Old 09-16-2014, 08:30 PM   #15
Skorov
Skorov's Avatar
Drives: 86 GTS White
Originally Posted by wheelhaus View Post
Yes, aint no thang. I have two JL 8W3v3 and they don't hit quite hard enough to cavitate the cabin and crack the windshield, but the light shroud is solid, no noise whatsoever. I specifically wanted to avoid rattles, so the LED bar mounts to the forward-most face of the carbon that butts against the head liner, which has a slight curve that's not very apparent from the photos. This curve adds a slight preload and keeps it from rattling. It sits about 1/4" off the bottom face (large surface) and from the glass, so there's no chance for rattle.
Simply perfection! ;-)
Skorov is offline   Reply With Quote
Old 09-16-2014, 10:14 PM   #16
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I love this. I would buy it if the price is reasonable
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
wheelhaus (10-04-2014)
Old 09-16-2014, 10:29 PM   #17
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
in if price is right..
would also like a non cf version, but either way.. in if price is right
Great work OP, looks first class!
Also, was there a reason for not going with clear 3m tape and trying to source black instead? Just curious..
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
The Following User Says Thank You to Danklvr For This Useful Post:
Old 09-16-2014, 10:45 PM   #18
Maniak_
Maniak_'s Avatar
Drives: WRB Limited BRZ
Awesome fabrication wheelhaus.
The fit and finish look great!
Looking forward to seeing the end result with the 3m tape.
I might have to jump on this list get one if you do eventually plan to make a batch of them.
Maniak_ is offline   Reply With Quote
The Following User Says Thank You to Maniak_ For This Useful Post:
Old 09-16-2014, 11:07 PM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
FWIW, wheelhaus has made me custom parts in the past. He's a good friend and very talented in designing and manufacturing of these things. He has great attention to detail. I saw his prototype for this last night. You won't be disappointed.
The Following User Says Thank You to Pat For This Useful Post:
wheelhaus (09-16-2014)
Old 09-16-2014, 11:52 PM   #20
wheelhaus
wheelhaus's Avatar
Thanks! Do you mean non carbon, as in fiberglass? We have some resin dye that can make fiberglass appear black. That's certainly possible, might save a few bucks on materials. I have a feeling that this won't be prohibitively expensive. It won't be $50, but certainly won't be $500 either. If you're referring to formed plastic, I'll look into it, but that will take time. Making some decent quality tooling on a budget is the biggest hurdle, I don't want to use/sell something made from plywood, duct tape, and hot glue, but can't afford exotic stainless steel tooling, either.
The clear 3M tape is an option, but I want to avoid having the red light bleed anywhere. The clear might act as a lens and could capture/prism some of the light, which would appear to glow on its own. That's the same reason I want a matte black finish inside the shroud.
Old 09-17-2014, 12:02 AM   #21
Danklvr
Danklvr's Avatar
Thanks for satisfying my curiosities!
Again, finished product looks beautiful in every way!!
Dyed fiberglass would be fine for my needs personally, but I'd be in for either option, if enough interest is generated to warrant you doing a run of them in the future..
Old 09-17-2014, 01:28 AM   #22
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I need it in carbon for the added weight reduction.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
Old 09-17-2014, 01:55 AM   #23
Flow
Drives: DGMBRZ
Flow is offline   Reply With Quote
The Following User Says Thank You to Flow For This Useful Post:
Old 09-17-2014, 02:07 AM   #24
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
This looks awesome! I was happily surprised with how low profile the light was that you mentioned in the second link you posted. How much thickness were you able to decrease your version by?
Jman1759 is offline   Reply With Quote
The Following User Says Thank You to Jman1759 For This Useful Post:
Old 09-17-2014, 02:53 AM   #25
Creole
Creole's Avatar
Drives: Monogram FRS
I'd be in for a group buy. That looks great!
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
The Following User Says Thank You to Creole For This Useful Post:
Old 09-17-2014, 04:07 AM   #26
DustinS
DustinS's Avatar
in for the group buy. Looks great!
The Following User Says Thank You to DustinS For This Useful Post:
Old 09-17-2014, 10:02 AM   #27
wheelhaus
wheelhaus's Avatar
Updated first post with these pics. Its pretty low. I believe the edge that meets the headliner is close to being flush, but the most limiting factor is the trailing edge. If its too high and COMPLETELY invisible from the rear view, then it cuts off too much of the light path, and mounting the LED bar higher isn't really an option. So the most visible edge is the very last trailing edge because it's the lowest and farthest point from the top of the rear glass. That's the faint curve you see.
The Following User Says Thank You to wheelhaus For This Useful Post:
DAEMANO (09-17-2014)
Old 09-17-2014, 10:35 AM   #28
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
This looks awesome - nice work!
I'm quite interested in getting one of these if you do a production run.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following User Says Thank You to codesplice For This Useful Post:
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 11:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
Low profile Seibon Carbon Fiber Spoiler pics mike_ekim1024 Cosmetic Modification (Interior/Exterior/Lighting) 0 04-17-2013 07:56 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 01:03 AM
