
Old 09-17-2014, 07:29 PM   #37
Sportsguy83
Drives: Limited BRZ
I didn't mount the plates because I have Perrin mounts, not Cusco mounts. Perrin mounts are a weird shape and the plates do not fit.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Carlitoz3 (09-17-2014)
Old 09-17-2014, 09:39 PM   #38
xwd
The Cusco mounts don't use them either they are constructed completely different than the stock mounts. I swapped the Cusco for the STi mounts, too much NVH.
Old 09-21-2014, 11:53 PM   #39
Astroboy
Astroboy's Avatar
Drives: None
When did you realized that the rubber part of the mounts melted? Did your car start to shake due to poor motor mounts?
Astroboy is offline   Reply With Quote
Old 09-21-2014, 11:55 PM   #40
Astroboy
Astroboy's Avatar
Drives: None
PSA: Replacing Engine Mounts can be a BITCH and much more!
Btw, I'm glad to here your cars been doing good
Old 09-22-2014, 12:20 AM   #41
Sportsguy83
Drives: Limited BRZ
My mounts haven't melted. That happened to another member.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 10-12-2014, 04:30 AM   #42
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Just replaced my motor mounts. It's not that bad, guys.
For tight bolts: use a longer ratchet. And I was able to get the driver's side mount out with the manifold still on. The trick is, you remove the lower manifold heat shield and then fold the offending flange out of the way. Bend it back to stock and reassemble, zero rattle due to the pretty fantastic heat shield design.
My FR-S has a build thread!
(It's mostly full of Nissans)
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 10:24 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
