Old 09-11-2014, 11:30 PM   #1891
juliog
juliog's Avatar
Drives: 86
If you're new, I'd suggest you start with Harry's lap timer for iPhone or Android ($20), a Bluetooth OBDII module ($50?, you can also use it to diagnose and clear CELs), and a $25 RAM mount for your phone.
juliog is offline   Reply With Quote
Old 09-11-2014, 11:44 PM   #1892
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I did try that but I wanted something standalone .. Thanks for the output tho !
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 09-12-2014, 01:07 AM   #1893
CSG Mike
CSG Mike's Avatar
Originally Posted by Stumpygt86 View Post
I have a set of 16x7 STI rims and was wanting to know what would be the better option for regarding tyre width.
I am looking at running the Advan 050 R/Spec tyre and was either looking at 225/45 or 215/45.
Cheers
7" Stick to the 215.
Old 09-12-2014, 01:07 AM   #1894
CSG Mike
CSG Mike's Avatar
Originally Posted by Simon99 View Post
So I'm new to tracking but I am interested in getting a data logging box of some sort. I've looked at VBox and AIM particularly, but I was wondering if any of you had suggestions for the noob that I am. I'd love something that could also support a camera (is GoPro an option?) and overlays in video export if that's possible. I don't mind ''used'' at all, since from what I've seen they all start at around 600$. I'm setting a budget of 750$ for everything, but the lower the better !
AIM Solo DL is the way to go for the OBD2 logging, and you can integrate it using racerender.
Old 09-13-2014, 03:47 AM   #1895
Carmaniac 86
Drives: Frs
Hey I got my FRS a month ago and I want to do autocross within the next month or so. I haven't done anything to the car except put a aftermarket Catback on it. I was wondering if there were anything I should do to the car? It'll be my first time autox
Carmaniac 86 is offline   Reply With Quote
Old 09-13-2014, 06:19 AM   #1896
nyfries
Drives: 14 FRS Whiteout
Should go as stock as possible for your first ran. U will learn a lot about the car and u as a driver. I feel like the best mistake and one can make is going autox first time with an overbuilt car for their ability.
Sent from my iPad using Tapatalk HD
nyfries is offline   Reply With Quote
Old 09-13-2014, 09:37 AM   #1897
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Go out there and just have fun.
Many people, including the quote above and myself, will tell you to go out and learn the car before making changes. It is difficult to learn unless you have some way to review what happened. Therefore, some kind of video of your driving would be helpful. The best would be to see your hands on the wheel and the car. If you have a GoPro or some other camera, use it. You will learn more from that than anything else in my opinion.
But most importantly, have fun. If you get upset and whiny about not winning your first time out, you will have a bigger struggle. A good target is to make each run you do faster than the previous.
Cheers,
bimmer635csi is offline   Reply With Quote
Old 09-13-2014, 09:42 AM   #1898
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Best mod is the driver mod. Just plan on soaking up as much as you can when starting out. The car will be fine as-is.
Bring a good quality tire gauge - you'll likely need to adjust tire pressures, and you'll want a reliable tool with which to do it. I use a bicycle pump for adding air; it works, it's small, its air supply is inexhaustible, and it never fails. Bring food/snacks and water for the driver.
If you can, find out who the most capable instructors are that will be at the event, and then find a way to get them into your car for one or more of your runs. Depending upon how the event is structured, simply asking in a nice way may be all you need to do.
+1 on shooting video of your driving, if you can. Reviewing what really happened instead of what you think you remember happened is much more productive.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
wparsons (09-13-2014)
Old 09-13-2014, 10:57 AM   #1899
Carmaniac 86
Drives: Frs
Yea I don't plan on modding I was wondering more like if I should change brake fluid to higher boiling point but idk it it'll get hot enough in autox
Old 09-13-2014, 11:22 AM   #1900
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
My car dyno'd ~365hp at the wheels and I'm about to hit Buttonwillow in a couple of weeks. I am also installing a set of new RS3 tires for the stock rims. I will run these out before upgrading to wider tire/rims in 2015. The question is that with this much power and these small of tires, I'm worried about extreme oversteer in the corners. Should I find a way to add weights to the trunk to help with this and balance the weight more? Anyone know what is allowed for HPDE and added weight in the trunk?
nlowell is offline   Reply With Quote
Old 09-13-2014, 01:28 PM   #1901
CSG Mike
CSG Mike's Avatar
Do nothing, go stock. You'll know what you want to change after that first day without having to ask for opinions
AZP Installs (09-13-2014)
Old 09-13-2014, 01:29 PM   #1902
CSG Mike
CSG Mike's Avatar
I can always alter your tune to emulate a stock car's output... why get all this power if you're not going to use it? Learning throttle control is one of the most basic skills you learn at the track. The Mustang/Vette/Porsche/Ferrari/etc. guys don't have it any different.
AZP Installs (09-13-2014), wparsons (09-13-2014)
Old 09-13-2014, 03:19 PM   #1903
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Exactly. If you can't learn to control your right foot, then you SHOULD NOT BE ON THE TRACK as you will be a danger to yourself and others.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 09-13-2014, 03:39 PM   #1904
nlowell
nlowell's Avatar
Got a track related question? I'll try to answer.
Wow, tough crowd - I will ease into it, don't worry. I just noticed that some drivers at the track are adding weight to the trunk to better balance the front to rear weight ratio. That was my question - guess I should have left the rest out.
P.S. my previous car was a C6 Corvette but I had that car corner balanced.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
