Old 09-15-2014, 10:26 PM   #57
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by Calum View Post
Loosen the lash adjustment, remove rocker arm. He'd need to adjust the lash with the new arms anyway. Wait, shims... WTF? Did he manage to compress the valves with the heads on? I know you've said you don't run much seat pressure, but damn.
It's a mystery ha ha We talked about making a tool that would allow us to compress the spring while the heads were in the car and the cam in place so I guess he made the tool. Luckily the shim we had originally used had the correct valve lash with the new rocker.
Not something I would recommend unless you got as lucky as I did. Normally the engine would need to be taking down but after cutting the oil filter apart with no debris (bearing or other), perfect leak down results, and we accounted for the shim, rocker, and pin I felt it was worth it to "get her done" and go racing this weekend.
There is still a little risk but I've decided I'm ok with it for my personal car since I really want to continue long term abuse/durability testing of Elment Tuning motors.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
Calum (09-16-2014)
Old 09-17-2014, 10:02 AM   #58
Element Tuning
Modified a rocker to test so the pin cannot walk out again and got the motor back into the FRS last night. She's ripping to 9k rpm again! Those Perrin pulleys sure do look sweet next to my corroded stock ones. LOL!
A couple more things to iron out and hopefully we'll be on the road to Limerock tomorrow.
sw20kosh (09-17-2014)
Old 09-17-2014, 10:50 AM   #59
gramicci101
Off Topic
What do you think the possibility is of our rockers being the same dimension as existing rockers for another vehicle? I wonder if there are already aftermarket options out there that fit and we just don't know about it yet. If there are, that seems like an easy way to have stronger rockers with more precise measurements.
Old 09-22-2014, 09:36 AM   #60
Element Tuning
It's possible but unlikely since this is a newely designed Subaru engine and they really haven't used these in the past. We'll continue testing our fix to make sure it's reliable over time. It survived a race weekend at Limerock so I'm happy so far.
Old 09-22-2014, 01:35 PM   #61
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
This is why im getting my engine eventually built by @Element Tuning. Nice job Phil.
Also kinda wanting to work for Element Tuning now
Old 09-22-2014, 07:50 PM   #62
Calum
That Guy
Drives: 2013 asphalt FRS MT
Now that you mention it, I have a fleeting memory of someone saying there is some similar parts between the top end of the FA and another toyota motor. You might try looking through Homemade WRX a.k.a 3MI Racing's old posts or maybe even argx7's posts.
Old 09-22-2014, 08:17 PM   #63
mike the snake
I remember reading here about someone saying they saw crank and bearing failures on engines with lightened parts on both front and rear ends.
Maybe something to do with harmonics? They seemed to indicate they'd seen more failures on engines with both lightened pulleys And lightened flywheels.
Maybe since you're wanging your engines out to 9K you might be out of the harmonic range?
I'll know in a couple months if I'll have enough to get the built engine from Element Tuning.
Old 09-25-2014, 03:47 PM   #64
Element Tuning
Mike, honestly people have been trying to make that connection for years and I'm really not convinced at all with these boxer motors it has anything to do with bearing failures. It's like saying cars that run on gas have bearing failures
In all seriousness I do think with inline motors with long cranks I can see making a case that a heavy damper could help if the motor isn't balanced well.
With that said this fine girl's Element Tuning engine got us through the weekend with flying colors. She was absolutely screaming around the track!
Here are the 25 seconds of Lime Rock Park that make you want to go back!!! We just missed out on first place at the Trans AM and Whelen USTT Championship in TT1 to a race prepped GT Viper by 4/100ths of a second. Given that has been a winning car and we are no where near TT1 spec (we just decided to up class the car and even the TT3 winner was faster on the straights. LOL!) I'm happy with the result and the testing we got out of the weekend.
I think I'll discuss more about the oiling and the engine in the other bearing and oiling thread as it's most relevant over there.
Thanks,
Phil Grabow
SportInjected (09-25-2014)
Old 12-26-2014, 11:34 AM   #65
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
I don't suppose you want to let us all know how you stop the pins coming out Phil?
I'm thinking a spot welded tab, connected to the rocker at the outer ends so as not to affect the strength of the main stressed parts of the pressed steel?
Nigelr32 is offline   Reply With Quote
Old 12-26-2014, 05:18 PM   #66
350matt
Drives: toyota mr2/ Toyota GT86
wasn't there a thread a while ago about using an lexus ISF follower? these had a bigger roller and pivot pin retainer
don't know if they drop right in though, bound to need some mods though
350matt is offline   Reply With Quote
Old 12-27-2014, 12:02 PM   #67
zooki
Drives: waiting on a 2021...
This thread (and the few like it)are why I keep coming back to this forum and wading through all of the "my air filter on a piece of muffler pipe is better than your air filter on a piece of muffler pipe " threads... Actual useful information.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 4 Users Say Thank You to zooki For This Useful Post:
civicdrivr (01-05-2015), Koa (12-29-2014), themadscientist (12-27-2014), whataboutbob (12-29-2014)
Old 12-27-2014, 05:34 PM   #68
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Hey all this talk off muff and pipe is getting me excited.
Old 12-29-2014, 10:50 PM   #69
Element Tuning
Shhhhh! That's how we solved the rocker issue
Ultramaroon (12-30-2014)
Old 12-29-2014, 10:57 PM   #70
Element Tuning
9k RPM on the dyno and still hanging on. Oil pressure is good too
http://instagram.com/p/xNjK8Bx_hH/
The Following 5 Users Say Thank You to Element Tuning For This Useful Post:
BatStig (12-29-2014), Griever423 (08-31-2015), Koa (12-29-2014), Ultramaroon (12-30-2014), whataboutbob (12-29-2014)
Dented rocker panel daftpunk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 49 08-15-2017 10:41 PM
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
Right quarter and rocker - Ottawa Mgb_bj70 Exterior Parts (Aero, Lighting, Etc.) 0 01-01-2014 03:23 PM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
