Old 09-13-2014, 04:49 PM   #15
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Originally Posted by dradernh View Post
So if I drop 15# per corner, that's an effective 1200# total reduction for the car, and I now have, effectively, a 1550# car...instead of a 2750# car. Gadzooks!
I did drop 12lbs per corner of wheel/tire weight on our Forester XT going from stock wheels with heavier than stock tires to the lightest wheels and tires I could find for it (without breaking the bank). Made a dramatic difference in acceleration and ride quality, but unfortunately the tires were a low rolling resistance with a mushy sidewall. In retrospect, I would have rather given up a couple of pounds of weight on the tires to get a higher performance, better handling tire.
Nowhere near an effective 20lbs per corner though, as that would have meant close to 1000 lbs of effective weight reduction. I have done 500 lbs of weight reduction on another car in the past (most of that not unsprung weight) and it wasn't that dramatic. It did make 5th gear acceleration with the lighter wheel package feel like 4th gear acceleration with the heavier one on the Forester.
It is difficult and costly to remove that much wheel/tire weight from the twins though, unfortunately. Lightest reasonably priced 17" wheel/tire combo I found on Tire Rack is 8 lbs per corner lighter than stock (Kosei K4R/Hankook V12evo2). Stepping up to a much more expensive wheel like a Volk CE28 can drop the weight lost to 10 lbs/corner. Going down to a 16" wheel/tire combo with Volks makes a 12 lb weight loss per corner possible with shaved tires.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 09-13-2014, 08:07 PM   #16
troek
troek's Avatar
Drives: 2012 Toyota 86
@Yui-Chan ill take some pics later today.
troek is offline   Reply With Quote
The Following 4 Users Say Thank You to troek For This Useful Post:
CSG Mike (09-14-2014), funwheeldrive (09-21-2014), Yui-Chan (09-13-2014), Zaneman (09-14-2014)
Old 09-13-2014, 08:17 PM   #17
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
The rule of thumb is 1 Lb of rotational mass in a tire /wheel/brake equals 10 Lbs of sprung weight.
So removing 5 Lbs per wheel/tire should roughly affect performance as much as lightening the car 200Lbs. 5x4x10=200.
The key is Rotational mass not unsprung weight. Tires, wheels, & rotors do not only accelerate linearly but also rotationaly. The further from the center of the rotation the more critical the weight is. 1 Lb on a tire has a greater effect than 1Lb in a rotor. However they would both affect unsprung weight about the same amount.
Caspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Caspeed For This Useful Post:
Jond63 (09-14-2014), raul (09-14-2014)
Old 09-13-2014, 11:26 PM   #18
Yui-Chan
Drives: Toyota
@troek: Sugoi!
Wish 16" RPF1s were available with concave or flat spokes though, like the 17x9 +35. But the low weight is awesome and very attractive!
Yui-Chan is offline   Reply With Quote
The Following 2 Users Say Thank You to Yui-Chan For This Useful Post:
CSG Mike (09-14-2014), Jond63 (09-14-2014)
Old 09-14-2014, 01:42 AM   #19
troek
troek's Avatar
日本語話せますか? yeah i wish they looked like the 17x9s as well.
The Following User Says Thank You to troek For This Useful Post:
Old 09-14-2014, 02:55 AM   #20
Yui-Chan
Drives: Toyota
日本語は得意じゃないんで。
The Following User Says Thank You to Yui-Chan For This Useful Post:
Old 09-14-2014, 06:55 AM   #21
troek
troek's Avatar
ぼくも下手:p
Yui-Chan (09-14-2014)
Old 09-14-2014, 09:51 AM   #22
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Sounds like you've thought about this in depth.
There is one more way to get significant weight off the twins' corners. The Essex Parts AP Racing Sprint Kit will drop 10.8# per corner; list is $2099, and some of the vendors here sell the kit.
http://www.essexparts.com/essex-comp...86-bundle.html
dradernh is offline   Reply With Quote
Old 09-14-2014, 02:17 PM   #23
CSG Mike
CSG Mike's Avatar
:raises hand:
Old 09-14-2014, 02:33 PM   #24
Yui-Chan
Drives: Toyota
Unsprung-to-sprung weight equivalent comparisons varies so greatly among different people and companies lol... I've seen anywhere from 1:1.7 to 1:20....most popularly, 1:6 ..but I've read about some smart engineer guy doing some intense calculations and figured out that 1:1.7 is the most realistic (which it sounds and feels like in the real world I think).
Of course, like someone mentioned already, it also depends on rotational mass and how much of its' mass is away from center rotation. Less rotational mass and weight = less gyroscope effect = less work the suspension needs to work and compensate.
Also, for weight-reduction to hp equivalent calculations, it's best to use the factor of each car's specific power to weight ratio (gt86 = 2775 / 200bhp = 13.9)
AP Sprint kit = 20lbs weight reduce
20lbs * 1.7 to 20lbs * 6 (depending on which unsprung-to-sprung myth ration you're using, lol) = 34lbs to 120lbs sprung
34lbs / 13.9 to 120lbs / 13.9 = 2.5bhp to 8.6bhp from an AP Sprint kit!
Now, 1:1.7 to 1:6 is a huge difference, but it seems no one really knows what the definite true equivalency ratio to use is (as everyone says different things...anywhere from 1:6-1:20?! lol!). I also don't really know what I am talking about (lol) and I am just a hobby'ist and not an engineer obviously. But, from my ghetto calculations, you can see how weight affect crank bhp ..take it with a grain of salt...as I am just a ricer and not an engineer lol.
SuperTom (10-12-2018)
Old 09-14-2014, 03:10 PM   #25
Phil_Marino
Drives: 2013 FRS (red)
Originally Posted by Cheeseballs View Post
From Enkei themselves:
"Every pound of unsprung weight savings has the effect of reducing overall vehicle weight by 20lbs."
http://www.enkei.com/rpf1.shtml
Well.. It depends on what effects you're considering. As far as acceleration, wheels usually have about a 1.5 mass multiplier. It depends a lot on the tire section height - the closer to the OD of the tire the wheel mass is, the larger the multiplier- but it probably rarely exceeds 1.6.
So, 5# x 4 wheels x 1.5 = 30#. That means, as far as acceleration is concerned, saving 5#/wheel is like reducing total (sprung) vehicle weight by about 30#. Maybe the same as taking our your spare tire.
Handling (and ride) changes are harder to quantify and are probably affected much more than acceleration.
Also, keep in mind that Enkei's goal is to sell their lightweight wheels.
Phil
Phil_Marino is offline   Reply With Quote
The Following User Says Thank You to Phil_Marino For This Useful Post:
Wayno (09-14-2014)
Old 09-14-2014, 03:32 PM   #26
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Phil
Good points you make. I figured Enkei's claim has diminishing returns since it's possible to lose a whole lot of unsprung weight if you've got the determination and $$$ to do so.
Cheeseballs is offline   Reply With Quote
Old 09-14-2014, 09:39 PM   #27
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
No, only on the front.
tahdizzle (09-15-2014)
Old 09-14-2014, 09:43 PM   #28
Captain Snooze
Drives: Red Herring
Originally Posted by TM View Post
I don't know too much about it, but they say every 1lb of unsprung weight is equivalent to ~10lbs sprung weight.
Who are they? I love these numbers. They crop a lot in forums with nothing to back up the claim. I am suggesting a 1 pound saving on a 20 pound mass is more significant than on a 30 pound mass of unsprung weight.
You mean from Enkei's marketing department. There is no mention of where that mass is taken from. That is,there are no numbers indicating the reduction of angular momentum. Taking 1 pound from the rim is more significant than taking one pound from the hub.
Does the overpipe really make a difference? Wise Engine, Exhaust, Transmission 66 03-02-2014 04:41 AM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
Little details . . . make a difference avusblue Cosmetic Modification (Interior/Exterior/Lighting) 27 08-10-2012 08:53 AM
Do intake systems really make a difference? Echo Engine, Exhaust, Transmission 36 07-26-2012 07:09 PM
Little details . . . make a difference avusblue Scion FR-S / Toyota 86 GT86 General Forum 1 07-21-2012 12:00 PM
