| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Nowhere near an effective 20lbs per corner though, as that would have meant close to 1000 lbs of effective weight reduction. I have done 500 lbs of weight reduction on another car in the past (most of that not unsprung weight) and it wasn't that dramatic. It did make 5th gear acceleration with the lighter wheel package feel like 4th gear acceleration with the heavier one on the Forester. It is difficult and costly to remove that much wheel/tire weight from the twins though, unfortunately. Lightest reasonably priced 17" wheel/tire combo I found on Tire Rack is 8 lbs per corner lighter than stock (Kosei K4R/Hankook V12evo2). Stepping up to a much more expensive wheel like a Volk CE28 can drop the weight lost to 10 lbs/corner. Going down to a 16" wheel/tire combo with Volks makes a 12 lb weight loss per corner possible with shaved tires.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#16 |
Drives: 2012 Toyota 86
| The Following 4 Users Say Thank You to troek For This Useful Post: |
#17 |
Drives: FRS-RS1, Triumph Speed Triple, Lola
The rule of thumb is 1 Lb of rotational mass in a tire /wheel/brake equals 10 Lbs of sprung weight.
So removing 5 Lbs per wheel/tire should roughly affect performance as much as lightening the car 200Lbs. 5x4x10=200. The key is Rotational mass not unsprung weight. Tires, wheels, & rotors do not only accelerate linearly but also rotationaly. The further from the center of the rotation the more critical the weight is. 1 Lb on a tire has a greater effect than 1Lb in a rotor. However they would both affect unsprung weight about the same amount. |
#18 |
Drives: Toyota
@troek: Sugoi!
Wish 16" RPF1s were available with concave or flat spokes though, like the 17x9 +35. But the low weight is awesome and very attractive!
#19 |
日本語話せますか? yeah i wish they looked like the 17x9s as well.
| The Following User Says Thank You to troek For This Useful Post: | CSG Mike (09-14-2014) |
#22 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
There is one more way to get significant weight off the twins' corners. The Essex Parts AP Racing Sprint Kit will drop 10.8# per corner; list is $2099, and some of the vendors here sell the kit. http://www.essexparts.com/essex-comp...86-bundle.html |
#23 | |
#24 |
Drives: Toyota
Unsprung-to-sprung weight equivalent comparisons varies so greatly among different people and companies lol... I've seen anywhere from 1:1.7 to 1:20....most popularly, 1:6 ..but I've read about some smart engineer guy doing some intense calculations and figured out that 1:1.7 is the most realistic (which it sounds and feels like in the real world I think).
Of course, like someone mentioned already, it also depends on rotational mass and how much of its' mass is away from center rotation. Less rotational mass and weight = less gyroscope effect = less work the suspension needs to work and compensate. Also, for weight-reduction to hp equivalent calculations, it's best to use the factor of each car's specific power to weight ratio (gt86 = 2775 / 200bhp = 13.9) AP Sprint kit = 20lbs weight reduce 20lbs * 1.7 to 20lbs * 6 (depending on which unsprung-to-sprung myth ration you're using, lol) = 34lbs to 120lbs sprung 34lbs / 13.9 to 120lbs / 13.9 = 2.5bhp to 8.6bhp from an AP Sprint kit! ![]() Now, 1:1.7 to 1:6 is a huge difference, but it seems no one really knows what the definite true equivalency ratio to use is (as everyone says different things...anywhere from 1:6-1:20?! lol!). I also don't really know what I am talking about (lol) and I am just a hobby'ist and not an engineer obviously. But, from my ghetto calculations, you can see how weight affect crank bhp ..take it with a grain of salt...as I am just a ricer and not an engineer lol.
| The Following User Says Thank You to Yui-Chan For This Useful Post: | SuperTom (10-12-2018) |
#25 | |
Drives: 2013 FRS (red)
So, 5# x 4 wheels x 1.5 = 30#. That means, as far as acceleration is concerned, saving 5#/wheel is like reducing total (sprung) vehicle weight by about 30#. Maybe the same as taking our your spare tire. Handling (and ride) changes are harder to quantify and are probably affected much more than acceleration. Also, keep in mind that Enkei's goal is to sell their lightweight wheels. Phil |
| The Following User Says Thank You to Phil_Marino For This Useful Post: | Wayno (09-14-2014) |
#26 | |
Drives: Really slow
#27 |
Because compromise ®
Drives: Red Herring
No, only on the front.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | tahdizzle (09-15-2014) |
#28 | |
Drives: Red Herring
You mean from Enkei's marketing department. There is no mention of where that mass is taken from. That is,there are no numbers indicating the reduction of angular momentum. Taking 1 pound from the rim is more significant than taking one pound from the hub.
| Does the overpipe really make a difference? | Wise | Engine, Exhaust, Transmission | 66 | 03-02-2014 04:41 AM |
| Tires Make a Big Difference | poudre | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-16-2012 10:58 PM |
| Little details . . . make a difference | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 08-10-2012 08:53 AM |
| Do intake systems really make a difference? | Echo | Engine, Exhaust, Transmission | 36 | 07-26-2012 07:09 PM |
| Little details . . . make a difference | avusblue | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-21-2012 12:00 PM |
