Old 09-14-2014, 07:44 PM   #1457
DC2R
Drives: 2014 Scion FR-S
Just downloaded a ton of rooting apps for Chinese had units and tried to get root but no luck this far
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 09-14-2014, 07:55 PM   #1458
BlkR
Drives: GT86
me neither....
BlkR is offline   Reply With Quote
Old 09-14-2014, 08:38 PM   #1459
DC2R
Originally Posted by BlkR View Post
me neither....
Yeah I've exhausted my knowledge.... :/
Guess we could flash older version
Old 09-15-2014, 12:28 AM   #1460
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by SilverlightPony View Post
Actually, it was a bad SD card. I swapped it with another one with the same contents (system "Update" folder and the MCU update file) and it started moving immediately.
Weird.
Mine was hanging up in the same spot as yours. I wiped the card and put the Upload folder on the card by itself. It worked fine after that.
From the amount of crashes and glitches, it seems like they're shipping a product that was like 80% complete.
After updating, the iPod app will not run at all. It opens and crashes within a few seconds. Maybe it somehow found out I was talking shit about it on the internet lol
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 09-15-2014, 05:03 PM   #1461
bwthor
Drives: gray
I struggled with my update too, I had to format the SD Card and put the update folder on there again. The first time I tried it, it just sat on the Ca-Fi screen and flashed. After about 10 minutes, I finally hit the reset button and pulled the SD Card. It rebooted, but came up to a black screen with a crosshair in the upper left corner. That is when I went in and formatted the card and tried again. This time, it went through the normal procedure where it shows the text checking partitions and such.
bwthor is offline   Reply With Quote
Old 09-15-2014, 05:21 PM   #1462
protpibe
protpibe's Avatar
That was pretty much my same experience.
Old 09-16-2014, 01:32 AM   #1463
nphillip
nphillip's Avatar
Have problems playing video on the head unit, hopefully someone can help me out.
When i play a video from my SD card there is audio but no display. For the display to come on i have to turn the car engine off and back on. By doing this the video i've selected plays (with audio and display) but when i go back to select another video it fails again thus needing me to again restart the engine.
I'm not sure if its a problem with the app im using (MX player), my SD card, the head unit or the wiring of my head unit.
I've been thinking it has something to do with the app as its always asking me to update it, but i accidentally hit the 'do not ask again message' so never got around to updating it since it never reminded me again. But then again, if restarting the engine fixes the problem i have a feeling its got something to do with the wiring..
Hoping someone who has experienced this problem can point me in the right direction. Cheers.
nphillip is offline   Reply With Quote
Old 09-16-2014, 01:44 AM   #1464
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
I had no trouble with MX Player before. Haven't tried it since flashing the new update.
SilverlightPony is offline   Reply With Quote
Old 09-16-2014, 01:45 AM   #1465
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Try a different player, like VLC or Mobo.
Pwolf is offline   Reply With Quote
The Following User Says Thank You to Pwolf For This Useful Post:
DC2R (09-16-2014)
Old 09-16-2014, 04:14 AM   #1466
Moor
Drives: Toyota Sienna
nphillip, Somewhere in DASHLINQ settings there is an option "to Show (video) during movement", try, probably will help
Moor is offline   Reply With Quote
Old 09-16-2014, 06:57 AM   #1467
DC2R
Think that setting only applies to stock app
Old 09-16-2014, 11:02 AM   #1468
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Will just sent me the the newest Firmware with Car-Home disabled, download it here:
http://we.tl/jul4c2xvZQ
I haven't tried it yet because I'm worried that it's still not rootable, so if someone else wants to give it a shot and try rooting please report back, I'm also going to ask will if he can send me a version with root access enabled already.
Deathalo is offline   Reply With Quote
Old 09-16-2014, 11:47 AM   #1469
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Orisai View Post
Neither Ca-Fi nor Android's fault Apple forces their own retarded proprietary stuff instead of standard, widely used audio and data interfaces such as AUX and USB.
Actually, this isn't telling the whole truth. It's not like you can't use Aux to play music from your iPhone on this head unit (you're heavily implying here that Apple somehow prevents you from doing this), it's just much less convenient, because Aux doesn't transfer controls to the head unit, nor does it charge your phone. Secondly, Ca-Fi made the decision to put the antiquated 30 pin dock connector on this unit, and that is their bad. I understand not putting a lightning connector (they'd have to pay Apple a licensing fee), but they could've just accepted input from an Apple lightning cable via USB like every other car stereo does. That's not Apple's fault, since the end opposite the phone of an Android charger and an Apple charger are both the same USB end. You're criticizing the convenience of Apple's iPod (yes, proprietary) standard, which you don't have to use. There are two other ways to play music from your Apple phone on this head unit. Pick one. Ca-Fi's implementation of the (once again, yes, proprietary) iPod standard is just incredibly poor.
Prog is offline   Reply With Quote
Old 09-16-2014, 01:44 PM   #1470
Deathalo
I just don't understand why people are even worrying about putting an iPod in your car when you can just buy a 256GB flash drive for ~$70 or shit a 1TB slim HDD and use a much better on screen player, I just don't get it...
The Following User Says Thank You to Deathalo For This Useful Post:
DC2R (09-16-2014)
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
