Old 09-14-2014, 05:48 PM   #155
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
@Shiv@Openflash
When trying to upload any of the 700l files to the tablet the OpenFlash Manager says that the checksum of xyz is wrong. Sorry for the stupid question but is something wrong with the files or with me?
Efferalgan is offline   Reply With Quote
Old 09-14-2014, 05:51 PM   #156
Efferalgan
These 3 error boxes pop up one after another.
Old 09-14-2014, 06:21 PM   #157
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FYI @Shiv@Openflash , I've been checking each new version since 2.03 and you guys still have an issue with the 91 oct Stage 1 map for the 900C cal ID. It says 700C not 900C when i look at the file with a hex editor. If it were that simple I'd just change that to 900C and go on my merry way, but there must be more to it than that -- I replaced with 900C in the two instances and it still won't let me load the map to my OFT. 93 oct map and E85 maps work just fine however.
Just fixed the Stage 1 900C 91oct map. You are correct, it still had a 70C CAL ID. Updating now and should be downloadable (as v2.061) in a few minutes. Thank you for brining this to my attention.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
PMok (09-14-2014)
Old 09-14-2014, 06:23 PM   #158
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Efferalgan View Post
@Shiv@Openflash
I don't see anything obviously wrong with the file. Please email me at shiv@openflashperformance.com and we can troubleshoot
Old 09-14-2014, 11:51 PM   #159
lucid215
here is a recent log i took after flashing the new 2.06 rom and did a maf scaling. OFT stage 2 uel 93, takeda intake, OFH, invidia over/front pipe, JDM TRD axle back
http://www.datazap.me/u/lucid215/3rd...ta=1-2-7-11-12
lucid215 is offline   Reply With Quote
Old 09-15-2014, 12:54 AM   #160
cookiesowns
Drives: WRB BRZ Series.Blue
When is the launch control going to be added to D00C maps?
cookiesowns is offline   Reply With Quote
Old 09-15-2014, 02:11 AM   #161
ScionFrsFan
http://datazap.me/u/scionfrsfan/e85-...g=0&data=1-2-8
Can someone check mine out. Just picked up a code P0456. Double checked gas cap and it was on tight. Cleared code and drove it around...nothing yet.
Stock car e85. 200ish miles ago switched over to V2.06 tune.
Thanks!!!
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 09-15-2014, 06:08 AM   #162
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
There are a lot of questions here from people running goofy setups, so anyone reading this who hasn't read any of the other oft threads might think that the new tunes aren't great. They'd be wrong. This setup is AMAZING on a stock car. The oft 93 stage 1 really feels like a completely different car. For most of us, this is really all the car needs power wise. Shiv is the man!
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
lucid215 (09-15-2014)
Old 09-15-2014, 09:40 AM   #163
lucid215
oh im not downing the oft. im loving it right now. my car has been acting weird cause maybe the temp drop or its that time of month for her. not sure which haha
Old 09-15-2014, 11:27 AM   #164
steve99
Drives: FT86
looks fine to me, maf scaling look good far better than before :-)
Old 09-15-2014, 11:32 AM   #165
smellslikecurry
Put about 100 miles on the e85 map on a stock car. Loving it so far. The cars mpg readouts are reading around 28-30mpg. Doesn't seem normal with e85. Any insight?
smellslikecurry is offline   Reply With Quote
Old 09-15-2014, 11:39 AM   #166
steve99
Drives: FT86
The readout is incorrect as the injector scaling has been upped about 25% for E85 hence the readout will be about 25% off.
smellslikecurry (09-15-2014)
Old 09-15-2014, 11:43 AM   #167
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Only talking about 98 ron in Australia i have no knowledge of EU fuels. G rom is used in Australia, Europe, South Africa pretty hard to account for all fuels Shiv is just being safe. If you have good fuel then make up a 93 map and test that.
So the only changes in the US93 Tune compared to the EU Tune is the Ignition timing - advance Base timing B table? so just copying that table in the EU tune should do it?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
The Following User Says Thank You to GT86meMR2 For This Useful Post:
unlimited86 (09-15-2014)
Old 09-15-2014, 11:56 AM   #168
lucid215
only thing im concerned about is the high (13) afr before 4300 rpms. is that a issue?
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
