Old 08-09-2014, 02:04 PM   #1429
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Questions and Discussion on Vortech Supercharging Systems
Originally Posted by Cal3000 View Post
Anyone do a weight study on the system yet? I'm estimating the whole system weighs around 55lbs.
I got:
Blower 19.3lb
IC 12.3
other stuff 17
49lbs give or take
Note that the washer bottle holds less fluid than stock. On the other hand adding a catch can, oil cooler and radiator gets you close to your guesstimate.
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
Cal3000 (08-10-2014)
Old 09-15-2014, 12:12 PM   #1430
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by AJPG View Post
@Tye300 you can use the 3.125 pulley with the stoke fuel system it work OK for me, but as soon as header and exhaust we're install it urgently needed more fuel, so be wear AFR is a good idea.
Somehow the mention did not work. Anyway, I've decided to pull the trigger and get the moto-east flex fuel kit. Next will be some injector dynamics 850cc and an aeromotive fuel pump.
The question is, since I already have full exhaust mods, will the chosen hardware be good enough when I upgrade to a 3.125 pulley and run on E85?
Any replies or comments would be appreciated. Thanks!
Tye300 is offline   Reply With Quote
Old 09-15-2014, 12:19 PM   #1431
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
I'm currently on fic 550 and a dw65c(fuel pump was thrown into the deal but the new aem E85 looks much more promising).
You should be fine with the 850's
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Tye300 (09-15-2014)
Old 09-15-2014, 12:45 PM   #1432
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I have been considering upgrading my pump and injectors for e85. Is anybody using open source for tuning? Just curious if any issues have come up.
bee_are_zee is offline   Reply With Quote
Old 09-15-2014, 01:23 PM   #1433
Tye300
Tye300's Avatar
@marcoaferrer Thanks! Good to hear!
One last question, regarding the 3.125 pulley, what belt size do I need? I heard I could still use the one for the stock pulley.
The Following User Says Thank You to Tye300 For This Useful Post:
marcoaferrer (09-15-2014)
Old 09-15-2014, 01:27 PM   #1434
AJPG
Drives: 22RE, FA20, 4G63
Here with the 550 injectors and DW65 pump, I think (test soon) that it will work just fine with the 2.8 pulley, but no E85 at the pump were I'm... Use Sunoco 100 (that one is at the pump) could you believe that shit?!
The 850 seems a bit large for the 3.125 pulley, but you will find soon enough that you really desire more whp. "2.8 pulley".
AJPG is offline   Reply With Quote
Old 09-15-2014, 01:40 PM   #1435
Tye300
Tye300's Avatar
Yeah, that's what I was thinking. Headroom for more boost just in case. What's the real verdict on the 2.8 pulley? Will it over spin the blower or not? I've seen some people have been using it, but no reports of bad results. I track my car often, so if it would overspin it with the 2.8, then I wouldn't risk it. That's why I'm looking hard at the 3.125. I also saw the numbers @nelsmar was making with the 3.125 and e85, and I think it was impressive. I would be very happy with those numbers or close to it.
Old 09-15-2014, 11:49 PM   #1436
AJPG
It will over spin for <200 RPMs and that's at red line, so very short time. The thing is that it will spinning faster at all RPMs and produce more heat... So custom supercharger oil cooler instead on plug to inferior, contaminated maybe overheated engine oil. Will take some pics after removal the bumper again.
Completely out of place! If track or drive at least moderate with AT will need additional oil cooler.
Old 10-22-2014, 02:39 PM   #1437
diirk
diirk's Avatar
Drives: 4Runner
Are there any concerns with the dealership running a diagnostic on a Vortech equipped car? Will they screw up the programming or anything?
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-22-2014, 03:17 PM   #1438
ft86me
ft86me's Avatar
Drives: 2013 FRS
I currently have nelsmars 3.125 pulley on 91 and I must say it's a very big difference between that one and the 9psi that comes w the kit. I had him also tune mine and all I have to say is , fuuuuuuuuck.
ft86me is offline   Reply With Quote
The Following 2 Users Say Thank You to ft86me For This Useful Post:
diirk (10-22-2014), Tye300 (10-22-2014)
Old 10-22-2014, 04:00 PM   #1439
Tye300
Tye300's Avatar
Thanks bro. I decided to go with the 3.125 pulley. Less boost, safer operating parameter for the Blower. I will be installing the pulley tom. Will update you guys with the numbers.
ft86me (10-22-2014)
Old 10-24-2014, 01:37 AM   #1440
Tye300
Tye300's Avatar
Done with the 3.125 install. Made 349whp/252tq. More details in my build thread if interested.
http://www.ft86club.com/forums/showp...&postcount=335
Old 10-24-2014, 10:53 AM   #1441
charged86
charged86's Avatar
that's beefy congrats
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Tye300 (10-24-2014)
Old 12-17-2014, 09:22 AM   #1442
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
WTB stock pulley for a V3 kit I picked up.
Also does anyone know what the stock map sensor included in the kit is? I read its 2.5bar but I'd like to know more specifically the brand etc.
Thanks
cruizin01 is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
