Old 09-15-2014, 02:07 PM   #15
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
This has been a common issue since I got the car over 2 years ago. I just add to it every now and then.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
whataboutbob (09-15-2014)
Old 09-15-2014, 02:10 PM   #16
nyfries
Drives: 14 FRS Whiteout
Originally Posted by Fastbrew View Post
When filling with Subaru supercoolant - you only need to fill to the bottom line. That's enough coolant. That is how they ship as well.
I assume when cold? No need to dilute?
nyfries is offline   Reply With Quote
Old 09-15-2014, 03:10 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Im stock power wise and have had to top mine off 3 times so far through 2+ years and 57,000 miles. Done a couple test at the dealer and then got tired of paying for it so just said forget it. Never found a cause to a somewhat common "issue".
Old 09-15-2014, 05:41 PM   #18
Fastbrew
Drives: 2014 Pearl White BRZ
It is typically premixed at 50/50 so no need to dilute. Cold is the time to add.
Fastbrew is offline   Reply With Quote
The Following User Says Thank You to Fastbrew For This Useful Post:
nyfries (09-15-2014)
Old 09-15-2014, 06:22 PM   #19
nyfries
Thanks guys I guess it's off to Subaru tmml! I assume the blue coolant can only be brought from Subaru and toyota uses the pink ones?
Old 09-15-2014, 06:50 PM   #20
FR-S Matt
I use the blue toyota coolant off Amazon. Same as the subaru stuff. Don't put any other color stuff in.
Old 09-15-2014, 07:45 PM   #21
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
The only reason I use OEM coolant is because of warranty reasons.
texasbound972 is offline   Reply With Quote
Old 09-15-2014, 07:47 PM   #22
nyfries
So toyota dealership also carries the blue stuff than?
Old 09-15-2014, 07:49 PM   #23
texasbound972
USMC
Same shit different name lol.
Old 09-15-2014, 07:55 PM   #24
FR-S Matt
Yes, it just costs a bit more than Amazon.
Old 09-15-2014, 09:07 PM   #25
Euro7R
Drives: 2013 Subaru BRZ
I just checked my car after work and the coolant reservoir is right at the line on "low" and after driving home (20 minutes or so) and checking again, it's between low and full range. I assume, this is apparently normal as long as reservoir isn't below "low" line.?
Euro7R is offline   Reply With Quote
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
lost my step-dad 5/25/13. :( charged86 Off-Topic Lounge [WARNING: NO POLITICS] 49 06-02-2013 12:54 PM
WE LOST :( Johnp Scion FR-S / Toyota 86 GT86 General Forum 47 03-29-2013 04:10 PM
im lost... lol _F-R-S_ Mid-Atlantic 2 10-07-2012 11:04 PM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
